coregen 生成RAM初始化问题,需要解决
2908|4
 楼主| 星星之火红 发表于 2012-5-14 12:44 | 显示全部楼层 |阅读模式
coregen 进行RAM初始化的时候出以下问题,帮忙解决啊。
"Error occurred during initialization of VM
java.lang.Error: java.io.UnsupportedEncodingException: GBK
ERROR:coreutil:576 - An error occurred while running Java. Please examine the console or coregen log file for a specific IP related error.
For more information please search the Xilinx Answers Database for this error: http://www.xilinx.com/support
ERROR:coreutil - An Error occurred during Customization.
ERROR:coreutil:308 - If the error occurred during generation, the problem may be due to a failure occurring in xst. Please check the xst log file - available in the working directory.
Error found during generation."
GoldSunMonkey 发表于 2012-5-14 12:45 | 显示全部楼层
这个问题简单:
在环境变量里面添加:
JAVA_TOOL_OPTIONS  =   -Dfile.encoding=UTF8
评分
参与人数 1威望 +1 收起 理由
xuehua230 + 1
查看全部评分
 楼主| 星星之火红 发表于 2012-5-14 12:47 | 显示全部楼层
:kiss:
猴哥,解决了。谢谢啦。
bairan168 发表于 2012-5-14 16:08 | 显示全部楼层
猴哥就是不一样。
zy7598865 发表于 2012-5-17 15:13 | 显示全部楼层
这个环境变量是在哪里添加,学习学习
