Wi-Fi在汽车中的应用
8042|18
 楼主| Go_PSoC 发表于 2012-5-26 23:18 | 显示全部楼层 |阅读模式
作者:N.Venkatesh
副总裁,高级技术部
Redpine Signals公司
Kapil Rai
高级总监,赛普拉斯系统方案部
赛普拉斯半导体
Electronic and electrical equipment in the home or commercial buildings have largely been discrete and independent systems – control and management of lighting temperature access as well as various alarms have been carried out by separate control mechanisms. The field of domotics deals with the automation of these systems and recently has been receiving increasing attention:
家用或商业建筑中的电子和电气设备在很大程度上是离散和独立的系统,照明、温度、访问以及各警报控制和管理都是单独的控制机制。Domotics涉及了这些系统的自动化,最近已逐渐受到重视。
HVAC control is used to manage temperature and humidity in various parts of a building at various times through for example a thermostat accessible over the Internet
Lighting control systems automatically turn on or off lights in a room or control brightness and color to create various ambiences
The operation of appliances such as washers dryers and sprinklers can be controlled to take advantage of variations in the cost of utilities
Data read from sensors monitoring for gas leaks breakage of glass intrusion movement and smoke can be used to quickly meet required safety measures while raising an appropriate level of alarm
HVAC控制可以在不同时间不同地区管理温度和湿度,可以通过互联网进行自动调温控制
照明控制系统可以自动打开或关闭室内灯光,或者控制亮度和颜色来营造各种氛围
某些设备如洗衣机,烘干机,和洒水器的操作可控制以发挥其成本优势
读取传感器监控数据(如气体泄漏,玻璃破碎,入侵,运动,和烟雾)可快速满足所需的安全检测,同时提高警报等级
Overall domotics provides not only greater degrees of comfort and safety but also savings in energy cost. Core to domotics is connectivity which has evolved to encompass various different methods.
Today the most prevalent are mostly hard-wired with proprietary signaling including dedicated cables carrying discrete digital data standardized RS-232 or RS-422 serial cable Ethernet and powerline.
Emerging wireless methods include Wi-Fi Zigbee and Bluetooth.
总的来说,domotics不仅提供了更大程度的舒适和安全性,还节省了能源成本。Domotics的核心是连接性,它已经开发了各种不同的方法。今天,最普遍的是专有信号的硬线方式,包括专用电缆进行离散数字数据,标准的RS - 232RS-422串行电缆,以太网,和电力线。新兴的无线方式包括Wi-FiZigbee,和蓝牙技术。
 楼主| Go_PSoC 发表于 2012-5-26 23:21 | 显示全部楼层
全文见附件
bm6520 发表于 2012-5-26 23:56 | 显示全部楼层
谢谢!!学学..:lol
taihezhibanh 发表于 2012-6-17 20:25 | 显示全部楼层
哈哈,挺有用的耶!
heibaiyinjiag 发表于 2012-6-17 20:45 | 显示全部楼层
挺好的资料,帮您顶一下。
sishangcine 发表于 2012-6-17 20:54 | 显示全部楼层
多谢楼主分享!
zgsxhzac 发表于 2012-6-17 21:03 | 显示全部楼层
挺实用的,觉得不错。
shibalihuandao 发表于 2012-6-17 21:12 | 显示全部楼层
这个资料得好好拜读。
beiwaroad 发表于 2012-6-17 21:18 | 显示全部楼层
不错不错,多谢楼主。
xichengmadia 发表于 2012-6-17 21:21 | 显示全部楼层
下载学习一下。
engtafanzhuan 发表于 2012-6-17 21:23 | 显示全部楼层
楼主辛苦了。
happy_10 发表于 2012-6-17 23:08 | 显示全部楼层
不错,看看~~
宋倩2010 发表于 2012-6-17 23:10 | 显示全部楼层
严重怀疑楼上这些有几个看的
gexingyouxian 发表于 2012-6-26 10:02 | 显示全部楼层
wifi现在随处可见了啊
yangguangaisha 发表于 2012-6-26 10:06 | 显示全部楼层
这东西确实应用很广泛啊
someontime 发表于 2012-6-26 16:01 | 显示全部楼层
果然无处不在啊
haidixibahe 发表于 2012-6-26 16:06 | 显示全部楼层
以前一直以为wifi就只能用作网络接入,没想到还有这么多功能
chao11yue 发表于 2012-6-26 16:12 | 显示全部楼层
人类的智慧真是好强大
zxcvb110 发表于 2012-6-27 15:00 | 显示全部楼层
呵呵   学习
