GD32F103收发485通讯不进中断,收怎么也不行中断
1159|0
Aist2018|  楼主 | 2023-12-25 13:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* enable USART and GPIOA clock */
    rcu_periph_clock_enable(RCU_GPIOB);
    rcu_periph_clock_enable(RCU_USART2);
    gpio_pin_remap_config( GPIO_USART2_PARTIAL_REMAP,ENABLE); //引脚重映射
                gpio_init(GPIOB, GPIO_MODE_OUT_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_1);
                gpio_bit_reset(GPIOB, GPIO_PIN_1);
    /* configure USART2 Tx as alternate function push-pull */
    gpio_init(GPIOB, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_10);
    /* configure USART2 Rx as alternate function push-pull */
    gpio_init(GPIOB, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_11);
void initUART() {
  /* USART interrupt configuration */
        nvic_priority_group_set(NVIC_PRIGROUP_PRE1_SUB3);
  nvic_irq_enable(USART2_IRQn, 1, 1);
  /* configure COM0 */
  //gd_eval_com_init(EVAL_COM0);
  usart_baudrate_set(USART2, 115200U);
        usart_parity_config(USART2, USART_PM_NONE);//无奇偶检验
                usart_word_length_set(USART2, USART_WL_8BIT);//8位数据
                usart_stop_bit_set(USART2, USART_STB_1BIT);//一个停止位
                usart_hardware_flow_rts_config(USART2,USART_RTS_DISABLE);//无硬件数据流
          usart_hardware_flow_cts_config(USART2, USART_CTS_DISABLE);  // 硬件流控制CTS
    usart_receive_config(USART2, USART_RECEIVE_ENABLE);//串口接收
    usart_transmit_config(USART2, USART_TRANSMIT_ENABLE);//串口发送
        //usart_halfduplex_enable(USART2);
  usart_interrupt_enable(USART2, USART_INT_RBNE);
        usart_enable(USART2);
void UART2_IRQHandler(void) {
    static int dataLen = 0;
          dataRev = 0x11;
          if(SET == usart_interrupt_flag_get(USART2, USART_INT_FLAG_TBE)){
                          usart_interrupt_flag_clear(USART2,USART_INT_FLAG_TBE);
        /* transmit data */
        usart_data_transmit(USART2, txbuffer[txcount++]);
        if(txcount == tx_size){
            usart_interrupt_disable(USART2, USART_INT_TBE);
    if((SET == usart_interrupt_flag_get(USART2, USART_INT_FLAG_RBNE))||(SET == usart_interrupt_flag_get(USART2, USART_INT_FLAG_RBNE_ORERR))) {
        dataRev = usart_data_receive(USART2);
                          usart_interrupt_flag_clear(USART2,USART_INT_FLAG_RBNE);
