[DemoCode下载] ADC配置
2303|2
 楼主| saservice 发表于 2024-8-29 22:00 | 显示全部楼层 |阅读模式
  1. /*************************ADC配置大体如下************************************************/
  2. ADC:
  3.         配置ADC:
  4.         /* Enable ADC module clock */
  5.     CLK_EnableModuleClock(ADC_MODULE);
  6.     /* ADC clock source is 22.1184MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
  7.     CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(7));
  8.
  9.         配置ADC时一定要端口的数字输入功能禁止
  10.     /* Disable the P1.0 - P1.3 digital input path to avoid the leakage current */
  11.     GPIO_DISABLE_DIGITAL_PATH(P1, 0xF);        //0000 1111
  12.
  13.     /* Configure the P1.0 - P1.3 ADC analog input pins */
  14.     SYS->P1_MFP &= ~(SYS_MFP_P10_Msk | SYS_MFP_P11_Msk | SYS_MFP_P12_Msk | SYS_MFP_P13_Msk);
  15.     SYS->P1_MFP |= SYS_MFP_P10_AIN0 | SYS_MFP_P11_AIN1 | SYS_MFP_P12_AIN2 | SYS_MFP_P13_AIN3 ;
  16.
  17. GPIO  IP有个寄存器叫OFFD(OFF  Digital),关闭相应管脚的数字通路的意思。如果某个管脚配置
  18. 为模拟功能,例如:ADC、DAC、ACMP、SEG、COM、DH1、DH2、V1、V2、V3等功能,这
  19. 些管脚对应的OFFD  bit应该使能,关闭到数字区域的通路,避免内部数字器件不停的打开、关闭
  20. 而漏电
  21.
  22.
  23.
  24. NUC029xAN  A/D转换器支持四种操作模式:  单次模式,  Burst模式,  单周期扫描模式和连续扫描模
  25. ADC continuous scan mode sample code :
  26.         //开启ADC
  27.     /* Power on ADC module */
  28.     ADC_POWER_ON(ADC);
  29.     /* Set the ADC operation mode as continuous scan, input mode as single-end and
  30.      enable the analog input channel 0, 1, 2 and 3 */
  31.     ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_CONTINUOUS, 0xF);
  32.     /* clear the A/D interrupt flag for safe */
  33.     ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
  34.     /* start A/D conversion */
  35.     ADC_START_CONV(ADC);
  36.     /* Wait conversion done */
  37.     while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT));
  38.         //转换结束后的值会放在使能通道对应的A/D寄存器中。
  39.     /* clear the A/D interrupt flag for safe */
  40.     ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
  41.     for(u32ChannelCount = 0; u32ChannelCount < 4; u32ChannelCount++)
  42.     {
  43.      i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount);
  44.      printf("Conversion result of channel %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
  45.     }
  46.     /* Wait conversion done */  ADC_ADF_INT: Convert complete interrupt flag
  47.     while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT));
  48.     /* Stop A/D conversion */
  49.     ADC_STOP_CONV(ADC);
  50.     for(u32ChannelCount = 0; u32ChannelCount < 4; u32ChannelCount++)
  51.     {
  52.      i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount);
  53.      printf("Conversion result of channel %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
  54.     }
  55.     /* clear the A/D interrupt flag for safe */
  56.     ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
  57.
  58.
  59.
  60.         //关闭ADC
  61.     /* Disable ADC module */
  62.     ADC_Close(ADC);
  63.     /* Disable ADC IP clock */
  64.     CLK_DisableModuleClock(ADC_MODULE);
  65.     /* Disable External Interrupt */
  66.     NVIC_DisableIRQ(ADC_IRQn);
  67.
  68.
呐咯密密 发表于 2024-9-2 17:14 | 显示全部楼层
库函数挺精简,很好用
花开了相爱吧 发表于 2025-8-30 13:43 | 显示全部楼层
配置 ADC 需选通道、设采样时钟与精度,配置转换模式(单次 / 连续),使能中断或 DMA,校准后启动,读取转换结果,确保时序匹配。
