[ModusToolbox™] capsense Tuner失败
2335|20
 楼主| 善水789 发表于 2024-7-5 17:17 | 显示全部楼层 |阅读模式
使用MTB3.2在进行Capsense Tuner失败,信息如下:有没有知道原因的,指点一下,谢谢。
OpenOCD process started
Open On-Chip Debugger 0.12.0+dev-5.1.0.3099 (2024-05-02-11:37)
Licensed under GNU GPL v2
For bug reports, read
        http://openocd.org/doc/doxygen/bugs.html
C:/Users/JCT/ModusToolbox/tools_3.2/capsense-configurator/rtt.tcl: Info: Found symbol '_SEGGER_RTT' @ 0x200003e4 in executable 'C:/Users/JCT/mtw/MSCLP_LLS_Template_UartTuner/build/APP_CY8CKIT-040T/Debug/mtb-example-psoc4-msclp-self-capacitance-button.elf'
adapter speed: 2000 kHz
adapter speed: 8000 kHz
Info : Using CMSIS-DAPv2 interface with VID:PID=0x04b4:0xf151, serial=1A2105B803260522
Info : CMSIS-DAP: SWD supported
Info : CMSIS-DAP: Atomic commands supported
Info : CMSIS-DAP: FW Version = 2.0.0
Info : CMSIS-DAP: Serial# = 307799870
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 0 TDO = 0 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : KitProg3: FW version: 2.40.1241
Info : KitProg3: Pipelined transfers enabled
Info : KitProg3: Asynchronous USB transfers enabled
Info : VTarget = 0.000 V
Info : clock speed 8000 kHz
Info : SWD DPIDR 0x0bc11477
Info : [psoc4.cpu] Cortex-M0+ r0p1 processor detected
Info : [psoc4.cpu] target has 4 breakpoints, 2 watchpoints
** Silicon: 0x3612, Family: 0xC6, Rev.: 0x22 (B1)
** Detected Family: PSoC 4000T
** Detected Device: CY8C4046LQI-T452
** Detected Main Flash size, kb: 64
** Chip Protection: OPEN
Info : [psoc4.mem_ap] Examination succeed
Info : [psoc4.cpu] Examination succeed
Info : gdb port disabled
Info : starting gdb server for psoc4.cpu on 3333
Info : Listening on port 3333 for gdb connections
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Error: [psoc4.cpu] DP initialisation failed
Error: [psoc4.cpu] Failed to enable the FPB
Polling target psoc4.cpu failed, trying to reexamine
Info : [psoc4.cpu] Cortex-M0+ r0p0 processor detected
Info : [psoc4.cpu] target has 0 breakpoints, 0 watchpoints
: Info: Reset device executed
Command: C:/Users/JCT/ModusToolbox/tools_3.2/capsense-configurator/rtt.tcl: rtt setup 0x200003e4 10 {SEGGER RTT}
Command: C:/Users/JCT/ModusToolbox/tools_3.2/capsense-configurator/rtt.tcl: rtt server start 50566 0
Info : Listening on port 50566 for rtt connections
Command: C:/Users/JCT/ModusToolbox/tools_3.2/capsense-configurator/rtt.tcl: rtt server start 50567 1
Info : Listening on port 50567 for rtt connections
Command: C:/Users/JCT/ModusToolbox/tools_3.2/capsense-configurator/rtt.tcl: rtt polling_interval 1
Command: C:/Users/JCT/ModusToolbox/tools_3.2/capsense-configurator/rtt.tcl: rtt start
Info : rtt: No control block with id 'SEGGER RTT' found, will retry
C:/Users/JCT/ModusToolbox/tools_3.2/capsense-configurator/rtt.tcl: RTT Channel Info
rtt: Control block not available
Error: Size 2 not supported
C:/Infineon/Tools/ModusToolboxProgtools-1.1/openocd/scripts/interface/kitprog3.cfg:39: Error: rtt: Control block not available
at file "C:/Infineon/Tools/ModusToolboxProgtools-1.1/openocd/scripts/interface/kitprog3.cfg", line 39
Error: Size 2 not supported (repeated 16 times)
Error: Size 2 not supported (repeated 20 times)
Info : accepting 'rtt' connection on tcp/50567
Warn : rtt: Down-channel 1 is not available
Error: Size 2 not supported (repeated 32 times)
Error: Size 2 not supported (repeated 64 times)
Error: Size 2 not supported (repeated 79 times)
Error: Size 2 not supported (repeated 40 times)
Error: Size 2 not supported (repeated 71 times)
Error: Size 2 not supported (repeated 48 times)
Info : dropped 'rtt' connection
shutdown command invoked
Info : psoc4.dap: powering down debug domain...
Warn :
* KitProg3 firmware is out of date. Update to the latest detected version (2.60.1450)
* found in C:/Infineon/Tools/ModusToolboxProgtools-1.1/kp-firmware
* using fw-loader tool
OpenOCD Duration: 7210 ms
OpenOCD process finished
请问您是自己写的代码还是用的我们的demo程序  发表于 2024-7-9 15:21
chenjun89 发表于 2024-7-7 18:35 来自手机 | 显示全部楼层
对这个不熟悉,估计是配置原因。
IFX-Unic 发表于 2024-7-7 22:57 | 显示全部楼层
有没有使用新的jlink rtt源文件更新替换过原来的RTT文件?
 楼主| 善水789 发表于 2024-7-8 14:59 | 显示全部楼层
这个工程的RTT没有改动过,PSOC 4000T液位检测的工程。
PSoC小子 发表于 2024-7-10 13:48 | 显示全部楼层
使用 RTT  的话,你要确保 debug 口是使能的,
elephant00 发表于 2024-7-10 15:03 | 显示全部楼层
软件配置有误?
jcky001 发表于 2024-7-10 20:00 | 显示全部楼层
设备固件或调试器驱动可能不是最新版本,或者存在兼容性问题。
两只袜子 发表于 2024-7-11 15:00 | 显示全部楼层
如果Capsense Tuner是通过UART或其他通信接口与设备连接的,那么连接问题(如线路故障、接口不匹配等)可能导致通信失败。
cr315 发表于 2024-7-11 15:00 | 显示全部楼层
资源冲突或者代码错误
IFX-RayLiang 发表于 2024-7-18 19:35 | 显示全部楼层
Log中显示:
可能并没有给烧录器手动上电,可以检查一下供电是否已经打开。
逢dududu必shu 发表于 2024-8-17 01:00 | 显示全部楼层
ModusToolbox、OpenOCD、和CapSense Configurator的版本都是最新的吗?与固件兼容吗。
IFX-DaveLong 发表于 2024-8-23 17:12 | 显示全部楼层
Log 提示KitProg3的固件不是最新版本,建议先把固件KitPro3的固件更新到最新版本。
可直接在ModusToolBox 下打开ModusToolBox Programmer根据提示直接更新仿真器固件。
sblpp 发表于 2024-8-25 19:45 | 显示全部楼层
sblpp 发表于 2024-8-25 19:47 | 显示全部楼层
Log中显示:
有这些,说明供电是OK的,读到ID了~
原来是wjc 发表于 2025-2-28 23:20 | 显示全部楼层
OpenOCD的版本或者配置可能存在问题,导致无法与硬件正常通信。
g36xcv 发表于 2025-3-25 16:02 | 显示全部楼层
日志中显示了OpenOCD、CMSIS-DAP和KitProg3的相关信息,但没有显示明显的错误信息。
小夏天的大西瓜 发表于 2025-3-25 22:52 | 显示全部楼层
找到具体的原因了嘛
小小蚂蚁举千斤 发表于 2025-3-26 23:37 | 显示全部楼层
peterLaw 发表于 2025-3-30 14:08 | 显示全部楼层
应该是设置问题
Burnon_FAE_2 发表于 2025-3-31 21:32 | 显示全部楼层
建议使用EZIIC的通信方式,这种方式可以把Tuner调整的参数实时的TO到Project里面方便参数更新
