ZCC6688-3A 开关型同步降压多节锂电池充电芯片
273|0
HPT-Lt|  楼主 | 2024-1-22 14:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
General Description
The ZCC6688 is a 3A Li-Ion battery charger. It utilizesa 500KHz synchronous buck converter topology toreduce power dissipation during charging. Low powerdissipation, an internal MOSFET allow a physicallysmall charger that can be embedded in a wide rangeof handheld applications. The ZCC6688 includescomplete charge termination circuitry, automaticrecharge and a ±1% 4.2V /8.4V float voltage.
Battery charge current, charge timeout and end-of- charge indication parameters are set with
externalcomponents. Additional features include shorted celldetection; temperature qualified charging andovervoltage protection. The ZCC6688 is available in alow profile ESOP10 package.
Features
Input voltage range 4V~10V
Dynamic input current allocation for maximumcharging rate
3.0A Maximum Charge Current
No External MOSFETs and Blocking DiodeRequired
Efficiency up to 90%
Constant-Current/Constant-Voltage Operationwith Thermal Regulation to Maximize ChargeRate Without Risk of Overheating
Optional Battery Temperature Monitoring Beforeand During Charge Automatic Sleep Mode forLow-Power
Over Current Protection
Consumption Available in ESOP10
RoHS Compliant and 100% Lead (Pb)-Free
Applications
Portable Media Players
Cellular and Smart mobile phone
PDA/DSC
Handheld Battery-Powered Devices
Handheld Computers
Charging Docks and Cradles
