[开发工具] OpenOCD 的 STM32F1 解锁与下载脚本
723|1
 楼主| tifmill 发表于 2024-2-28 23:00 | 显示全部楼层 |阅读模式
解锁
  1. #!/usr/bin/env bash
  2. case "$1" in
  3.    "-dap" | "dap-link")
  4.        echo "You choose the DAP-Link"
  5.        INTERFACE=cmsis-dap.cfg
  6.    ;;
  7.    "-st" | "st-link")
  8.        echo "You choose the ST-Link V2"
  9.        INTERFACE=stlink-v2.cfg
  10.    ;;
  11.    "-j" | "j-link")
  12.        echo "You choose the J-Link"
  13.        INTERFACE=jlink.cfg
  14.    ;;
  15.     "-h" | "help" | *)
  16.         echo -e  "$0 [command] \n \
  17.         dap-link    | -dap  Unlock by DAP-Link\n \
  18.         st-link     | -st   Unlock by ST-Link V2\n \
  19.         j-link      | -j    Unlock by J-Link\n \
  20.         help        | -h    Show the help\n"
  21.         exit
  22.    ;;
  23. esac
  24. SOURCE=/usr/share/openocd/
  25. INTERFACE_CFG=${SOURCE}scripts/interface/${INTERFACE}
  26. TARGET_CFG=${SOURCE}scripts/target/stm32f1x.cfg
  27. PWD=$(dirname "$(readlink -f "$0")")
  28. echo "开始连接"
  29. openocd -f ${INTERFACE_CFG}                     \
  30.         -f ${TARGET_CFG}                        \
  31.         -c "init"                               \
  32.         -c "halt"                               \
  33.         -c "stm32f1x unlock 0"                  \
  34.         -c "reset halt"                         \
  35.         -c "exit"
下载
  2. case "$1" in
  6.    ;;
  10.    ;;
  14.    ;;
  17.         dap-link    | -dap  Download by DAP-Link\n \
  18.         st-link     | -st   Download by ST-Link V2\n \
  19.         j-link      | -j    Download by J-Link\n \
  21.         exit
  22.    ;;
  23. esac
  25. INTERFACE_CFG=${SOURCE}scripts/interface/$INTERFACE
  28. # BIN=${PWD}/build/LED.bin
  29. HEX=${PWD}/build/LED.hex
  30. echo "开始连接"
  31. openocd -f ${INTERFACE_CFG}                     \
  32.         -f ${TARGET_CFG}                        \
  33.         -c "init"                               \
  34.         -c "reset"                              \
  35.         -c "halt"                               \
  36.         -c "flash erase_sector 0 0 last"        \
  37.         -c "flash write_image erase ${HEX}"     \
  38.         -c "reset"                              \
  39.         -c "shutdown"
狄克爱老虎油 发表于 2024-2-29 18:36 | 显示全部楼层
openocd怎么配置啊
