GD32F103驱动电机,电机不转
2156|23
 楼主| Aist2018 发表于 2024-1-5 13:25 | 显示全部楼层 |阅读模式
GD32F103驱动电机,电机不转,看波形有PWM信号。
  1. void timer2_config(void)
  3.     /* -----------------------------------------------------------------------
  4.     TIMER1 configuration: generate 3 PWM signals with 3 different duty cycles:
  5.     TIMER1CLK = SystemCoreClock / 108 = 1MHz
  6.     TIMER1 channel1 duty cycle = (4000/ 16000)* 100  = 25%
  7.     TIMER1 channel2 duty cycle = (8000/ 16000)* 100  = 50%
  8.     TIMER1 channel3 duty cycle = (12000/ 16000)* 100 = 75%
  9.     ----------------------------------------------------------------------- */
  10.     timer_oc_parameter_struct timer_ocintpara;
  11.     timer_parameter_struct timer_initpara;
  12.     rcu_periph_clock_enable(TIMER2);
  13.     timer_deinit(TIMER2);
  14.           //timer_internal_clock_config(TIMER2);
  15.     /* TIMER1 configuration */
  16.     timer_initpara.prescaler         = 71999;
  17.     timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
  18.     timer_initpara.counterdirection  = TIMER_COUNTER_UP;
  19.     timer_initpara.period            = 15999;
  20.     timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
  21.     timer_initpara.repetitioncounter = 0;
  22.     timer_init(TIMER2,&timer_initpara);
  23.     /* CH1,CH2 and CH3 configuration in PWM mode1 */
  24.     timer_ocintpara.ocpolarity   = TIMER_OC_POLARITY_HIGH;
  25.     timer_ocintpara.outputstate  = TIMER_CCX_ENABLE;
  26.     timer_ocintpara.ocnpolarity  = TIMER_OCN_POLARITY_HIGH;
  27.     timer_ocintpara.outputnstate = TIMER_CCXN_DISABLE;
  28.     timer_ocintpara.ocidlestate  = TIMER_OC_IDLE_STATE_LOW;
  29.     timer_ocintpara.ocnidlestate = TIMER_OCN_IDLE_STATE_LOW;
  30.     timer_channel_output_config(TIMER2,TIMER_CH_0,&timer_ocintpara);
  31.                 timer_channel_output_config(TIMER2,TIMER_CH_1,&timer_ocintpara);
  32.     /* CH1 configuration in PWM mode1,duty cycle 25% */
  33.     timer_channel_output_pulse_value_config(TIMER2,TIMER_CH_0,11999);
  34.     timer_channel_output_mode_config(TIMER2,TIMER_CH_0,TIMER_OC_MODE_PWM0);
  35.     timer_channel_output_shadow_config(TIMER2,TIMER_CH_0,TIMER_OC_SHADOW_DISABLE);
  36.
  37.                 /* CH2 configuration in PWM mode1,duty cycle 25% */
  38.     timer_channel_output_pulse_value_config(TIMER2,TIMER_CH_1,11999);
  39.     timer_channel_output_mode_config(TIMER2,TIMER_CH_1,TIMER_OC_MODE_PWM0);
  40.     timer_channel_output_shadow_config(TIMER2,TIMER_CH_1,TIMER_OC_SHADOW_DISABLE);
  41.     /* auto-reload preload enable */
  42.     timer_auto_reload_shadow_enable(TIMER2);
  43.     /* auto-reload preload enable */
  44.     timer_enable(TIMER2);
  45. }
初始化GPIO
  1. rcu_periph_clock_enable(RCU_GPIOC);
  2.     rcu_periph_clock_enable(RCU_AF);
  3.     /*Configure PA1 PA2 PA3(TIMER1 CH1 CH2 CH3) as alternate function*/
  4.                 gpio_pin_remap_config( GPIO_TIMER2_FULL_REMAP,ENABLE); //引脚重映射
  5.     gpio_init(GPIOC, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
  6.     gpio_init(GPIOC, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_7);
 楼主| Aist2018 发表于 2024-1-5 13:26 | 显示全部楼层
SystemCoreClock 是 72MHZ
 楼主| Aist2018 发表于 2024-1-5 14:29 | 显示全部楼层
timer_initpara.prescaler         = 71;也不行,设的是71
储小勇_526 发表于 2024-1-5 16:06 | 显示全部楼层
你都有PWM波了,是不是硬件有问题?
coody 发表于 2024-1-5 18:41 | 显示全部楼层
PWM有信号,示波器测量驱动输出有信号吗?
GlenX 发表于 2024-1-7 16:54 | 显示全部楼层
1.检查去电机驱动的GND是否连接?
2.检查电机驱动模块的电源是否正常
3.电机的A-A\B-B是否结成了AB\-A-B,
1.检查去电机驱动的GND是否连接?
2.检查电机驱动模块的电源是否正常
chenqianqian 发表于 2024-1-8 08:10 来自手机 | 显示全部楼层
PWM信号是否正确?
mbutterfly 发表于 2024-1-8 09:35 | 显示全部楼层
我用普通光耦加MOS管的方式,居然200HZ,占空比都不是1:1了,变成三分之一了。而单片机出去的PWM是1:1的。之后赶紧改成了高速光耦,出来的就对了。
 楼主| Aist2018 发表于 2024-1-8 10:43 | 显示全部楼层
  16.     timer_initpara.prescaler         = 71;
  33.     timer_channel_output_pulse_value_config(TIMER2,TIMER_CH_0,7999);
  34.     timer_channel_output_mode_config(TIMER2,TIMER_CH_0,TIMER_OC_MODE_PWM1);
  36.
  38.     timer_channel_output_pulse_value_config(TIMER2,TIMER_CH_1,7999);
  39.     timer_channel_output_mode_config(TIMER2,TIMER_CH_1,TIMER_OC_MODE_PWM1);
  45. }
这是全部设置代码,SystemCoreClock 是 72MHZ,用KEIL软件仿真逻辑分析看GPIOC6 GPIOC7引脚没有产生脉冲方波,抱歉前面我说错了这样看PWM输出没有产生。
 楼主| Aist2018 发表于 2024-1-8 11:30 | 显示全部楼层
  1. void  initGPIO(void)  {
  2.     //EINT_Config_T eintConfig;
  3.     rcu_periph_clock_enable(RCU_GPIOA);
  4.     rcu_periph_clock_enable(RCU_AF);
  5.     /*configure PA6 (TIMER2 CH0) as alternate function*/
  6.     gpio_init(GPIOA, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_8);
  7.     gpio_init(GPIOA, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_9);
  8.     gpio_init(GPIOA, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_4);
  9.
  10.
  11.     /* Configure GPIO pin used as EINT Line */
  12.           *(volatile uint32_t  *)AFIO_EXTISS1 = 0xFFF0;
  13.     //SYSCFG_EINTLine(SYSCFG_PORT_GPIOA, SYSCFG_PIN_4);
  14.     /* Configure Button exit line */
  15.     //eintConfig.line    =  EINT_LINE4;
  16.     //eintConfig.lineCmd =  ENABLE;
  17.     //eintConfig.mode    =  EINT_MODE_INTERRUPT;
  18.     //eintConfig.trigger =  EINT_TRIGGER_FALLING;
  19.     //EINT_Config(&eintConfig);
  20.                 exti_init(EXTI_4,EXTI_INTERRUPT,EXTI_TRIG_FALLING);
  21.     //NVIC_EnableIRQRequest(EXTI4_IRQn, 0x0f);//使能GPIO中断
  22.                 nvic_irq_enable(EXTI4_IRQn, 0, 0);
  23.     rcu_periph_clock_enable(RCU_GPIOC);
  24.     rcu_periph_clock_enable(RCU_AF);
  25.     /*Configure PA1 PA2 PA3(TIMER1 CH1 CH2 CH3) as alternate function*/
  26.                 gpio_pin_remap_config( GPIO_TIMER2_FULL_REMAP,ENABLE); //引脚重映射
  27.     gpio_init(GPIOC, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
  28.     gpio_init(GPIOC, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_7);
  29.
  30.     //GPIO_Config_T gpioConfig;
  31.     //USART_Config_T usartConfigStruct;
  32.     /* enable USART and GPIOA clock */
  33.     rcu_periph_clock_enable(RCU_GPIOB);
  34.     rcu_periph_clock_enable(RCU_USART2);
  35.
  36.     //gpio_pin_remap_config( GPIO_USART2_PARTIAL_REMAP,ENABLE); //引脚重映射
  37.                 *(volatile uint32_t  *)AFIO_PCF0 &= 0xFFFFFFCF;
  38.                 gpio_init(GPIOB, GPIO_MODE_OUT_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_1);
  39.                 gpio_bit_reset(GPIOB, GPIO_PIN_1);
  40.     /* configure USART2 Tx as alternate function push-pull */
  41.     gpio_init(GPIOB, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_10);
  42.     /* configure USART2 Rx as alternate function push-pull */
  43.     gpio_init(GPIOB, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_11);
  44.     //  初始化  GPIOB  为旋转编码器输入
  45.     gpio_init(GPIOB, GPIO_MODE_IPU, GPIO_OSPEED_50MHZ, GPIO_PIN_12);
  46.     gpio_init(GPIOB, GPIO_MODE_IPU, GPIO_OSPEED_50MHZ, GPIO_PIN_13);
  47.     gpio_init(GPIOB, GPIO_MODE_IPU, GPIO_OSPEED_50MHZ, GPIO_PIN_14);
  48.     gpio_init(GPIOB, GPIO_MODE_IPU, GPIO_OSPEED_50MHZ, GPIO_PIN_15);
  49.     gpio_init(GPIOC, GPIO_MODE_IPU, GPIO_OSPEED_50MHZ, GPIO_PIN_8);
  50.     gpio_init(GPIOC, GPIO_MODE_IPU, GPIO_OSPEED_50MHZ, GPIO_PIN_9);
  51.     gpio_init(GPIOC, GPIO_MODE_IPU, GPIO_OSPEED_50MHZ, GPIO_PIN_10);
  52.     gpio_init(GPIOC, GPIO_MODE_IPU, GPIO_OSPEED_50MHZ, GPIO_PIN_11);
  53. }
这是全部GPIO配置
 楼主| Aist2018 发表于 2024-1-8 12:06 | 显示全部楼层
debug参数-pSTM32F103VB      dialog dll 用 DARMSTM.DLL   TARMSTM.DLL,  这样仿真能看GD32F103的GPIOC引脚脉冲吧?不用这个设置连GPIO引脚再logic analyzer里都看不到。
hjl2832 发表于 2024-1-8 12:32 | 显示全部楼层
逻辑仿真?做研发的公司不会穷到连示波器都没一个了吧。。。。
hjl2832 发表于 2024-1-8 12:33 | 显示全部楼层
实在不行,用万用表量也能知道有没有PWM啊,调整PWM的占空比,这时万用表量出来的IO电压是有变化的
 楼主| Aist2018 发表于 2024-1-8 12:42 | 显示全部楼层
我先仿真看看代码输出的PWM波形对不对,在GPIOC的6 7引脚上, 结果没看到脉冲方波
 楼主| Aist2018 发表于 2024-1-8 13:18 | 显示全部楼层
代码里
下面还有
看手册寄存器11,10位都是1 ,应该没问题啊,是设置11:完全开启重映射功能(TIMER2_CH0 / PC6,TIMER2_CH1 /
 楼主| Aist2018 发表于 2024-1-9 10:33 | 显示全部楼层
运行代码观察寄存器值,在PWM输出模式下,如果CNT寄存器的值一直为0且没有增长到占空比,这应该是不正常的现象吧?我已经使能了TIMER2,请看上面代码,为什么CNT寄存器值一直是0不变化呢?
xdqfc 发表于 2024-1-9 10:54 | 显示全部楼层
运行代码观察寄存器值,在PWM输出模式下,如果CNT寄存器的值一直为0且没有增长到占空比,这应该是不正常的 ...
仿真的时候,把TIME2的相关寄存器配置的截图发出来看看,一般计数器的值应该是变化的,你这个配置连计数器都不变化,已经很不正常了。
 楼主| Aist2018 发表于 2024-1-9 12:32 | 显示全部楼层
 楼主| Aist2018 发表于 2024-1-9 12:35 | 显示全部楼层
你看代码在运行,两个引脚一直低电平,CNT一直是0不变化。
