[传感器] 国产平替 16/20/24/32-bit 高精度 Σ-Δ 模数转换器芯片
5608|5
 楼主| slot867 发表于 2023-12-1 11:11 | 显示全部楼层 |阅读模式
信格勒微电子的芯片产品已通过行业头部大厂导入验证,深受百万终端客户好评。
而且因为 fully compatible. 板子拿来,换个芯片,性能更好。MCU不用改 c code。
平替TI芯片
SIG1230A 平替 ADS1230 (20-bit)
SIG1232A 平替 ADS1232 (24-bit)
平替ADI芯片
SIG7190 平替 AD7190
SIG7192 平替 AD7192
SIG7193 平替 AD7193
平替Cirrus Logic芯片
SIG5532B 平替 CS5532BS(32-bit)
SIG5534B 平替 CS5534BS(32-bit)
SIG5532A 平替 CS5532AS(24-bit)
SIG5534A 平替 CS5534AS(24-bit)
SIG5530 平替 CS5530 (24-bit)
SIG5530B 平替 CS5530(32-bit)
平替ADI芯片
SIG7792 平替 AD7792
SIG7793 平替 AD7793
SIG7794 平替 AD7794
SIG7795 平替 AD7795
SIG7796 平替 AD7796
SIG7797 平替 AD7797
SIG7798 平替 AD7798
SIG7799 平替 AD7799
功能替代TI芯片
SIG24130/SIG24131/SIG24132 替代 ADS1220、ADS1247、ADS1248
SIG16130/SIG16131/SIG16132 替代 ADS1120、ADS1147、ADS1148
 楼主| slot867 发表于 2024-1-19 10:28 | 显示全部楼层
性能更佳
SIG7792/SIG7793
4.17SPS to 890SPS ADC with PGA and Reference
Compatible Parts
AD7792/AD7793 pin/register fully compatible (10nV/℃ and 3ppm/℃).
Features
Programmable Gain: 1/2/4/8/16/32/64/128
Data Rates: 4.17SPS to 890SPS
RMS Noises: 20nV at 4.17SPS (Gain = 128)
23.2ENOB (21.0 noise-free bits) at 4.17SPS (Gain= 1)
Offset Drift: 5nV/℃ (Gain = 128)
Gain Drift: 1ppm/℃
Integral Non-linearity: 3ppm
internal reference: 4ppm/℃
Reference input current: 1uA
Internal or External Clock
Simultaneous 50Hz/60Hz Rejection
4 Differential Inputs
Current: 0.5mA
Specified Temperature Range: -40℃ to 125℃
Package: 16-ld TSSOP
Power Supply
AVDD: 2.7V to 5.25V
DVDD: 2.7V to 5.25V
 楼主| slot867 发表于 2024-2-22 10:23 | 显示全部楼层
性能更佳
SIG7193
4.7SPS to 4.8kSPS 24-bit ADC with PGA gain 1 to 128
Compatible Parts
AD7193 pin/register fully compatible.
Features
  • Programmable Gain: 1/2/4/8/16/32/64/128
  • Data Rates: 4.7SPS to 4.8kSPS
  • RMS Noises: 15nV at 10SPS (Gain = 128)
  • 24.4ENOB (22.0 noise-free bits) at 10SPS (Gain= 1)
  • Offset Drift: 3nV/℃ (Gain = 128)
  • Gain Drift: 0.5ppm/℃
  • Integral Non-linearity: 3ppm
  • Reference input current: 500nA
  • Internal or External Clock
  • Simultaneous 50Hz/60Hz Rejection
  • 2 Differential/4 Pseudo Differential Inputs
  • Power Supply
    AVDD:
    2.7V to 5.25V or ±2.5V
    DVDD:
    2.7V to 5.25V
  • Specified Temperature Range: -40℃ to 125℃
  • Package: 28-ld TSSOP
  • Current: 2.7mA
 楼主| slot867 发表于 2024-2-22 10:25 | 显示全部楼层
性能更佳
SIG5530
1.6SPS to 3840SPS 24-bit ADC with PGA GAIN = 64
Compatible Parts
CS5530 pin/register fully compatible (10nV/℃ and 2ppm/℃).
Features
  • Programmable Gain:64
  • Data Rates: 1.6SPS to 3840SPS
  • RMS Noises: 16nV at 4.17SPS (Gain = 128)
  • Offset Drift: 5nV/℃ (Gain = 128)
  • Reference input current: 250nA
  • SINC3/SINC1 Filter Option
  • 2 Differential Inputs
  • Current: 4.0mA
  • Package: 20-ld TSSOP
  • Power Supply
AVDD:
4.75V to 5.25V or ±2.5V
DVDD:
  2.7V to 5.25V
 楼主| slot867 发表于 2024-2-23 15:21 | 显示全部楼层
性能更好
SIG1232A
10/80SPS 24-bit ADC with PGA
Compatible Parts
ADS1232 fully compatible  (10nV/℃ and 2.5ppm/℃).
Features
  • Programmable Gain: 1/2/64/128
  • Data Rates: 10/80SPS
  • RMS Noises: 19nV at 10SPS (Gain = 128)
  • 23.0ENOB (20.9 noise-free bits) at 10SPS (Gain = 1)
  • Offset Drift: 5nV/ (Gain = 128)
  • Gain Drift: 1ppm/℃
  • Reference input current: 30nA
  • Power Supply
    AVDD:
    DVDD:
    2.7V to 5.25V
  • Current: 1.5mA
  • Package: 24-ld TSSOP
 楼主| slot867 发表于 2023-12-1 11:12 | 显示全部楼层
Product No.
Data Rate
PGA Gain
Resolution
Offset Drift
Gain Drift
Power
Package
Features
SIG5532B
1.6SPS to 3840SPS
1/2/4/8/16/32/64
32-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
6.0mA
TSSOP-20
2 Differential Channels
SIG5534B
1.6SPS to 3840SPS
1/2/4/8/16/32/64
32-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
6.0mA
TSSOP-24
4 Differential Channels
SIG5531A
1.6SPS to 3840SPS
1/2/4/8/16/32/64
16-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
4.0mA
TSSOP-20
SIG5532A
1.6SPS to 3840SPS
1/2/4/8/16/32/64
24-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
4.0mA
TSSOP-20
SIG5533A
1.6SPS to 3840SPS
1/2/4/8/16/32/64
16-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
4.0mA
TSSOP-24
SIG5534A
1.6SPS to 3840SPS
1/2/4/8/16/32/64
24-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
4.0mA
TSSOP-24
SIG5530B
1.6SPS to 3840SPS
64
32-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
6.0mA
TSSOP-20
SIG5530
1.6SPS to 3840SPS
64
24-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
4.0mA
TSSOP-20
SIG5530C
1.6SPS to 200SPS
64
24-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
4.0mA
TSSOP-20
SIG5632
1.6SPS to 30.72kSPS
1/2/4/8/16/32/64
32-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
6.0mA
TSSOP-20
SIG5634
1.6SPS to 30.72kSPS
1/2/4/8/16/32/64
32-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
6.0mA
TSSOP-24
SIG7190
4.7SPS to 4.8kSPS
24-bit
3nV/℃ (Gain = 128)
0.5ppm/℃
2.7mA
TSSOP-24
4 Single End Channels
SIG7192
4.7SPS to 4.8kSPS
24-bit
3nV/℃ (Gain = 128)
0.5ppm/℃
2.7mA
TSSOP-24
SIG7193
4.7SPS to 4.8kSPS
24-bit
3nV/℃ (Gain = 128)
0.5ppm/℃
2.7mA
TSSOP-28
8 Single End Channels
SIG7290
9.4SPS to 9.6kSPS
24-bit
3nV/℃ (Gain = 128)
0.5ppm/℃
4.8mA
TSSOP-20
SIG7293
9.4SPS to 9.6kSPS
24-bit
3nV/℃ (Gain = 128)
0.5ppm/℃
4.8mA
TSSOP-24
SIG7792
4.17SPS to 890SPS
16-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-16
SIG7793
4.17SPS to 890SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-16
SIG7794
4.17SPS to 890SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-24
6 Differential Channels
SIG7795
4.17SPS to 890SPS
16-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-24
SIG7796
4.17SPS to 890SPS
128
16-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-16
SIG7797
4.17SPS to 890SPS
128
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-16
SIG7798
4.17SPS to 890SPS
16-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-16
SIG7799
4.17SPS to 890SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-16
SIG24130
2.5SPS to 9600SPS
1/2/4/8/16/32/64/128/256
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.8mA
TSSOP-16
SIG24131
2.5SPS to 9600SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.8mA
TSSOP-20
SIG24132
2.5SPS to 9600SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.8mA
TSSOP-24
SIG16130
2.5SPS to 9600SPS
16-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.8mA
TSSOP-16
SIG16131
2.5SPS to 9600SPS
16-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.8mA
TSSOP-20
SIG16132
2.5SPS to 9600SPS
16-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.8mA
TSSOP-24
SIG2432
10SPS to 2400SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
1.5mA
TSSOP-24
SIG2430
10SPS to 2400SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
1.5mA
TSSOP-16
1 Differential Channel
SIG2030
10SPS to 1200SPS
20-bit
10nV/℃ (Gain = 128)
2ppm/℃
0.8mA
TSSOP-16
SIG1232A
10SPS/80SPS
1/2/64/128
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
1.5mA
TSSOP-24
SIG1230A
10SPS/80SPS
64/128
20-bit
10nV/℃ (Gain = 128)
2ppm/℃
0.8mA
TSSOP-16
SIG2012
10SPS
64/128
20-bit
10nV/℃ (Gain = 128)
2ppm/℃
0.8mA
TSSOP-16
SIG24293
7.8SPS to 8000SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
1.3mA
TSSOP-16
7 Single End Channels
SIG24294
7.8SPS to 8000SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
1.3mA
TSSOP-24
7 Differential Channels
13 Single End Channels
