前几天stm32写了一个通用定时器,和一个串口,但是在使用的时候发现了:初始化定时器的函数在就不能运行串口- 定时器的相关配置:
- void TIM3_Int_Init(u16 arr,u16 psc)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- NVIC_InitTypeDef NVIC_InitStructure;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //时钟使能
- //定时器TIM3初始化
- TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值
- TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值
- TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式
- TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根据指定的参数初始化TIMx的时间基数单位
- TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE ); //使能指定的TIM3中断,允许更新中断
- //中断优先级NVIC设置
- NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; //TIM3中断
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //先占优先级0级
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //从优先级3级
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
- NVIC_Init(&NVIC_InitStructure); //初始化NVIC寄存器
- TIM_Cmd(TIM3, ENABLE); //使能TIMx
- 串口的相关配置:
- void uart_init(u32 bound){
- //GPIO端口设置
- GPIO_InitTypeDef GPIO_InitStructure;
- USART_InitTypeDef USART_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE); //使能USART1,GPIOA时钟
- //USART1_TX GPIOA.9
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出
- GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.9
- //USART1_RX GPIOA.10初始化
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
- GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.10
- //Usart1 NVIC 配置
- NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0 ;//抢占优先级0
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //子优先级3
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能
- NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器
- //USART 初始化设置
- USART_InitStructure.USART_BaudRate = bound;//串口波特率
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
- USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
- USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式
- USART_Init(USART1, &USART_InitStructure); //初始化串口1
- USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启串口接受中断
- USART_Cmd(USART1, ENABLE); //使能串口1
- void USART1_IRQHandler(void) //串口1中断服务程序
- u8 Res;
- #if SYSTEM_SUPPORT_OS //如果SYSTEM_SUPPORT_OS为真,则需要支持OS.
- OSIntEnter();
- #endif
- if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //接收中断(接收到的数据必须是0x0d 0x0a结尾)
- Res =USART_ReceiveData(USART1); //读取接收到的数据
- if((USART_RX_STA&0x8000)==0)//接收未完成
- if(USART_RX_STA&0x4000)//接收到了0x0d
- if(Res!=0x0a)USART_RX_STA=0;//接收错误,重新开始
- else USART_RX_STA|=0x8000; //接收完成了
- else //还没收到0X0D
- if(Res==0x0d)USART_RX_STA|=0x4000;
- else
- USART_RX_BUF[USART_RX_STA&0X3FFF]=Res ;
- USART_RX_STA++;
- if(USART_RX_STA>(USART_REC_LEN-1))USART_RX_STA=0;//接收数据错误,重新开始接收
- OSIntExit();
- #endif
