#include “N76E003.h”
#include “Common.h”
#include “Delay.h”
#include “SFR_Macro.h”
#include “Function_define.h”
bit BIT_TMP; void Timer0_Delay10us(UINT32 u32CNT)
clr_T0M; //T0M=0, Timer0 Clock = Fsys/12
TIMER0_MODE1_ENABLE; //TMOD |= 0x01; //Timer0 is 16-bit mode - set_TR0; <span class="hljs-regexp">//</span>Start Timer0
- <span class="hljs-keyword">while</span> (u32CNT != <span class="hljs-number">0</span>)
- TL0 = LOBYTE(TIMER_DIV12_VALUE_10us); <span class="hljs-regexp">//</span>Find define <span class="hljs-keyword">in</span> <span class="hljs-string">"Function_define.h"</span> <span class="hljs-string">"TIMER VALUE"</span>
- TH0 = HIBYTE(TIMER_DIV12_VALUE_10us);
- <span class="hljs-keyword">while</span> (TF0 != <span class="hljs-number">1</span>); <span class="hljs-regexp">//</span>Check Timer0 Time-Out Flag
- clr_TF0;
- u32CNT --;
- clr_TR0; <span class="hljs-regexp">//</span>Stop Timer0
void Timer0_Delay100us(UINT32 u32CNT)
set_TR0; //Start Timer0
while (u32CNT != 0)
TL0 = LOBYTE(TIMER_DIV12_VALUE_100us); //Find define in “Function_define.h” “TIMER VALUE”
TH0 = HIBYTE(TIMER_DIV12_VALUE_100us);
while (TF0 != 1); //Check Timer0 Time-Out Flag
clr_TF0;
u32CNT —;
clr_TR0; //Stop Timer0
//void Timer0_Delay1ms(UINT32 u32CNT)
// clr_T0M; //T0M=0, Timer0 Clock = Fsys/12
// TMOD |= 0x01; //Timer0 is 16-bit mode
// set_TR0; //Start Timer0
// while (u32CNT != 0)
// TL0 = LOBYTE(TIMER_DIV12_VALUE_1ms); //Find define in “Function_define.h” “TIMER VALUE”
// TH0 = HIBYTE(TIMER_DIV12_VALUE_1ms);
// while (TF0 != 1); //Check Timer0 Time-Out Flag
// clr_TF0;
// u32CNT —;
// clr_TR0; //Stop Timer0
//} void Timer0_Delay1ms(UINT32 u32CNT)
clr_T0M; //T0M=0, Timer0 Clock = Fsys/12 // TMOD |= 0x01; //Timer0 is 16-bit mode
TMOD&=0xf0; TMOD |= 0x01; //Timer0 is 16-bit mode // Start Timer0
while (u32CNT != 0)
TL0 = TIMER_DIV12_VALUE_1ms & 0xff;
TH0 = TIMER_DIV12_VALUE_1ms >> 8;
- while (TF0 != <span class="hljs-number">1 //</span>Check Timer0 Time-Out Flag
- clr_TF0;
- u32CNT --;
- clr_TR0; //Stop Timer0
void Timer1_Delay10ms(UINT32 u32CNT)
clr_T1M; //T1M=0, Timer1 Clock = Fsys/12
TMOD |= 0x10; //Timer1 is 16-bit mode
set_TR1; //Start Timer1
while (u32CNT != 0)
TL1 = LOBYTE(TIMER_DIV12_VALUE_10ms); //Find define in “Function_define.h” “TIMER VALUE”
TH1 = HIBYTE(TIMER_DIV12_VALUE_10ms);
while (TF1 != 1); //Check Timer1 Time-Out Flag
clr_TF1;
u32CNT —;
clr_TR1; //Stop Timer1
void Timer2_Delay500us(UINT32 u32CNT)
clr_T2DIV2; //Timer2 Clock = Fsys/4
clr_T2DIV1;
set_T2DIV0;
set_TR2; //Start Timer2
while (u32CNT != 0)
TL2 = LOBYTE(TIMER_DIV4_VALUE_500us); //Find define in “Function_define.h” “TIMER VALUE”
TH2 = HIBYTE(TIMER_DIV4_VALUE_500us);
while (TF2 != 1); //Check Timer2 Time-Out Flag
clr_TF2;
u32CNT —;
clr_TR2; //Stop Timer2
void Timer3_Delay100ms(UINT32 u32CNT)
T3CON = 0x07; //Timer3 Clock = Fsys/128
set_TR3; //Trigger Timer3
while (u32CNT != 0)
RL3 = LOBYTE(TIMER_DIV128_VALUE_100ms); //Find define in “Function_define.h” “TIMER VALUE”
RH3 = HIBYTE(TIMER_DIV128_VALUE_100ms);
while ((T3CON&SET_BIT4) != SET_BIT4); //Check Timer3 Time-Out Flag
clr_TF3;
u32CNT —;
clr_TR3; //Stop Timer3
void Timer3_Delay10us(UINT32 u32CNT)
while (u32CNT != 0)
RL3 = LOBYTE(TIMER_DIV4_VALUE_10us); //Find define in “Function_define.h” “TIMER VALUE”
RH3 = HIBYTE(TIMER_DIV4_VALUE_10us); - <span class="hljs-keyword">while</span> ((T3CON&SET_BIT4) != SET_BIT4); <span class="hljs-regexp">//</span>Check Timer3 Time-Out Flag
- clr_TF3;
- u32CNT --;
- clr_TR3; <span class="hljs-regexp">//</span>Stop Timer3
