[AIROC™ Wi-Fi + BT] knowhow to enable 80MHz by Android11
1487|1
 楼主| IFX-LillianJ 发表于 2024-8-5 22:21 | 显示全部楼层 |阅读模式
The hostapd configuration file will be generated in the hostapd source.
Check below source code function(CreateHostapdConfig).
hostapd_supplicant_src\hostap\hostapd\hidl\1.x\hostpad.cpp
cr315 发表于 2024-8-9 19:26 | 显示全部楼层
谁能翻译一下
