TIM3捕获配置时,只要一NVIC_Init使能中断就卡死,咨询下大家
2340|9
 楼主| AProgrammer 发表于 2023-12-1 15:15 | 显示全部楼层 |阅读模式
STM32F103ZET6板子,想用TIM3_CH2来捕获TIM8 CH3输出的pwm,为此将pwm TIM8_CH3输出的管脚PC8 和 TIM3_CH2管脚PA7 连起来后,发现程序执行不下去了(不连起来就能执行)。卡死了好像。请帮看下可能原因。
做过的尝试:
1、自己把TIM3 CH2的优先级改成最高(抢占优先级为0,响应优先级也为0),也不行。
2、PC8 和 TIM3_CH2管脚PA7 连线去除,发现程序能执行下去
3、中断不使能,就是不执行Nvic_init也可以执行下去,说明肯定是和中断相关。
TIM3_CH2初始化的代码:
void InitFan3InletFG(void)
    TIM_ICInitTypeDef TIM_ICInitStructure;
    TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    //初始化GPIO复用
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    //初始化定时器
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
    TIM_TimeBaseStructure.TIM_Period = 0xFFFF-1;
    TIM_TimeBaseStructure.TIM_Prescaler = 72-1; //1us,总时间65ms
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
    /* IC2,上升沿触发 TI2FP2 */
    TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
    TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
    TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
    TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
    TIM_ICInitStructure.TIM_ICFilter = 0x0;
    TIM_PWMIConfig(TIM3, &TIM_ICInitStructure);
#if 0
    /* IC2, 下降沿触发,TI2FP1*/
    TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;
    TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Falling;
    TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_IndirectTI;
    TIM_PWMIConfig(TIM5, &TIM_ICInitStructure);
#endif
    TIM_SelectInputTrigger(TIM3, TIM_TS_TI2FP2);
    TIM_SelectSlaveMode(TIM3, TIM_SlaveMode_Reset);
    TIM_SelectMasterSlaveMode(TIM3,TIM_MasterSlaveMode_Enable);
    TIM_Cmd(TIM3, ENABLE);
    //使能CC2捕获中断,主
////    TIM_ClearITPendingBit(TIM3, TIM_IT_CC2); //20231130 1101: try add this
    TIM_ITConfig(TIM3, TIM_IT_CC2, ENABLE);
    //使能中断
    NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //3; //0; //1; // 3;  //20231130pm5 try modified to 1
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
///////    NVIC_Init(&NVIC_InitStructure); ///////1130pm15: disable try
中断处理代码:
void TIM3_IRQHandler(void)
    Timer3ISR();
void Timer3ISR(void)
    int ret;
    g_tim3Count++;
    if (g_tim3Count % 100 == 0) {
        //printf("timer3 got\r\n");
    TIM_ClearITPendingBit(TIM3, TIM_IT_CC1);
    TIM_ClearITPendingBit(TIM3, TIM_IT_CC3);
    TIM_ClearITPendingBit(TIM3, TIM_IT_CC4);
    //TIM3, CH2通道
    ret = TIM_GetFlagStatus(TIM3, TIM_FLAG_CC2);
    if (ret)
        Tim3Ch2Isr();
    //TIM3, CH1通道
    ret = TIM_GetFlagStatus(TIM3, TIM_FLAG_CC1);
    if (ret)
        Tim3Ch1Isr();
    //TIM3, CH3通道
    ret = TIM_GetFlagStatus(TIM3, TIM_FLAG_CC3);
    if (ret)
        Tim3Ch3Isr();
    //TIM3, CH4通道
    ret = TIM_GetFlagStatus(TIM3, TIM_FLAG_CC4);
    if (ret)
        Tim3Ch4Isr();
一叶倾城wwq 发表于 2023-12-4 09:14 | 显示全部楼层
STM32的捕获用过,挺好用的,不过没用过你这种把2个脚接起来的做法,用的是外接一个信号,去捕获,程序是用cube生成的,你可以试一下,网上一堆教程
@一叶倾城wwq :定位了,是自己的问题,把中断向量表地址设置错了。感谢您的热心支持!  发表于 2023-12-5 15:26
@AProgrammer :能仿真吗?仿真看一下,不一定用信号发生器,用另一个板子的芯片发pwm就行了  发表于 2023-12-5 11:19
@一叶倾城wwq :“pwm TIM8_CH3输出的管脚PC8 和 TIM3_CH2管脚PA7 连起来“,是的,我现在就是TIM8输出的,TIM3想测量的。而且示波器在PC8量了,有持续的方波,占空比是50%, 真是郁闷,不知道为啥卡。  发表于 2023-12-5 09:05
@AProgrammer :还有你输出pwm的定时器和捕获的定时器不要用一个,比如说用timer3输出pwm,用timer1去捕获,尽量分开操作,互不干扰  发表于 2023-12-4 18:43
@AProgrammer :限流,保护引脚,防止一个输出高一个输出低,造成短路  发表于 2023-12-4 18:40
@一叶倾城wwq :为啥要穿个100欧姆的电阻?  发表于 2023-12-4 14:43
@AProgrammer :理论上是可以的,你穿个100欧电阻  发表于 2023-12-4 13:57
能把输出管脚和这个定时器的输入直接连起来吗?我现在没有信号发生器  发表于 2023-12-4 10:44
