[开发工具] keil v5.15编译总是提示有两个错误,内容如下
782|10
 楼主| jcky001 发表于 2024-1-4 09:31 | 显示全部楼层 |阅读模式
那个高手给看看,keil无法编译,谢谢了。
错误提示如下:
*** Using Compiler 'V5.05 update 2 (build 169)', folder: 'C:Keil_v5ARMARMCCBin'
Rebuild target 'STM32L476RG_NUCLEO'
compiling system_stm32l4xx.c...
Error: C9511E: Product definition file was not found. The following paths were searched:
- C:Keil_v5ARMARMCCBinmdk_cm_pro.elmap
- C:Keil_v5ARMARMCCBin....swmappingsmdk_cm_pro.elmap
- C:Keil_v5ARMARMCCBin......swmappingsmdk_cm_pro.elmap
- C:Keil_v5ARMARMCCBin..swmappingsmdk_cm_pro.elmap
Error: C9545E: Info key CT.ProductName could not be found in product definition C:Keil_v5ARMARMCCswmappingsarmcompiler.elmap
Product: unknown
Component: ARM Compiler 5.05 update 2 (build 169)
Tool: ArmCC [4d0f38]
compiling stm32l4xx_nucleo.c...
Product: unknown
compiling main.c...
Product: unknown
compiling stm32l4xx_it.c...
Product: unknown
compiling stm32l4xx_hal_gpio.c...
Product: unknown
compiling stm32l4xx_hal.c...
Product: unknown
compiling stm32l4xx_hal_cortex.c...
Product: unknown
compiling stm32l4xx_hal_pwr_ex.c...
Product: unknown
compiling stm32l4xx_hal_rcc_ex.c...
Product: unknown
compiling stm32l4xx_hal_pwr.c...
Product: unknown
compiling stm32l4xx_hal_rcc.c...
Product: unknown
assembling startup_stm32l476xx.s...
startup_stm32l476xx.s: Error: A9511E: Product definition file was not found. The following paths were searched:
startup_stm32l476xx.s:  - C:Keil_v5ARMARMCCBinmdk_cm_pro.elmap
startup_stm32l476xx.s:  - C:Keil_v5ARMARMCCBin....swmappingsmdk_cm_pro.elmap
startup_stm32l476xx.s:  - C:Keil_v5ARMARMCCBin......swmappingsmdk_cm_pro.elmap
startup_stm32l476xx.s:  - C:Keil_v5ARMARMCCBin..swmappingsmdk_cm_pro.elmap
startup_stm32l476xx.s: Error: A9545E: Info key CT.ProductName could not be found in product definition C:Keil_v5ARMARMCCswmappingsarmcompiler.elmap
startup_stm32l476xx.s: Product: unknown
startup_stm32l476xx.s: Component: ARM Compiler 5.05 update 2 (build 169)
startup_stm32l476xx.s: Tool: ArmAsm [4d0f2f]
"STM32L476RG_NUCLEOSTM32L476RG_NUCLEO.axf" - 2 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed:  00:00:01
一只眠羊 发表于 2024-1-15 15:16 | 显示全部楼层
有点像你的编译链的问题
在曼谷的春 发表于 2024-1-15 18:00 | 显示全部楼层
你怎么做的?是新建工程导致的么?
月亮一键变蓝 发表于 2024-1-15 20:00 | 显示全部楼层
提示是CT.ProductName没找到?
我吃小朋友 发表于 2024-1-15 22:00 | 显示全部楼层
不懂,这大概还是配置的问题,你哪里配置没搞对
未说出口的像你 发表于 2024-1-16 01:00 | 显示全部楼层
建议楼主可以直接找个例程,编译通过之后,在其基础上进行修改
温室雏菊 发表于 2024-1-16 03:00 | 显示全部楼层
你之前的keil能编译其他的工程吗?
白马过平川 发表于 2024-1-16 05:00 | 显示全部楼层
像是你的编译链不行,而且路径好像有问题
西洲 发表于 2024-1-16 09:00 | 显示全部楼层
你用的keil5.15啊?不是很稳定啊,你用最新的keil多好
捧一束彼岸花 发表于 2024-1-16 11:00 | 显示全部楼层
你用cubemx直接生成一个工程,试试能否编译
将爱藏于深海 发表于 2024-1-16 15:00 | 显示全部楼层
是不是没添加这些库函数啊?所以编译报错
