为什么AD5328没有输出电压
2784|3
 楼主| 伊小于 发表于 2024-6-17 17:31 | 显示全部楼层 |阅读模式
#ifndef __SPI1_H
#define __SPI1_H
#include "gd32f4xx.h"
/* 时钟使能宏定义 */
#define SPIx                              SPI1
#define SPIx_CLK_ENABLE()                 rcu_periph_clock_enable(RCU_SPI1)
#define SPIx_SCK_GPIO_CLK_ENABLE()        rcu_periph_clock_enable(RCU_GPIOB)
#define SPIx_MISO_GPIO_CLK_ENABLE()       rcu_periph_clock_enable(RCU_GPIOB)
#define SPIx_MOSI_GPIO_CLK_ENABLE()       rcu_periph_clock_enable(RCU_GPIOB)
#define SPIx_CS_GPIO_CLK_ENABLE()         rcu_periph_clock_enable(RCU_GPIOB)
#define LDAC_GPIO_CLK_ENABLE()            rcu_periph_clock_enable(RCU_GPIOB)
/* SPIx 引脚定义 */
#define SPIx_SCK_PIN                      GPIO_PIN_13
#define SPIx_SCK_GPIO_PORT                GPIOB
#define SPIx_MOSI_PIN                     GPIO_PIN_15
#define SPIx_MOSI_GPIO_PORT               GPIOB
#define AD5328_CS_PIN                     GPIO_PIN_12
#define AD5328_CS_GPIO_PORT               GPIOB
// AD5328 的 LDAC 引脚
#define AD5328_LDAC_PIN                   GPIO_PIN_14
#define AD5328_LDAC_GPIO_PORT             GPIOB
#define digitalHi(p,i)                    {gpio_bit_set(p, i);}              // 设置为高电平
#define digitalLo(p,i)                    {gpio_bit_reset(p, i);}            // 设置为低电平
#define SPI_AD5328_CS_LOW()               digitalLo(AD5328_CS_GPIO_PORT, AD5328_CS_PIN)
#define SPI_AD5328_CS_HIGH()              digitalHi(AD5328_CS_GPIO_PORT, AD5328_CS_PIN)
#define AD5328_LDAC_LOW()                 digitalLo(AD5328_LDAC_GPIO_PORT, AD5328_LDAC_PIN)
#define AD5328_LDAC_HIGH()                digitalHi(AD5328_LDAC_GPIO_PORT, AD5328_LDAC_PIN)
void SPI1_Init(void);//SPI1初始化
void Write_Byte(unsigned int Data);//SPI1写数据
void SPI1_Write_Data(unsigned char Channel,unsigned int Tdata);//写数据
void AD5328_Init(); //AD5328初始化
void SPWM_Out_DAValue(unsigned char Channel,unsigned int Dim_Vlaue);
#endif /* __SPI1_H */
#include "main.h"
#include "systick.h"
unsigned int RST = 0xE000;
unsigned int Buff_SET = 0x8000;
unsigned int POWER_DOWN = 0xC000;
unsigned int LOCK_MODE_Updata = 0xA001;
void AD5328_Init(void)//AD5328初始化
    Write_Byte(RST);//复位芯片
        delay_1ms(1);//延时1ms
        Write_Byte(Buff_SET); //设置缓冲模式
        Write_Byte(POWER_DOWN);//关闭功耗模式
        Write_Byte(LOCK_MODE_Updata);//单次更新模式
void SPI1_Init(void)//SPI1初始化
    spi_parameter_struct spi_init_struct;//SPI参数结构体
    /* 使能外设和GPIO时钟 */
    SPIx_SCK_GPIO_CLK_ENABLE();
    SPIx_MOSI_GPIO_CLK_ENABLE();
    SPIx_CS_GPIO_CLK_ENABLE();
    SPIx_CLK_ENABLE();
    LDAC_GPIO_CLK_ENABLE();
    /* 配置 SPI SCK GPIO 引脚 */
    gpio_mode_set(SPIx_SCK_GPIO_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP, SPIx_SCK_PIN);
    gpio_output_options_set(SPIx_SCK_GPIO_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, SPIx_SCK_PIN);
    gpio_af_set(SPIx_SCK_GPIO_PORT, GPIO_AF_5, SPIx_SCK_PIN);  // 设置为 AF5 用于 SPI1
    /* 配置 SPI MOSI GPIO 引脚 */
    gpio_mode_set(SPIx_MOSI_GPIO_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP, SPIx_MOSI_PIN);
    gpio_output_options_set(SPIx_MOSI_GPIO_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, SPIx_MOSI_PIN);
    gpio_af_set(SPIx_MOSI_GPIO_PORT, GPIO_AF_5, SPIx_MOSI_PIN);  // 设置为 AF5 用于 SPI1
    /* 配置 CS 引脚 */
    gpio_mode_set(AD5328_CS_GPIO_PORT, GPIO_MODE_OUTPUT, GPIO_PUPD_PULLUP, AD5328_CS_PIN);
    gpio_output_options_set(AD5328_CS_GPIO_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, AD5328_CS_PIN);
    //gpio_af_set(AD5328_CS_GPIO_PORT, GPIO_AF_5, AD5328_CS_PIN);  // 设置为 AF5 用于 SPI1
    /* 配置 LDAC 引脚 */
    gpio_mode_set(AD5328_LDAC_GPIO_PORT, GPIO_MODE_OUTPUT, GPIO_PUPD_PULLUP, AD5328_LDAC_PIN);
    gpio_output_options_set(AD5328_LDAC_GPIO_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, AD5328_LDAC_PIN);
    /* SPI 配置 */
    spi_init_struct.trans_mode           = SPI_TRANSMODE_BDTRANSMIT;//半双工模式
    spi_init_struct.device_mode          = SPI_MASTER;//主机模式
    spi_init_struct.frame_size           = SPI_FRAMESIZE_8BIT;//8位帧
    spi_init_struct.clock_polarity_phase = SPI_CK_PL_LOW_PH_1EDGE;//时钟极性低,第二个边沿采样
    spi_init_struct.nss                  = SPI_NSS_SOFT;//软件控制NSS
    spi_init_struct.prescale             = SPI_PSC_4;//预分频256
    spi_init_struct.endian               = SPI_ENDIAN_MSB;//高位在前
    spi_init(SPIx, &spi_init_struct);
//    spi_bidirectional_line_config()
    spi_enable(SPIx);
unsigned char SPI_Buff[4] = {0};
void Write_Byte(unsigned int Data)//SPI1写数据
    SPI_AD5328_CS_LOW();//NSS拉低
    SPI_Buff[0] = (unsigned char)(Data>>8);        //高位
        SPI_Buff[1] = (unsigned char)(Data);//低位
    while (RESET == spi_i2s_flag_get(SPIx, SPI_FLAG_TBE));// 等待发送缓冲区空闲
    spi_i2s_data_transmit(SPIx, SPI_Buff[0]);
    spi_i2s_data_transmit(SPIx, SPI_Buff[1]);
    SPI_AD5328_CS_HIGH();//NSS拉高
unsigned int sdata =0;
void SPI1_Write_Data(unsigned char Channel,unsigned int Tdata)//写入数据
    sdata = (Channel<<12) | (Tdata & 0x0FFF);//设置数据位
    sdata = sdata & 0x7FFF;//去掉最高位的1
    SPI_Buff[0] = (unsigned char)(sdata>>8);        //高位
        SPI_Buff[1] = (unsigned char)(sdata);//低位
    while (RESET == spi_i2s_flag_get(SPIx, SPI_FLAG_TBE));//等待空闲位
unsigned int REF_AD_Value = 0;//AD采样值
unsigned int DA_Value = 0;//DAC输出值
double FDA_Value = 0;//DAC输出值(浮点数)
//Channel:通道选择,0~7
//Dim_Vlaue:亮度值,0~5000
void SPWM_Out_DAValue(unsigned char Channel,unsigned int Dim_Vlaue)//SPWM输出DAC值
if(Dim_Vlaue <= 4998)//0-5V
    FDA_Value = (double)Dim_Vlaue/5000;//DAC输出值(浮点数)
    DA_Value = FDA_Value*4096;//DAC输出值(整数)
  }else
    DA_Value = 4095;//最大值
  SPI1_Write_Data(Channel,Dim_Vlaue);//写入数据
地瓜patch 发表于 2024-6-21 23:07 来自手机 | 显示全部楼层
硬件有问题的概率大
硬件也没有把mosl硬件下拉,然后我读文档也没有注意,所以出问题 加一句: gpio_mode_set(GPIOB, GPIO_MODE_OUTPUT, GPIO_PUPD_PULLDOWN, GPIO_PIN_14);  发表于 2024-7-3 12:00
我已经调试出来了,MOSI要下拉,不下拉的话,就无法通讯  发表于 2024-7-3 11:57
