[技术讨论] 耐压18V,2A,高效率同步降压芯片ZCC1496替代MP1496
394|0
 楼主| HPT-Lt 发表于 2024-1-19 15:01 | 显示全部楼层 |阅读模式
FEATURES
High Efficiency: Up to 98%
500KHz Frequency Operation
2A Output Current
No Schottky Diode Required
4.0V to 18V Input Voltage Range
0.6V Reference
Slope Compensated Current Mode
Control for Excellent Line and
Load Transient Response
Integrated internal compensation
Stable with Low ESR Ceramic Output Capacitors
Over Current Protection with Hiccup-Mode
Thermal Shutdown
Inrush Current Limit and Soft Start
Available in SOT23-6 Package
-40°C
APPLICATIONS
Distributed Power Systems
Digital Set Top Boxes
Flat Panel Television and Monitors
Wireless and DSL Modems
Notebook Computer
GENERAL DESCRIPTION
The ZCC1496 is a fully integrated, high efficiency 2A synchronous rectified step down converter. The ZCC1496 operates at high efficiency over a wide output current load range.
This device offers two operation modes, PWM control and PFM Mode switching control, which allows a high efficiency over the wider range of the load. The ZCC1496 requires a minimum number of readily available standard external components and is available in a 6-pin SOT23-6 compliant package.
