用fread读wav文件出错了
2186|2
G21372|  楼主 | 2012-5-28 17:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
主程序:
#include "Wave.h"
// WaveHeader.c
//void main(int argc, char **argv)
void main()
    FILE *fp=NULL;
unsigned long size;
wav_pcm_header44 hwav;
short *data;
int i;
*  Get wave header information
//fpWav = fopen(argv[1], "rb");
//fp = fopen("music_source.wav", "rb+");
//fpWav = fopen("abc.txt","r+");
// printf("Channel number: %d\n",fpWav);
if ((fp = fopen("News Item 1.wav","rb"))!=NULL)
  fread(&hwav,sizeof(wav_pcm_header44),1,fp);
// fread(&hwav, 44,1,fp);
  /* Check wave header */
  if ( (0==memcmp(hwav.ChunkID, "RIFF", 4)) &&(0==memcmp(hwav.Format, "WAVE", 4)) &&
  (0==memcmp(hwav.SubChunk1ID, "fmt ", 4)) &&(0==memcmp(hwav.SubChunk2ID, "data", 4)) &&(1==hwav.AudioFormat))
   printf("Wave audio data format:\n");
   printf("Channel number: %d\n", hwav.NumChannels);
   printf("SampleRate: %dHz\n", hwav.SampleRate);
   printf("BitsPerSample: %dbits\n", hwav.BitsPerSample);
   printf("Audio data size:%d\n", hwav.SubChun2Size);
         //printf("hwav.SubChun2Size:%d\n",hwav.ChunkID);
  *  Get wave data
  data=(short*)malloc(sizeof(short)*hwav.SubChun2Size);
  for (i=0;i<hwav.SubChun2Size;i++)
   fread(&data,sizeof(wav_pcm_header44),1,fp);
  // printf("DATA:%d\n", (&data);
  fclose(fp);
  fp = NULL;
else
  //printf("Open wave file %s failed!\n", argv[1]);
  printf("Open wave file %s failed!\n");
头文件:#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
// Microsoft wav pcm sound file format. Normal 44 bytes header
typedef struct _tagMsWavPcmHeader44{
signed char ChunkID[4]; // "RIFF"; The "RIFF" the mainchunk;
signed long ChunkSize; // FileSize - 8; The size following this data
signed char Format[4]; // "WAVE"; The "WAVE" format consists of two subchunks: "fmt " and "data"
signed char SubChunk1ID[4]; // "fmt "
signed long SubChunk1Size; // 16 for PCM. This is the size of the rest of the subchunk which follows this data.
signed short AudioFormat; // 1 for PCM. Linear quantization
signed short NumChannels; // 1->Mono, 2->stereo, etc..
signed long SampleRate; // 8000, 11025, 16000, 44100, 48000, etc..
signed long ByteRate; // = SampleRate * NumChannels * BitsPerSample/8
signed short BlockAlign; // = NumChannels * BitsPerSample / 8
signed short BitsPerSample; // 8->8bits, 16->16bits, etc..
signed char SubChunk2ID[4]; // "data"
signed long SubChun2Size; // = NumSamples * NumChannels * BitsPerSample / 8. The size of data
} wav_pcm_header44;
//void wave_generator(FILE *fp, wav_pcm_header44 *phwav);
文件头就没办法通过额 大家给看看什么问题
yangguangaisha| | 2012-5-28 17:18 | 只看该作者
把News Item 1.wav去掉空格,改成NewsItem1.wav试试
