请高手帮忙解答一下TLC549的问题
2246|0
 楼主| 枫恋00 发表于 2012-5-27 18:13 | 显示全部楼层 |阅读模式
#include<reg52.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
uchar code lcd[]="tension is:";
uchar code lcd1[]="      V";
uchar dis[5];
sbit   CS=P2^0;
sbit   CLK=P2^1;
sbit   DataOut=P2^2;
sbit   lcd_rs=P3^2;
sbit   lcd_rw=P3^1;
sbit   lcd_en=P3^0;
uchar num,num1;
float aver;
void delayms(uint z)    //延时ms
uint x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void write_com(uchar com)//lcd写指令控制命令
    delayms(10);
lcd_rs=0;
    lcd_rw=0;
P1=com;
lcd_en=1;
delayms(5);
lcd_en=0;
    delayms(5);
void write_data(uchar date)//lcd写数据命令
    delayms(10);
lcd_rs=1;
    lcd_rw=0;
P1=date;
delayms(10);
lcd_en=1;
delayms(10);
lcd_en=0;
void init()
    delayms(15);
write_com(0x38);//设置lcd显示模式
    delayms(5);
write_com(0x38);
    delayms(5);
write_com(0x38);
write_com(0x0c);//设置光标的显示/闪烁
write_com(0x06);//设置显示后指针加1,并且光标移一位
write_com(0x01);//清屏设置
write_com(0x80);//设置字符从地址为10的位置开始显示
void init_play()   //初始化显示
   init();
   for(num=0;num<11;num++)
  write_data(lcd[num]);
  delayms(20);
write_com(0x80+0x40);
for(num=0;num<7;num++)
  write_data(lcd1[num]);
  delayms(20);
uchar TLC549_ADC()
uchar i,temp;
CS=1;
CLK=0;
CS=0;
_nop_();
_nop_();
for(i=0;i<8;i++)
   temp<<=1;
   temp|=DataOut;  //相或
   CLK=1;
   _nop_();
   CLK=0;
   CS=1;
   for(i=17;i!=0;i--)_nop_();
   return temp;
uchar average()
   uint a[30];
   uint i,j,t;
   uchar T1;
   float sum=0;
for(i=0;i<30;i++)
   T1=TLC549_ADC();
   num1=((float)T1/256)*5000;    //电压转换扩大1000倍
   a[i]=num1;
   for(j=0;j<30;j++)   //用起泡法对30个数进行排序
    for(i=0;i<30-j;i++)
  if(a[i]>a[i+1])
    t=a[i];
    a[i]=a[i+1];
    a[i+1]=t;
     for(i=5;i<25;i++)   //取中间20个数的平均值
     sum=sum+a[i];
     aver=sum/20;
return aver;
void display()
     uchar aver1;
     aver1=average();
  dis[0]=aver1/1000+0x30;
  dis[1]=aver1/100%10+0x30;
  dis[2]=aver1/10%10+0x30;
  dis[3]=aver1%10+0x30;
  write_com(0xc1);     //显示
  write_data(dis[0]);
  write_com(0xc2);
  write_data(dis[1]);
  write_com(0xc3);
  write_data(0x2e);
  write_com(0xc4);
  write_data(dis[2]);
  write_com(0xc5);
  write_data(dis[3]);
void main()
init_play();
while(1)
//  TLC549_ADC();
  display();
用lcd显示一个TLC549A/D转换数字电压表,但是lcd显示时,只有显示1.16而且也调不了,请高手帮忙解答
