[STM32MP1] 【STM32MP135F-DK测评】官方SDK编译环境搭建体验
1549|2
 楼主| dql2015 发表于 2024-1-16 21:00 | 显示全部楼层 |阅读模式
SDK包含了构建OpenSTLinux所需的交叉编译工具链和库。
官方教程地址https://wiki.stmicroelectronics.cn/stm32mpu/wiki/Getting_started/STM32MP1_boards/STM32MP135x-DK/Develop_on_Arm%C2%AE_Cortex%C2%AE-A7/Install_the_SDK
首先安装工具:
  1. sudo apt-get update
  2. sudo apt-get install gawk wget git diffstat unzip texinfo gcc-multilib  chrpath socat cpio python3 python3-pip python3-pexpect
额外设置
  1. echo 'options mmc_block perdev_minors=16' > /tmp/mmc_block.conf
  2. sudo mv /tmp/mmc_block.conf /etc/modprobe.d/mmc_block.conf
下载SDK
下载得到en.SDK-x86_64-stm32mp1-openstlinux-6.1-yocto-mickledore-mp1-v23.06.21.tar.gz
解压SDK
  1. cd $HOME/STM32MPU_workspace/tmp
  2. tar xvf en.SDK-x86_64-stm32mp1-openstlinux-6.1-yocto-mickledore-mp1-v23.06.21.tar.gz
创建STM32MP1 Developer Package SDK目录,并执行SDK安装脚本
  1. mkdir -p $HOME/STM32MPU_workspace/STM32MP1-Ecosystem-v5.0.0/Developer-Package/SDK
  2. chmod +x stm32mp1-openstlinux-6.1-yocto-mickledore-mp1-v23.06.21/sdk/st-image-weston-openstlinux-weston-stm32mp1-x86_64-toolchain-4.2.1-openstlinux-6.1-yocto-mickledore-mp1-v23.06.21.sh
  3. ./stm32mp1-openstlinux-6.1-yocto-mickledore-mp1-v23.06.21/sdk/st-image-weston-openstlinux-weston-stm32mp1-x86_64-toolchain-4.2.1-openstlinux-6.1-yocto-mickledore-mp1-v23.06.21.sh -d <working directory absolute path>/Developer-Package/SDK
安装成功后显示的信息如下:
  1. 1-x86_64-toolchain-4.2.1-openstlinux-6.1-yocto-mickledore-mp1-v23.06.21.sh -d /home/ubuntu/STM32MPU_workspace/STM32MP1-Ecosystem-v5.0.0/Developer-Package/SDK
  2. ST OpenSTLinux - Weston - (A Yocto Project Based Distro) SDK installer version 4.2.1-openstlinux-6.1-yocto-mickledore-mp1-v23.06.21
  3. ===================================================================================================================================
  4. You are about to install the SDK to "/home/ubuntu/STM32MPU_workspace/STM32MP1-Ecosystem-v5.0.0/Developer-Package/SDK". Proceed [Y/n]? Y
  5. Extracting SDK........................................................................................................................................................................................done
  6. Setting it up...done
  7. SDK has been successfully set up and is ready to be used.
  8. Each time you wish to use the SDK in a new shell session, you need to source the environment setup script e.g.
  9. $ . /home/ubuntu/STM32MPU_workspace/STM32MP1-Ecosystem-v5.0.0/Developer-Package/SDK/environment-setup-cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi
每次打开终端使用SDK前执行命令加载环境变量
  1. <blockquote> cd $HOME/STM32MPU_workspace/STM32MP1-Ecosystem-v5.0.0/Developer-Package
检查是否加载成功,查看架构
  1. echo $ARCH
检查交叉编译工具链前缀
  1. echo $CROSS_COMPILE
检查编译器版本
  1. $CC --version
检查SDK版本
  1. echo $OECORE_SDK_VERSION
MessageRing 发表于 2024-1-27 21:19 | 显示全部楼层
新手容易入门吗?
szt1993 发表于 2024-1-28 12:08 | 显示全部楼层
有关于新手入门的教程嘛
