[AIROC™ Wi-Fi + BT] Kernel panic - not syncing tx_cpu nr_cpu_ids file dhd_linux_lb.c line 216
573|0
 楼主| IFX-Raymondtsoi 发表于 2024-7-24 19:22 | 显示全部楼层 |阅读模式
Patch for Kernel panic - not syncing tx_cpu  nr_cpu_ids file dhd_linux_lb.c  line 216
File: dhd_linux_lb.c
Function: dhd_select_cpu_candidacy
        if ((primary_available_cpus == 0) &&
                (secondary_available_cpus == 0)) {
                /* No CPUs available from primary or secondary mask */
                napi_cpu = 1;
                compl_cpu = 0;
                tx_cpu = 2;
+                if (tx_cpu >= nr_cpu_ids)
+                        tx_cpu = 0;
