[技术问答] ma35d1的串口pdma的scatter-gather接收无法响应。
4364|12
 楼主| classroom 发表于 2024-5-18 20:00 | 显示全部楼层 |阅读模式
#include "com.h"
//linux->uart7 arm->uart9
#define PDMA                   ((PDMA_T *)  PDMA3_BASE)
#define PDMA_TEST_LENGTH        30
void pdma_init(void);
void com_init(void)
        SYS_UnlockReg();
         CLK_SetModuleClock(UART6_MODULE, CLK_CLKSEL2_UART6SEL_HXT, CLK_CLKDIV2_UART6(1));
    CLK_EnableModuleClock(UART6_MODULE);
        CLK_EnableModuleClock(PDMA3_MODULE);
    /* Init I/O Multi-function        */
    /* Set multi-function pins for Debug UART RXD and TXD */
    SYS->GPN_MFPH &= ~(SYS_GPN_MFPH_PN14MFP_Msk | SYS_GPN_MFPH_PN15MFP_Msk);
    SYS->GPN_MFPH |= SYS_GPN_MFPH_PN14MFP_UART6_RXD | SYS_GPN_MFPH_PN15MFP_UART6_TXD;
        SYS_LockReg();
        UART_Open(UART6, 115200);
        pdma_init();
uint32_t g_u32DMAConfig = 0;
typedef struct dma_desc_t
    uint32_t ctl;
    uint32_t src;
    uint32_t dest;
    uint32_t offset;
} DMA_DESC_T;
DMA_DESC_T DMA_DESC[2];
volatile uint8_t rx[PDMA_TEST_LENGTH];
static uint8_t g_u8Tx_Buffer[PDMA_TEST_LENGTH]={1,2,3,4,5,6,7,8};
        UART_PDMA_ENABLE(UART6,UART_INTEN_RXPDMAEN_Msk);
        SYS_ResetModule(PDMA3_RST);
    PDMA_Open(PDMA,1 << 1); // Channel 1 for UART1 RX
    PDMA_SetTransferMode(PDMA,1, PDMA_UART6_RX, TRUE, (uint32_t)&DMA_DESC[0]);
    g_u32DMAConfig = \
                     ((PDMA_TEST_LENGTH/2 -1)<< PDMA_DSCT_CTL_TXCNT_Pos) | /* Transfer count is 1 */ \
                     PDMA_WIDTH_8 |  /* Transfer width is 8 bits(one word) */ \
                     PDMA_SAR_FIX |   /* Source increment size is fixed(no increment) */ \
                     PDMA_DAR_INC |   /* Destination increment size is increment(increment) */ \
                     PDMA_REQ_SINGLE  | /* Transfer type is burst transfer type */ \
                     PDMA_BURST_1 |   /* Burst size is 128. No effect in single transfer type */ \
                                        /* PDMA_TBINTDIS_DISABLE |  Disable transfer done and table empty interrupt */
                     PDMA_OP_SCATTER; /* Operation mode is scatter-gather mode */
        DMA_DESC[0].ctl = g_u32DMAConfig;
    /* Configure source address */
    DMA_DESC[0].src = UART6_BASE; /* Ping-Pong buffer 1 */
    /* Configure destination address */
    DMA_DESC[0].dest = (uint32_t)(&rx[0]);
    /* Configure next descriptor table address */
    DMA_DESC[0].offset = (uint32_t)&DMA_DESC[1]; /* next operation table is table 2 */
        DMA_DESC[1].ctl = g_u32DMAConfig;
    DMA_DESC[1].src = UART6_BASE; /* Ping-Pong buffer 1 */
    DMA_DESC[1].dest = (uint32_t)(&rx[PDMA_TEST_LENGTH/2]);
    DMA_DESC[1].offset = (uint32_t)&DMA_DESC[0]; /* next operation table is table 2 */
        printf("%d %d\r\n",(uint32_t)&DMA_DESC[0],PDMA->CURSCAT[1]);
   /* Enable transfer done interrupt */
    PDMA_EnableInt(PDMA3,1, PDMA_INT_TRANS_DONE);
    NVIC_EnableIRQ(PDMA3_IRQn);
void PDMA3_IRQHandler(void)
    /* Check channel transfer done status */
    if (PDMA_GET_TD_STS(PDMA3) == PDMA_TDSTS_TDIF1_Msk)
        /* When finished a descriptor table then g_u32TransferredCount increases 1 */
pdma_test();
        /* Clear transfer done flag of channel 4 */
        PDMA_CLR_TD_FLAG(PDMA3,PDMA_TDSTS_TDIF1_Msk);
                PDMA_SetTransferCnt(PDMA,1, PDMA_WIDTH_8, PDMA_TEST_LENGTH);
//                printf("%x,pdma ok\r\n",PDMA3->DSCT[1].CTL);
static void SendChar_ToUART(int ch)
    while(UART6->FIFOSTS & UART_FIFOSTS_TXFULL_Msk);
    UART6->DAT = ch;
void pdma_test(void)
        int i;
        for(i=0;i<PDMA_TEST_LENGTH;i++)
                printf("%x ",rx);
        printf("\r\n");
//        SendChar_ToUART('O');
//        SendChar_ToUART('K');
代码参考如上,测试串口6接收DAT寄存器可以读到数据,但是pdma的scatter-gather模式无法自动搬运数据到sram中,无法触发pdma中断。也尝试使用pdma的普通模式,能成功搬运,但是奇怪的是收到的第二到第7字节都是0,第一字节和第8字节后面都是正常,搬运结束也能正常进入pdma中断,但也是有一个问题,只能启动一次,在中断里面清除了中断标记和重新赋值搬运个数,也无法触发第二次pdma接收。串口换了几个,pdma也尝试使用pdma2,最终结果都是一样,感觉这个芯片有bug,忘原厂重视下。
奔跑的牛 发表于 2024-6-7 17:37 | 显示全部楼层
请更新测试例程到最新
两只袜子 发表于 2024-8-20 19:11 | 显示全部楼层
检查硬件连接
jcky001 发表于 2024-8-20 20:00 | 显示全部楼层
检查驱动和固件都是最新版本
cr315 发表于 2024-8-20 23:00 | 显示全部楼层
检查中断是否被使能,以及中断优先级是否设置得当。
雾都浪漫 发表于 2025-8-30 13:52 | 显示全部楼层
检查 PDMA 通道配置,确保 SCATTER 模式使能、描述符链表正确。确认串口波特率匹配,DMA 请求信号有效,中断使能及 NVIC 优先级设置无误。
我趴在云边 发表于 2025-9-16 13:46 | 显示全部楼层
ma35d1 串口 PDMA 的 scatter-gather 接收无响应,可能是描述符链配置有误,需检查地址对齐与终止标志;或 PDMA 通道使能不当,确认关联正确串口;也可能中断向量未正确设置。建议核对手册中描述符格式,单步调试通道状态寄存器,排查触发条件。
牛奶秋刀鱼 发表于 2025-9-23 17:56 | 显示全部楼层
MA35D1 串口 PDMA 的 scatter-gather 接收无响应,可能因:1. 描述符链表配置错误(地址未对齐、长度 / 状态位设置错);2. PDMA 通道使能 / 中断未开启;3. 串口与 PDMA 时钟未使能;4. 内存权限或缓存问题。需检查描述符链结构、寄存器配置,确保 DMA 请求与串口中断正确关联。
玫瑰凋零日记 发表于 2025-10-5 15:02 | 显示全部楼层
检查 MA35D1 串口 PDMA scatter-gather 接收无响应,可从三方面排查:1. 确认 SG 表物理地址正确,描述符链配置无误(如终止位、传输长度);2. 检查 PDMA 通道使能、串口 DMA 模式及中断掩码设置;3. 验证内存对齐,确保缓冲区符合 PDMA 地址对齐要求,必要时用示波器监测 PDMA 请求信号。
热爱浪漫 发表于 2025-10-13 16:31 | 显示全部楼层
检查 MA35D1 串口 PDMA 的 scatter-gather 配置:确认通道链接正确,描述符表地址有效且对齐;使能 PDMA 中断及对应 NVIC 通道;检查串口波特率与 PDMA 时钟匹配;确保描述符链尾标志正确,可单步调试看 PDMA 状态寄存器找错误原因。
我趴在云边 发表于 2025-10-21 11:02 | 显示全部楼层
ma35d1 串口 PDMA 的 scatter-gather 接收无响应,可检查:PDMA 通道配置是否正确关联串口;scatter-gather 链表地址是否对齐、描述符参数(传输长度、内存地址)是否有误;中断使能是否开启,优先级是否冲突;串口波特率、校验位是否匹配,避免数据格式错误导致 PDMA 触发失败。
桃花落满山前 发表于 2025-10-30 15:11 | 显示全部楼层
ma35d1 串口 PDMA 的 scatter-gather 接收无法响应,可能原因:PDMA 通道配置错误,如缓冲区地址、长度未正确设置; scatter-gather 链表结构或描述符参数有误;串口波特率、校验位等与 PDMA 时序不匹配;中断使能未开启。需检查配置寄存器、链表完整性及硬件连接。
热爱浪漫 发表于 2025-11-13 12:33 | 显示全部楼层
排查 MA35D1 串口 PDMA 的 scatter-gather 接收无响应:检查 PDMA 通道配置,确保与串口关联正确;验证 scatter-gather 链表地址有效性,描述符参数(如传输长度、中断使能)是否正确;确认串口波特率、校验位等与 PDMA 同步;排查中断向量表配置,确保 PDMA 中断被使能且服务函数正确。
