[应用方案] 单片机简易计算器设计
1177|0
 楼主| jtracy3 发表于 2024-9-18 12:53 | 显示全部楼层 |阅读模式
#include "reg52.h"#include "string.h"#include "stdio.h"#include "lcd1602.h"#include "keyboard.h"#define keydeng                14#define keyzuoyi    12code unsigned char KeyDisPlaybuf[16] = {    '1', '2', '3', '+',\    '4', '5', '6', '-',\     '7', '8', '9', '*',\    '<', '0', '=', '/'};long Count(char *ch, char len)//简单计算器 仅支持加减乘除+-*/{    unsigned char i = 0;    char Operation;    long Num1=0,Num2=0;    while(i<len && ch!='+' && ch!='-' && ch!='*' && ch!='/')         //输入的数据 数值1    {        Num1*=10;        Num1+=ch-'0';        i++;    }    Operation=ch[i++];    while(i<len && ch!='=')           //输入的数据 数值2    {        Num2*=10;        Num2+=ch-'0';        i++;    }    switch(Operation)           //计算    {        case'+':return Num1+Num2;//加法        case'-':return Num1-Num2;//减法        case'*':return Num1*Num2;//乘法        case'/':return Num1/Num2;//除法    }        return 0;}void EasyCounter(void){        unsigned char buff[30];        unsigned char text[30];        unsigned char key;        unsigned char i = 0;        do  {                        key = keycan();//读取键值                                if(key!=0xff)//键值不等于0                        {                                text[i++]=KeyDisPlaybuf[key];//记录键值对应的字符                                text='\0';                        LCD_ShowStr(0,0,"                ");                                LCD_ShowStr(16-strlen(text),0,text); //第一行显示字符                        }        if(key==keyzuoyi&&i>0)//按下"<"时删除一位          i-=2;        }while(key!=keydeng);//按下'='时结束输入        sprintf(buff, "%ld", Count(text, strlen(text)));          LCD_ShowStr(0,1,"                ");        LCD_ShowStr(16-strlen(buff),1,buff);          //第二行显示字符}void main(void)        //主函数{  LCD_Init();  LCD_ShowStr(0,0, "               0");  while(1)  {    EasyCounter();        //按键扫描+计算+显示  }}
