[STM32F1] stm32f103c8t6用spi协议操作sd卡并给电脑串口发送消息
691|1
 楼主| tpgf 发表于 2024-2-28 08:17 | 显示全部楼层 |阅读模式
stm32cubemx设计图如下:
接线如下:
main.c代码如下:
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * Copyright (c) 2024 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "fatfs.h"
#include "spi.h"
#include "usart.h"
#include "gpio.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "stdio.h"
#include "string.h"
//SPI_HandleTypeDef hspi1;
FATFS fs;
FATFS *pfs;
FIL fil;
FRESULT fres;
DWORD fre_clust;
DIR dir;
static FILINFO fno;
uint32_t total, freez;
char buffer[100];
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_SPI1_Init();
  MX_FATFS_Init();
  MX_USART1_UART_Init();
  /* USER CODE BEGIN 2 */
        /* Mount SD Card */
  if(f_mount(&fs, "", 0) != FR_OK)
    printf("挂载失败 \r\n");
  /* Open file to write */
  if(f_open(&fil, "test1.txt", FA_OPEN_ALWAYS | FA_READ | FA_WRITE) != FR_OK)
    printf("打开文件失败 \r\n");
  /* Check free space */
  if(f_getfree("", &fre_clust, &pfs) != FR_OK)
    printf("计算空间失败 \r\n");
  total = (uint32_t)((pfs->n_fatent - 2) * pfs->csize * 0.5);
  freez = (uint32_t)(fre_clust * pfs->csize * 0.5);
  /* Free space is less than 1kb */
  if(freez < 1)
     printf("SD满了 \r\n");
  /* Writing text */
  f_puts("hello world \n", &fil);
  f_puts("SD卡获取根目录文件成功!!!", &fil);
  /* Close file */
  if(f_close(&fil) != FR_OK)
    printf("关闭文件失败 \r\n");
        /* Open file to read */
  if(f_open(&fil, "test1.txt", FA_READ) != FR_OK)
  while(f_gets(buffer, sizeof(buffer), &fil))
    printf("%s \r\n", buffer);
  /* Close file */
        /* Get tree list */
        FRESULT res;
        if(f_opendir(&dir,"") != FR_OK){
    printf("打开根目录失败 \r\n");
        }else{
                printf("打开根目录成功 \r\n");
                for(;;){
                        res = f_readdir(&dir, &fno); //读取目录,返回状态 和 文件信息的指针
                        if(res != FR_OK || fno.fname[0] == 0)
                                break; //若打开失败 或 到结尾,则退出
                        if(fno.fattrib & AM_DIR) //是目录
                                printf("是目录%s \r\n",fno.fname);
                                if(res != FR_OK) break; //打开失败则退出
                        }else
                                printf("是文件:%s \r\n",fno.fname); //是文件
  /* Unmount SDCARD */
  if(f_mount(NULL, "", 1) != FR_OK)
    printf("解除挂载文件失败 \r\n");
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
                printf("test123123 \r\n");
                HAL_Delay(2000);
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI_DIV2;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL16;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV2;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
原文链接:https://blog.csdn.net/kukunet/article/details/135921672
xuanhuanzi 发表于 2024-2-29 22:38 | 显示全部楼层
SD卡读写吗?
