[STM32F1] STM32单片机OLED显示
1607|0
 楼主| elsaflower 发表于 2024-5-27 22:00 | 显示全部楼层 |阅读模式
main.c
#include "stm32f10x.h"                  // Device header
#include "Delay.h"
#include "OLED.h"
int main(void)
        OLED_Init();
        OLED_ShowChar(1, 1, 'A');
        OLED_ShowString(1, 3, "HelloWorld!");
        OLED_ShowNum(2, 1, 12345, 5);
        OLED_ShowSignedNum(2, 7, -66, 2);
        OLED_ShowHexNum(3, 1, 0xAA55, 4);
        OLED_ShowBinNum(4, 1, 0xAA55, 16);
        while (1)
LED.C
void LED_Init(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_SetBits(GPIOA, GPIO_Pin_1 | GPIO_Pin_2);
void LED1_ON(void)
        GPIO_ResetBits(GPIOA, GPIO_Pin_1);
void LED1_OFF(void)
        GPIO_SetBits(GPIOA, GPIO_Pin_1);
void LED1_Turn(void)
        if (GPIO_ReadOutputDataBit(GPIOA, GPIO_Pin_1) == 0)
        else
void LED2_ON(void)
        GPIO_ResetBits(GPIOA, GPIO_Pin_2);
void LED2_OFF(void)
        GPIO_SetBits(GPIOA, GPIO_Pin_2);
void LED2_Turn(void)
        if (GPIO_ReadOutputDataBit(GPIOA, GPIO_Pin_2) == 0)
        else
KEY.c
#include "Delay.h"
void Key_Init(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_11;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
uint8_t Key_GetNum(void)
        uint8_t KeyNum = 0;
        if (GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_1) == 0)
                Delay_ms(20);
                while (GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_1) == 0);
                Delay_ms(20);
                KeyNum = 1;
        if (GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_11) == 0)
                Delay_ms(20);
                while (GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_11) == 0);
                Delay_ms(20);
                KeyNum = 2;
        return KeyNum;
OLED.C
#include "OLED_Font.h"
/*引脚配置*/
#define OLED_W_SCL(x)                GPIO_WriteBit(GPIOB, GPIO_Pin_8, (BitAction)(x))
#define OLED_W_SDA(x)                GPIO_WriteBit(GPIOB, GPIO_Pin_9, (BitAction)(x))
/*引脚初始化*/
void OLED_I2C_Init(void)
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
        OLED_W_SCL(1);
        OLED_W_SDA(1);
  * @brief  I2C开始
  * @param  无
  * @retval 无
void OLED_I2C_Start(void)
        OLED_W_SDA(1);
        OLED_W_SCL(1);
        OLED_W_SDA(0);
        OLED_W_SCL(0);
  * @brief  I2C停止
  * @param  无
  * @retval 无
void OLED_I2C_Stop(void)
        OLED_W_SDA(0);
        OLED_W_SCL(1);
        OLED_W_SDA(1);
  * @brief  I2C发送一个字节
  * @param  Byte 要发送的一个字节
  * @retval 无
void OLED_I2C_SendByte(uint8_t Byte)
        uint8_t i;
        for (i = 0; i < 8; i++)
                OLED_W_SDA(Byte & (0x80 >> i));
                OLED_W_SCL(1);
                OLED_W_SCL(0);
        OLED_W_SCL(1);        //额外的一个时钟,不处理应答信号
        OLED_W_SCL(0);
  * @brief  OLED写命令
  * @param  Command 要写入的命令
  * @retval 无
void OLED_WriteCommand(uint8_t Command)
        OLED_I2C_Start();
        OLED_I2C_SendByte(0x78);                //从机地址
        OLED_I2C_SendByte(0x00);                //写命令
        OLED_I2C_SendByte(Command);
        OLED_I2C_Stop();
  * @brief  OLED写数据
  * @param  Data 要写入的数据
  * @retval 无
void OLED_WriteData(uint8_t Data)
        OLED_I2C_Start();
        OLED_I2C_SendByte(0x40);                //写数据
        OLED_I2C_SendByte(Data);
        OLED_I2C_Stop();
  * @brief  OLED设置光标位置
  * @param  Y 以左上角为原点,向下方向的坐标,范围:0~7
  * @param  X 以左上角为原点,向右方向的坐标,范围:0~127
  * @retval 无
void OLED_SetCursor(uint8_t Y, uint8_t X)
        OLED_WriteCommand(0xB0 | Y);                                        //设置Y位置
        OLED_WriteCommand(0x10 | ((X & 0xF0) >> 4));        //设置X位置高4位
        OLED_WriteCommand(0x00 | (X & 0x0F));                        //设置X位置低4位
  * @brief  OLED清屏
  * @param  无
  * @retval 无
void OLED_Clear(void)
        uint8_t i, j;
        for (j = 0; j < 8; j++)
                OLED_SetCursor(j, 0);
                for(i = 0; i < 128; i++)
                        OLED_WriteData(0x00);
  * @brief  OLED显示一个字符
  * @param  Line 行位置,范围:1~4
  * @param  Column 列位置,范围:1~16
  * @param  Char 要显示的一个字符,范围:ASCII可见字符
  * @retval 无
void OLED_ShowChar(uint8_t Line, uint8_t Column, char Char)
        uint8_t i;
        OLED_SetCursor((Line - 1) * 2, (Column - 1) * 8);                //设置光标位置在上半部分
                OLED_WriteData(OLED_F8x16[Char - ' ']);                        //显示上半部分内容
        OLED_SetCursor((Line - 1) * 2 + 1, (Column - 1) * 8);        //设置光标位置在下半部分
                OLED_WriteData(OLED_F8x16[Char - ' '][i + 8]);                //显示下半部分内容
  * @brief  OLED显示字符串
  * @param  Line 起始行位置,范围:1~4
  * @param  Column 起始列位置,范围:1~16
  * @param  String 要显示的字符串,范围:ASCII可见字符
  * @retval 无
void OLED_ShowString(uint8_t Line, uint8_t Column, char *String)
        uint8_t i;
        for (i = 0; String != '\0'; i++)
                OLED_ShowChar(Line, Column + i, String);
  * @brief  OLED次方函数
  * @retval 返回值等于X的Y次方
uint32_t OLED_Pow(uint32_t X, uint32_t Y)
        uint32_t Result = 1;
        while (Y--)
                Result *= X;
        return Result;
  * @brief  OLED显示数字(十进制,正数)
  * @param  Number 要显示的数字,范围:0~4294967295
  * @param  Length 要显示数字的长度,范围:1~10
  * @retval 无
void OLED_ShowNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length)
        uint8_t i;
        for (i = 0; i < Length; i++)
                OLED_ShowChar(Line, Column + i, Number / OLED_Pow(10, Length - i - 1) % 10 + '0');
  * @brief  OLED显示数字(十进制,带符号数)
  * @param  Number 要显示的数字,范围:-2147483648~2147483647
  * @retval 无
void OLED_ShowSignedNum(uint8_t Line, uint8_t Column, int32_t Number, uint8_t Length)
        uint8_t i;
        uint32_t Number1;
        if (Number >= 0)
                OLED_ShowChar(Line, Column, '+');
                Number1 = Number;
        else
                OLED_ShowChar(Line, Column, '-');
                Number1 = -Number;
                OLED_ShowChar(Line, Column + i + 1, Number1 / OLED_Pow(10, Length - i - 1) % 10 + '0');
  * @brief  OLED显示数字(十六进制,正数)
  * @param  Number 要显示的数字,范围:0~0xFFFFFFFF
  * @param  Length 要显示数字的长度,范围:1~8
  * @retval 无
void OLED_ShowHexNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length)
        uint8_t i, SingleNumber;
                SingleNumber = Number / OLED_Pow(16, Length - i - 1) % 16;
                if (SingleNumber < 10)
                        OLED_ShowChar(Line, Column + i, SingleNumber + '0');
                else
                        OLED_ShowChar(Line, Column + i, SingleNumber - 10 + 'A');
  * @brief  OLED显示数字(二进制,正数)
  * @param  Number 要显示的数字,范围:0~1111 1111 1111 1111
  * @param  Length 要显示数字的长度,范围:1~16
  * @retval 无
void OLED_ShowBinNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length)
        uint8_t i;
                OLED_ShowChar(Line, Column + i, Number / OLED_Pow(2, Length - i - 1) % 2 + '0');
  * @brief  OLED初始化
  * @param  无
  * @retval 无
void OLED_Init(void)
        uint32_t i, j;
        for (i = 0; i < 1000; i++)                        //上电延时
                for (j = 0; j < 1000; j++);
        OLED_I2C_Init();                        //端口初始化
        OLED_WriteCommand(0xAE);        //关闭显示
        OLED_WriteCommand(0xD5);        //设置显示时钟分频比/振荡器频率
        OLED_WriteCommand(0x80);
        OLED_WriteCommand(0xA8);        //设置多路复用率
        OLED_WriteCommand(0x3F);
        OLED_WriteCommand(0xD3);        //设置显示偏移
        OLED_WriteCommand(0x00);
        OLED_WriteCommand(0x40);        //设置显示开始行
        OLED_WriteCommand(0xA1);        //设置左右方向,0xA1正常 0xA0左右反置
        OLED_WriteCommand(0xC8);        //设置上下方向,0xC8正常 0xC0上下反置
        OLED_WriteCommand(0xDA);        //设置COM引脚硬件配置
        OLED_WriteCommand(0x12);
        OLED_WriteCommand(0x81);        //设置对比度控制
        OLED_WriteCommand(0xCF);
        OLED_WriteCommand(0xD9);        //设置预充电周期
        OLED_WriteCommand(0xF1);
        OLED_WriteCommand(0xDB);        //设置VCOMH取消选择级别
        OLED_WriteCommand(0x30);
        OLED_WriteCommand(0xA4);        //设置整个显示打开/关闭
        OLED_WriteCommand(0xA6);        //设置正常/倒转显示
        OLED_WriteCommand(0x8D);        //设置充电泵
        OLED_WriteCommand(0x14);
        OLED_WriteCommand(0xAF);        //开启显示
        OLED_Clear();                                //OLED清屏
OLED_Font.h
#ifndef __OLED_FONT_H
#define __OLED_FONT_H
/*OLED字模库,宽8像素,高16像素*/
const uint8_t OLED_F8x16[][16]=
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//  0
        0x00,0x00,0x00,0xF8,0x00,0x00,0x00,0x00,
        0x00,0x00,0x00,0x33,0x30,0x00,0x00,0x00,//! 1
        0x00,0x10,0x0C,0x06,0x10,0x0C,0x06,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//" 2
        0x40,0xC0,0x78,0x40,0xC0,0x78,0x40,0x00,
        0x04,0x3F,0x04,0x04,0x3F,0x04,0x04,0x00,//# 3
        0x00,0x70,0x88,0xFC,0x08,0x30,0x00,0x00,
        0x00,0x18,0x20,0xFF,0x21,0x1E,0x00,0x00,//$ 4
        0xF0,0x08,0xF0,0x00,0xE0,0x18,0x00,0x00,
        0x00,0x21,0x1C,0x03,0x1E,0x21,0x1E,0x00,//% 5
        0x00,0xF0,0x08,0x88,0x70,0x00,0x00,0x00,
        0x1E,0x21,0x23,0x24,0x19,0x27,0x21,0x10,//& 6
        0x10,0x16,0x0E,0x00,0x00,0x00,0x00,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//' 7
        0x00,0x00,0x00,0xE0,0x18,0x04,0x02,0x00,
        0x00,0x00,0x00,0x07,0x18,0x20,0x40,0x00,//( 8
        0x00,0x02,0x04,0x18,0xE0,0x00,0x00,0x00,
        0x00,0x40,0x20,0x18,0x07,0x00,0x00,0x00,//) 9
        0x40,0x40,0x80,0xF0,0x80,0x40,0x40,0x00,
        0x02,0x02,0x01,0x0F,0x01,0x02,0x02,0x00,//* 10
        0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,
        0x01,0x01,0x01,0x1F,0x01,0x01,0x01,0x00,//+ 11
        0x80,0xB0,0x70,0x00,0x00,0x00,0x00,0x00,//, 12
        0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,//- 13
        0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,//. 14
        0x00,0x00,0x00,0x00,0x80,0x60,0x18,0x04,
        0x00,0x60,0x18,0x06,0x01,0x00,0x00,0x00,/// 15
        0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,
        0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//0 16
        0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,
        0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//1 17
        0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,
        0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,//2 18
        0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,
        0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//3 19
        0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,
        0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//4 20
        0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,
        0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,//5 21
        0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,
        0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//6 22
        0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,
        0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,//7 23
        0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,
        0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//8 24
        0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//9 25
        0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,
        0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,//: 26
        0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,
        0x00,0x00,0x80,0x60,0x00,0x00,0x00,0x00,//; 27
        0x00,0x00,0x80,0x40,0x20,0x10,0x08,0x00,
        0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x00,//< 28
        0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00,
        0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00,//= 29
        0x00,0x08,0x10,0x20,0x40,0x80,0x00,0x00,
        0x00,0x20,0x10,0x08,0x04,0x02,0x01,0x00,//> 30
        0x00,0x70,0x48,0x08,0x08,0x08,0xF0,0x00,
        0x00,0x00,0x00,0x30,0x36,0x01,0x00,0x00,//? 31
        0xC0,0x30,0xC8,0x28,0xE8,0x10,0xE0,0x00,
        0x07,0x18,0x27,0x24,0x23,0x14,0x0B,0x00,//@ 32
        0x00,0x00,0xC0,0x38,0xE0,0x00,0x00,0x00,
        0x20,0x3C,0x23,0x02,0x02,0x27,0x38,0x20,//A 33
        0x08,0xF8,0x88,0x88,0x88,0x70,0x00,0x00,
        0x20,0x3F,0x20,0x20,0x20,0x11,0x0E,0x00,//B 34
        0xC0,0x30,0x08,0x08,0x08,0x08,0x38,0x00,
        0x07,0x18,0x20,0x20,0x20,0x10,0x08,0x00,//C 35
        0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,
        0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00,//D 36
        0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,
        0x20,0x3F,0x20,0x20,0x23,0x20,0x18,0x00,//E 37
        0x20,0x3F,0x20,0x00,0x03,0x00,0x00,0x00,//F 38
        0xC0,0x30,0x08,0x08,0x08,0x38,0x00,0x00,
        0x07,0x18,0x20,0x20,0x22,0x1E,0x02,0x00,//G 39
        0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,
        0x20,0x3F,0x21,0x01,0x01,0x21,0x3F,0x20,//H 40
        0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0x00,
        0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//I 41
        0x00,0x00,0x08,0x08,0xF8,0x08,0x08,0x00,
        0xC0,0x80,0x80,0x80,0x7F,0x00,0x00,0x00,//J 42
        0x08,0xF8,0x88,0xC0,0x28,0x18,0x08,0x00,
        0x20,0x3F,0x20,0x01,0x26,0x38,0x20,0x00,//K 43
        0x08,0xF8,0x08,0x00,0x00,0x00,0x00,0x00,
        0x20,0x3F,0x20,0x20,0x20,0x20,0x30,0x00,//L 44
        0x08,0xF8,0xF8,0x00,0xF8,0xF8,0x08,0x00,
        0x20,0x3F,0x00,0x3F,0x00,0x3F,0x20,0x00,//M 45
        0x08,0xF8,0x30,0xC0,0x00,0x08,0xF8,0x08,
        0x20,0x3F,0x20,0x00,0x07,0x18,0x3F,0x00,//N 46
        0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,
        0x0F,0x10,0x20,0x20,0x20,0x10,0x0F,0x00,//O 47
        0x08,0xF8,0x08,0x08,0x08,0x08,0xF0,0x00,
        0x20,0x3F,0x21,0x01,0x01,0x01,0x00,0x00,//P 48
        0x0F,0x18,0x24,0x24,0x38,0x50,0x4F,0x00,//Q 49
        0x08,0xF8,0x88,0x88,0x88,0x88,0x70,0x00,
        0x20,0x3F,0x20,0x00,0x03,0x0C,0x30,0x20,//R 50
        0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,
        0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00,//S 51
        0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,
        0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//T 52
        0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00,//U 53
        0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,
        0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,//V 54
        0xF8,0x08,0x00,0xF8,0x00,0x08,0xF8,0x00,
        0x03,0x3C,0x07,0x00,0x07,0x3C,0x03,0x00,//W 55
        0x08,0x18,0x68,0x80,0x80,0x68,0x18,0x08,
        0x20,0x30,0x2C,0x03,0x03,0x2C,0x30,0x20,//X 56
        0x08,0x38,0xC8,0x00,0xC8,0x38,0x08,0x00,
        0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//Y 57
        0x10,0x08,0x08,0x08,0xC8,0x38,0x08,0x00,
        0x20,0x38,0x26,0x21,0x20,0x20,0x18,0x00,//Z 58
        0x00,0x00,0x00,0xFE,0x02,0x02,0x02,0x00,
        0x00,0x00,0x00,0x7F,0x40,0x40,0x40,0x00,//[ 59
        0x00,0x0C,0x30,0xC0,0x00,0x00,0x00,0x00,
        0x00,0x00,0x00,0x01,0x06,0x38,0xC0,0x00,//\ 60
        0x00,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,
        0x00,0x40,0x40,0x40,0x7F,0x00,0x00,0x00,//] 61
        0x00,0x00,0x04,0x02,0x02,0x02,0x04,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//^ 62
        0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,//_ 63
        0x00,0x02,0x02,0x04,0x00,0x00,0x00,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//` 64
        0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,
        0x00,0x19,0x24,0x22,0x22,0x22,0x3F,0x20,//a 65
        0x08,0xF8,0x00,0x80,0x80,0x00,0x00,0x00,
        0x00,0x3F,0x11,0x20,0x20,0x11,0x0E,0x00,//b 66
        0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,
        0x00,0x0E,0x11,0x20,0x20,0x20,0x11,0x00,//c 67
        0x00,0x00,0x00,0x80,0x80,0x88,0xF8,0x00,
        0x00,0x0E,0x11,0x20,0x20,0x10,0x3F,0x20,//d 68
        0x00,0x1F,0x22,0x22,0x22,0x22,0x13,0x00,//e 69
        0x00,0x80,0x80,0xF0,0x88,0x88,0x88,0x18,
        0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//f 70
        0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,
        0x00,0x6B,0x94,0x94,0x94,0x93,0x60,0x00,//g 71
        0x08,0xF8,0x00,0x80,0x80,0x80,0x00,0x00,
        0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,//h 72
        0x00,0x80,0x98,0x98,0x00,0x00,0x00,0x00,
        0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//i 73
        0x00,0x00,0x00,0x80,0x98,0x98,0x00,0x00,
        0x00,0xC0,0x80,0x80,0x80,0x7F,0x00,0x00,//j 74
        0x08,0xF8,0x00,0x00,0x80,0x80,0x80,0x00,
        0x20,0x3F,0x24,0x02,0x2D,0x30,0x20,0x00,//k 75
        0x00,0x08,0x08,0xF8,0x00,0x00,0x00,0x00,
        0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//l 76
        0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,
        0x20,0x3F,0x20,0x00,0x3F,0x20,0x00,0x3F,//m 77
        0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,
        0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,//n 78
        0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00,//o 79
        0x80,0x80,0x00,0x80,0x80,0x00,0x00,0x00,
        0x80,0xFF,0xA1,0x20,0x20,0x11,0x0E,0x00,//p 80
        0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x00,
        0x00,0x0E,0x11,0x20,0x20,0xA0,0xFF,0x80,//q 81
        0x80,0x80,0x80,0x00,0x80,0x80,0x80,0x00,
        0x20,0x20,0x3F,0x21,0x20,0x00,0x01,0x00,//r 82
        0x00,0x33,0x24,0x24,0x24,0x24,0x19,0x00,//s 83
        0x00,0x80,0x80,0xE0,0x80,0x80,0x00,0x00,
        0x00,0x00,0x00,0x1F,0x20,0x20,0x00,0x00,//t 84
        0x80,0x80,0x00,0x00,0x00,0x80,0x80,0x00,
        0x00,0x1F,0x20,0x20,0x20,0x10,0x3F,0x20,//u 85
        0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,
        0x00,0x01,0x0E,0x30,0x08,0x06,0x01,0x00,//v 86
        0x80,0x80,0x00,0x80,0x00,0x80,0x80,0x80,
        0x0F,0x30,0x0C,0x03,0x0C,0x30,0x0F,0x00,//w 87
        0x00,0x80,0x80,0x00,0x80,0x80,0x80,0x00,
        0x00,0x20,0x31,0x2E,0x0E,0x31,0x20,0x00,//x 88
        0x80,0x81,0x8E,0x70,0x18,0x06,0x01,0x00,//y 89
        0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,
        0x00,0x21,0x30,0x2C,0x22,0x21,0x30,0x00,//z 90
        0x00,0x00,0x00,0x00,0x80,0x7C,0x02,0x02,
        0x00,0x00,0x00,0x00,0x00,0x3F,0x40,0x40,//{ 91
        0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,
        0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,//| 92
        0x00,0x02,0x02,0x7C,0x80,0x00,0x00,0x00,
        0x00,0x40,0x40,0x3F,0x00,0x00,0x00,0x00,//} 93
        0x00,0x06,0x01,0x01,0x02,0x02,0x04,0x04,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//~ 94
#endif
Delay.c
  * @brief  微秒级延时
  * @param  xus 延时时长,范围:0~233015
  * @retval 无
void Delay_us(uint32_t xus)
        SysTick->LOAD = 72 * xus;                                //设置定时器重装值
        SysTick->VAL = 0x00;                                        //清空当前计数值
        SysTick->CTRL = 0x00000005;                                //设置时钟源为HCLK,启动定时器
        while(!(SysTick->CTRL & 0x00010000));        //等待计数到0
        SysTick->CTRL = 0x00000004;                                //关闭定时器
  * @brief  毫秒级延时
  * @param  xms 延时时长,范围:0~4294967295
  * @retval 无
void Delay_ms(uint32_t xms)
        while(xms--)
                Delay_us(1000);
  * @brief  秒级延时
  * @param  xs 延时时长,范围:0~4294967295
  * @retval 无
void Delay_s(uint32_t xs)
        while(xs--)
                Delay_ms(1000);
