MSP430F149驱动HT1621
3081|0
 楼主| 比神乐 发表于 2024-5-25 17:10 | 显示全部楼层 |阅读模式
代码:
  1. /********************************************************************
  2. //DM430-A型开发板控制8个发光二极管闪烁程序
  3. //发光二极管分别接入P2口,每500ms状态转换一次
  4. //调试环境:EW430 V5.30
  5. //作者:阿迪 www.avrgcc.com
  6. //时间:2011.09.19
  7. ********************************************************************/
  8. #include <msp430x14x.h>
  9. #include "Config.h"                  //开发板配置头文件,主要配置IO端口及时钟看门狗函数
  10. #define uchar unsigned char
  11. #define uint unsigned int
  12. #define DA_1 P2OUT |= BIT0  //RS置1
  13. #define DA_0 P2OUT &= ~BIT0 //RS置0
  14. #define WR_1 P2OUT |= BIT1 //RS置1
  15. #define WR_0 P2OUT &= ~BIT1 //RS置0
  16. #define CS_1 P2OUT |= BIT2 //RS置1
  17. #define CS_0 P2OUT &= ~BIT2  //RS置0
  18. #define Smg_a 0x80
  19. #define Smg_b 0x40
  20. #define Smg_c 0x20
  21. #define Smg_d 0x01
  22. #define Smg_e 0x02
  23. #define Smg_f 0x08
  24. #define Smg_g 0x04
  25. #define Smg_dp 0x10
  26. #define Bmp0Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
  27. #define Bmp1Map Smg_b | Smg_c
  28. #define Bmp2Map Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
  29. #define Bmp3Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
  30. #define Bmp4Map Smg_b | Smg_c | Smg_f | Smg_g
  31. #define Bmp5Map Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
  32. #define Bmp6Map Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
  33. #define Bmp8Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
  34. #define Bmp9Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
  35. #define Bmp7Map Smg_a | Smg_b | Smg_c
  36. #define BmpAMap Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
  37. #define BmpBMap Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
  38. #define BmpCMap Smg_a | Smg_d | Smg_e | Smg_f
  39. #define BmpDMap Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
  40. #define BmpEMap Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
  41. #define BmpFMap Smg_a | Smg_e | Smg_f | Smg_g
  42. const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
  43. unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //?????
  44. unsigned int i;
  45. void COMMAND_HT1621(unsigned char comm)
  46. {
  47. //unsigned char i;
  48. CS_0;
  49. WR_0;
  50. for(i=0;i<3;i++)//???
  51. {
  52. if((0x04<<i)&0x04)
  53. DA_1; //100
  54. else
  55. DA_0;
  56. WR_0;
  57. WR_1;
  58. }
  59. for(i=0;i<9;i++)//?????
  60. {
  61. if((comm<<i)&0x80) DA_1; //100
  62. else DA_0;
  63. WR_0;
  64. WR_1;
  65. }
  66. CS_1;
  67. }
  68. void HT1621_Display(void)
  69. {
  70. //unsigned char i;
  71. CS_0;//??CS
  72. WR_0;
  73. for(i=0;i<3;i++) //???
  74. {
  75. if((0x05<<i)&0x04) DA_1;
  76. else DA_0;
  77. WR_0;
  78. WR_1;
  79. }
  80. for(i=0;i<6;i++) //???
  81. {
  82. if((20<<i)&0x20) DA_1;//20?? SEG??
  83. else DA_0;
  84. WR_0;
  85. WR_1;
  86. }
  87. for(i=0;i<8;i++) //???
  88. {
  89. if((DpyNum[5]<<i)&0x80)
  90. DA_1;
  91. else DA_0;
  92. WR_0;
  93. WR_1;
  94. }
  95. for(i=0;i<8;i++) //???
  96. {
  97. if((DpyNum[4]<<i)&0x80)DA_1;
  98. else DA_0;
  99. WR_0;
  100. WR_1;
  101. }
  102. for(i=0;i<8;i++) //???
  103. {
  104. if((DpyNum[3]<<i)&0x80) DA_1;
  105. else DA_0;
  106. WR_0;
  107. WR_1;
  108. }
  109. for(i=0;i<8;i++) //???
  110. {
  111. if((DpyNum[2]<<i)&0x80)DA_1;
  112. else DA_0;
  113. WR_0;
  114. WR_1;
  115. }
  116. for(i=0;i<8;i++) //???
  117. {
  118. if((DpyNum[1]<<i)&0x80)DA_1;
  119. else DA_0;
  120. WR_0;
  121. WR_1;
  122. }
  123. for(i=0;i<8;i++) //???
  124. {
  125. if((DpyNum[0]<<i)&0x80) DA_1;
  126. else DA_0;
  127. WR_0;
  128. WR_1;
  129. }
  130. CS_1;//??CS
  131. }
  132. void LCD_Init(void)
  133. {
  134. COMMAND_HT1621(0x01);//SYS EN
  135. COMMAND_HT1621(0x03);//LCD ON
  136. COMMAND_HT1621(0x29);//4 COM牋1/3 BIAS
  137. HT1621_Display(); //clear screen
  138. }
  139. //***********************************************************************
  140. //               MSP430IO口初始化
  141. //***********************************************************************
  142. void Port_Init()
  143. {
  144.   LED8SEL = 0x00;                     //设置IO口为普通I/O模式
  145.   LED8DIR = 0xFF;                     //设置IO口方向为输出
  146.   LED8PORT = 0xFF;                    //P2口初始设置为FF
  147. }
  148. //***********************************************************************
  149. //      主程序
  150. //***********************************************************************
  151. void main(void)
  152. {
  153.   WDT_Init();                       //看门狗初始化
  154.   Clock_Init();                     //时钟初始化
  155.   Port_Init();                      //端口初始化,用于控制IO口输入或输出
  156.   Close_LED();                      //关闭数码管
  157.   LCD_Init();
  158. DpyNum[0] = Smg_a|Smg_d|Smg_g;//"?"
  159. DpyNum[1] = SegCode[2];
  160. DpyNum[2] = SegCode[4];
  161. DpyNum[3] = SegCode[6];
  162. DpyNum[4] = SegCode[8];
  163. DpyNum[5] = SegCode[0];
  164. HT1621_Display();
  165.   while(1)
  166.   {
  167.
  168.   }
  169. }
效果图;
