新手急求大侠帮忙解决关于ISE综合报告的timing report
6571|13
 楼主| liqibeckham 发表于 2012-5-28 08:59 | 显示全部楼层 |阅读模式
本人最近做了一个小波变换的FPGA实现   用的是ISE10.1  用的板子是xilinx V2的板子。最后综合报告出来之后  对timing report有些疑问。通常来说,
Timing constraint: Default period analysis for Clock 'clk'
  Clock period: 6.286ns (frequency: 159.076MHz)
  Total number of paths / destination ports: 268605 / 3770
Delay:               3.143ns (Levels of Logic = 5)
clock period 和Delay是相等的,为什么我的是两倍的关系呢???
timing report如下所示:
Timing Summary:
Speed Grade: -7
   Minimum period: 6.286ns (Maximum Frequency: 159.076MHz)
   Minimum input arrival time before clock: No path found
   Maximum output required time after clock: 5.521ns
   Maximum combinational path delay: No path found
Timing Detail:
All values displayed in nanoseconds (ns)
  Source:            im_show_inst/vga_inst/Hcount_6 (FF)
  Destination:       rrom/BU2/U0/blk_mem_generator/valid.cstr/has_mux_a.A/sel_pipe_1 (FF)
  Source Clock:      clk rising 0.3X
  Destination Clock: clk rising 0.7X
  Data Path: im_show_inst/vga_inst/Hcount_6 to rrom/BU2/U0/blk_mem_generator/valid.cstr/has_mux_a.A/sel_pipe_1
                                Gate     Net
    Cell:in->out      fanout   Delay   Delay  Logical Name (Net Name)
     FDC:C->Q              6   0.370   0.581  im_show_inst/vga_inst/Hcount_6 (im_show_inst/vga_inst/Hcount_6)
     LUT4_L:I0->LO         1   0.275   0.118  im_show_inst/vga_inst/Start_Video56 (im_show_inst/vga_inst/Start_Video56)
     LUT4:I2->O            2   0.275   0.416  im_show_inst/vga_inst/Start_Video57 (im_show_inst/vga_inst/Start_Video57)
     LUT4_D:I3->O          1   0.275   0.349  im_show_inst/vga_inst/Start_Video83_1 (im_show_inst/vga_inst/Start_Video83)
     LUT4:I2->O            5   0.275   0.000  mux2_1_inst/d_out<15>1 (src_addr<15>)
     begin scope: 'rrom'
     begin scope: 'BU2'
     FDE:D                     0.208          U0/blk_mem_generator/valid.cstr/has_mux_a.A/sel_pipe_1
    Total                      3.143ns (1.678ns logic, 1.465ns route)
                                       (53.4% logic, 46.6% route)
Timing constraint: Default OFFSET OUT AFTER for Clock 'clk'
  Total number of paths / destination ports: 123 / 27
Offset:              5.521ns (Levels of Logic = 5)
  Source:            rrom/BU2/U0/blk_mem_generator/valid.cstr/has_mux_a.A/sel_pipe_0 (FF)
  Destination:       B<7> (PAD)
  Source Clock:      clk rising 0.7X
  Data Path: rrom/BU2/U0/blk_mem_generator/valid.cstr/has_mux_a.A/sel_pipe_0 to B<7>
                                Gate     Net
     FDE:C->Q             16   0.370   0.766  U0/blk_mem_generator/valid.cstr/has_mux_a.A/sel_pipe_0 (U0/blk_mem_generator/valid.cstr/has_mux_a.A/sel_pipe<0>)
     LUT3:I0->O            1   0.275   0.000  U0/blk_mem_generator/valid.cstr/has_mux_a.A/Mmux_dout_mux_3 (U0/blk_mem_generator/valid.cstr/has_mux_a.A/Mmux_dout_mux_3)
     MUXF5:I1->O           6   0.303   0.543  U0/blk_mem_generator/valid.cstr/has_mux_a.A/Mmux_dout_mux_2_f5 (douta(0))
     end scope: 'BU2'
     end scope: 'rrom'
     LUT3:I1->O            3   0.275   0.397  im_show_inst/RGB_inst/B<0>1 (B_0_OBUF)
     OBUF:I->O                 2.592          B_0_OBUF (B<0>)
    Total                      5.521ns (3.815ns logic, 1.706ns route)
                                       (69.1% logic, 30.9% route)
AutoESL 发表于 2012-5-28 09:37 | 显示全部楼层
ISE和板子都老!
 楼主| liqibeckham 发表于 2012-5-28 09:40 | 显示全部楼层
没办法,现在我们这只有V2的板子能跑VGA显示,请问大侠能解释一下我遇到的这个问题吗???? 2# AutoESL
dan_xb 发表于 2012-5-28 10:51 | 显示全部楼层
1. 第一个约束,时钟周期约束   你这个不是好的吗?你时钟周期是6.286ns,你逻辑延时是3.143ns,不是很好么?
   逻辑延时必须小于时钟周期才可以工作的。因为其实还有Setup/Hold Time
   什么时候说过clock period 和Delay是相等的?
2. 你那个OFFSET OUT约束是什么意思?是为了满足输出接口的时序吗?
    你那个输出接口是同步接口还是异步接口?如果是同步接口,更好的选择是相移时钟
评分
参与人数 1威望 +1 收起 理由
liqibeckham + 1
查看全部评分
atua 发表于 2012-5-28 11:57 | 显示全部楼层
我猜楼主没有做约束,而且分别用了clk的上下沿打数据了,所以才会有这样的报告。
GoldSunMonkey 发表于 2012-5-28 12:03 | 显示全部楼层
应该是这个问题。否则,别的也不会出现。
 楼主| liqibeckham 发表于 2012-5-28 14:20 | 显示全部楼层
我全是用的上升沿啊,具体是什么约束呢??? 6# GoldSunMonkey
 楼主| liqibeckham 发表于 2012-5-28 14:22 | 显示全部楼层
我全是用的上升沿啊,具体是什么约束呢??? 5# atua
GoldSunMonkey 发表于 2012-5-28 14:56 | 显示全部楼层
至少有周期
nongfuxu 发表于 2012-5-29 06:41 | 显示全部楼层
有GSM在,LZ的问题指日可待。:)
jojojoy 发表于 2012-5-29 14:06 | 显示全部楼层
:dizzy:飘走。。。。
atua 发表于 2012-5-29 19:56 | 显示全部楼层
Hcount 是如何控制rom地址的?
GoldSunMonkey 发表于 2012-5-29 23:32 | 显示全部楼层
有GSM在,LZ的问题指日可待。:)
我一直在。
年轻不再 发表于 2012-5-30 20:57 | 显示全部楼层
进来学习了下。留个印。
