[STM32L0] 求问,STM32L151RDT6多通道采用的是ADC+DMA方式,但是驱动不起来是什么原因?
506|0
 楼主| 内政奇才 发表于 2023-12-20 11:36 | 显示全部楼层 |阅读模式
以下为具体程序代码,求大神解答
void AD_Configuration(void)
         DMA_InitTypeDef DMA_InitStructure;
         ADC_InitTypeDef ADC_InitStructure;
         /*Enable DMA1 Clock*/
         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
         /*DMA1 Channel1 Configuration*/
         DMA_DeInit(DMA1_Channel1);
         DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_ADDRESS;
         DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADC_ConvertedValue;
         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
         DMA_InitStructure.DMA_BufferSize = 2;
         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
         DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
         DMA_InitStructure.DMA_Priority = DMA_Priority_High;
         DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
         DMA_Init(DMA1_Channel1, &DMA_InitStructure);
         /*ENABLE DMA1 CHANNEL1*/
         DMA_Cmd(DMA1_Channel1, ENABLE);
         /*------------ADC1 configuration with DMA enabled---------*/
         /*Enable the HSI oscillator*/
         RCC_HSICmd(ENABLE);
         /*Enable GPIOA Clock*/
         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6;
         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
         GPIO_Init(GPIOA, &GPIO_InitStructure);
         /*Check that HSI oscillator is ready*/
         while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
         RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
         ADC_DeInit(ADC1);
         ADC_InitStructure.ADC_ScanConvMode = ENABLE;
         ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
         ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
         ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
         ADC_InitStructure.ADC_NbrOfConversion = 2;
         ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
         ADC_Init(ADC1, &ADC_InitStructure);
         /*ADC1 regular channel10 configuration*/
         ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 1, ADC_SampleTime_48Cycles);
         ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 2, ADC_SampleTime_48Cycles);
         ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
         //Enable ADC1 DMA
         ADC_DMACmd(ADC1, ENABLE);
         //Enable ADC1
         ADC_Cmd(ADC1, ENABLE);
         /*Wait until the ADC1 is ready*/
         while(ADC_GetFlagStatus(ADC1, ADC_FLAG_ADONS) == RESET);
         /*Start ADC1 Software Conversion*/
         ADC_SoftwareStartConv(ADC1);
复制代码
