| 在Normal/System Reset模式下swD连接不上目标板时,我们可以尝试换个连接模式,比如Connect Under Reset,或者换个复位模式,比如Hardware Reset 。
 -Debug
 Connect & Reset Options
 Connect:under Reset        Reset        HW RESET
 Reset after Connect        Autodetect
 MDK        HW RESET        SYSRESETREQ
 VECTRESET
 Reset
 System (default) System (default) Core
 In        Software        Hardware        IAR
 Connect during reset
 SWD        Default        Specify
 Connection Setup        Mode Setup
 Interface;        SWD        SW4STM32-        Reset Mode:        Connect under reset
 Frequency:        4 MHz        ☑Enable de Hardware reset        Connect under reset
 Stop watc Software system reset
 如果说借助STLINK,即使使用Connect Under Reset或Hardware Reset方式还连接不上呢?我们可以查看下STLINK的NRST脚与目标板上的MCU的NRST脚是否相连了。如果是nucleo板的话,还需确认下跳线SB12是否为连接状态
