ASC8513单双节锂电池充电芯片
2766|0
 楼主| tongxinhk 发表于 2012-5-17 14:13 | 显示全部楼层 |阅读模式
联系电话:18675575810toby
SWITCH-MODE SINGLE CELL LI-ION BATTERY CHARGER
DESCRIPTION
The ASC8513 is a monolithic switching charger for single cell battery, It achieves up to 2.5A charge current with voltage mode PWM step- down (buck) switching architecture.ASC8513 regulates the battery voltage and charge current with CV(constant voltage) and CC(constant current) loops. Fault condition includes thermal shutdown、time out and output short. Other safety features include battery temperature monitoring and charge status indication.
The ASC8513 is available in 14-pin TSSOP package.
APPLICATIONS
● Handheld Products
● Portable Equipment
● Distributed Power Systems
● Portable DVD Players
● Notebook
● Chargers for one cell Lion Batteries
FEATURES
● 100% Maximum Duty Cycle
● 0.5% Charge Voltage Accuracy
● Low 10uA Reverse Battery Drain Current
● Programmable Charge Current Up To 2.5A
● Fixed 400kHz Frequency
Build-in Battery Detection
Suitable For One Cell Li-Ion Batteries
Automatic Battery Recharge
● Soft Start
● Battery Temperature Monitoring
● Thermal Shutdown And Protection
Status Indication
12V Maximum Input Voltage Rating
● Ambient Temperature Range: -20℃~70℃
● 14-Lead TSSOP Package Available
TYPICAL APPLICATION
file:///C:/Users/steven/AppData/Local/Temp/ksohtml/wps_clip_image-18424.png
Figure1.1
Typical Application For 1A Charge Current
file:///C:/Users/steven/AppData/Local/Temp/ksohtml/wps_clip_image-2980.png
Figure2.1
Typical Application For 2A Charge Current
file:///C:/Users/steven/AppData/Local/Temp/ksohtml/wps_clip_image-32363.pngThese devices have limited built-in ESD protection. The leads should be shorted
