#!/bin/bash # 一键部署 LNMP(源码安装版本) menu() { clear echo " ##############‐‐‐‐Menu‐‐‐‐##############" echo "# 1. Install Nginx" echo "# 2. Install MySQL" echo "# 3. Install PHP" echo "# 4. Exit Program" echo " ########################################" } choice() { read -p "Please choice a menu[1‐9]:" select } install_nginx() { id nginx &>/dev/null if [ $? -ne 0 ];then useradd -s /sbin/nologin nginx fi if [ -f nginx‐1.8.0.tar.gz ];then tar -xf nginx‐1.8.0.tar.gz cd nginx‐1.8.0 yum -y install gcc pcre‐devel openssl‐devel zlib‐devel make ./configure ‐‐prefix=/usr/local/nginx ‐‐with‐http_ssl_module make make install ln -s /usr/local/nginx/sbin/nginx /usr/sbin/ cd .. else echo "没有 Nginx 源码包" fi } install_mysql() { yum -y install gcc gcc‐c++ cmake ncurses‐devel perl id mysql &>/dev/null if [ $? -ne 0 ];then useradd -s /sbin/nologin mysql fi if [ -f mysql‐5.6.25.tar.gz ];then tar -xf mysql‐5.6.25.tar.gz cd mysql‐5.6.25 cmake . make make install /usr/local/mysql/scripts/mysql_install_db ‐‐user=mysql ‐‐datadir=/usr/local/mysql/data/ ‐‐basedir=/usr/local/mysql/ chown -R root.mysql /usr/local/mysql chown -R mysql /usr/local/mysql/data /bin/cp -f /usr/local/mysql/support‐files/mysql.server /etc/init.d/mysqld chmod +x /etc/init.d/mysqld /bin/cp -f /usr/local/mysql/support‐files/my‐default.cnf /etc/my.cnf echo "/usr/local/mysql/lib/" >> /etc/ld.so.conf ldconfig echo 'PATH=\$PATH:/usr/local/mysql/bin/' >> /etc/profile export PATH else echo "没有 mysql 源码包" exit fi } install_php() { #安装 php 时没有指定启动哪些模块功能,如果的用户可以根据实际情况自行添加额外功能如‐‐with‐gd 等 yum -y install gcc libxml2‐devel if [ -f mhash‐0.9.9.9.tar.gz ];then tar -xf mhash‐0.9.9.9.tar.gz cd mhash‐0.9.9.9 ./configure make make install cd .. if [ ! ‐f /usr/lib/libmhash.so ];then ln -s /usr/local/lib/libmhash.so /usr/lib/ fi ldconfig else echo "没有 mhash 源码包文件" exit fi if [ -f libmcrypt‐2.5.8.tar.gz ];then tar -xf libmcrypt‐2.5.8.tar.gz cd libmcrypt‐2.5.8 ./configure make make install cd .. if [ ! -f /usr/lib/libmcrypt.so ];then ln -s /usr/local/lib/libmcrypt.so /usr/lib/ fi ldconfig else echo "没有 libmcrypt 源码包文件" exit fi if [ -f php‐5.4.24.tar.gz ];then tar -xf php‐5.4.24.tar.gz cd php‐5.4.24 ./configure ‐‐prefix=/usr/local/php5 ‐‐with‐mysql=/usr/local/mysql ‐‐enable‐fpm ‐‐ enable‐mbstring ‐‐with‐mcrypt ‐‐with‐mhash ‐‐with‐config‐file‐path=/usr/local/php5/etc ‐‐with‐ mysqli=/usr/local/mysql/bin/mysql_config make && make install /bin/cp -f php.ini‐production /usr/local/php5/etc/php.ini /bin/cp -f /usr/local/php5/etc/php‐fpm.conf.default /usr/local/php5/etc/php‐fpm.conf cd .. else echo "没有 php 源码包文件" exit fi } while : do menu choice case $select in 1) install_nginx ;; 2) install_mysql ;; 3) install_php ;; 4) exit ;; *) echo Sorry! esac done
收藏0 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
308
2692
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
