新手请教ISE综合报告中timing的问题
3269|1
 楼主| liqibeckham 发表于 2012-5-28 19:36 | 显示全部楼层 |阅读模式
本人综合之后的timing报告如下,请高手帮忙解读一下。谢谢。
请问
Timing Summary:
Speed Grade: -7
   Minimum period: 6.286ns (Maximum Frequency: 159.076MHz)
   Minimum input arrival time before clock: 2.016ns
   Maximum output required time after clock: 5.407ns
   Maximum combinational path delay: No path found
Timing Detail:
All values displayed in nanoseconds (ns)
Timing constraint: Default period analysis for Clock 'clk'
  Clock period: 6.286ns (frequency: 159.076MHz)
  Total number of paths / destination ports: 268235 / 3680
Delay:               3.143ns (Levels of Logic = 5)
  Source:            im_show_inst/vga_inst/Hcount_6 (FF)
  Destination:       rrom/BU2/U0/blk_mem_generator/valid.cstr/has_mux_a.A/sel_pipe_1 (FF)
  Source Clock:      clk rising 0.3X
  Destination Clock: clk rising 0.7X
  Data Path: im_show_inst/vga_inst/Hcount_6 to rrom/BU2/U0/blk_mem_generator/valid.cstr/has_mux_a.A/sel_pipe_1
                                Gate     Net
    Cell:in->out      fanout   Delay   Delay  Logical Name (Net Name)
     FDC:C->Q              6   0.370   0.581  im_show_inst/vga_inst/Hcount_6 (im_show_inst/vga_inst/Hcount_6)
     LUT4_L:I0->LO         1   0.275   0.118  im_show_inst/vga_inst/Start_Video56 (im_show_inst/vga_inst/Start_Video56)
     LUT4:I2->O            2   0.275   0.416  im_show_inst/vga_inst/Start_Video57 (im_show_inst/vga_inst/Start_Video57)
     LUT4_D:I3->O          1   0.275   0.349  im_show_inst/vga_inst/Start_Video83_1 (im_show_inst/vga_inst/Start_Video83)
     LUT4:I2->O            5   0.275   0.000  mux2_1_inst/d_out<15>1 (src_addr<15>)
     begin scope: 'rrom'
     begin scope: 'BU2'
     FDE:D                     0.208          U0/blk_mem_generator/valid.cstr/has_mux_a.A/sel_pipe_1
    Total                      3.143ns (1.678ns logic, 1.465ns route)
                                       (53.4% logic, 46.6% route)
Timing constraint: Default OFFSET IN BEFORE for Clock 'clk'
  Total number of paths / destination ports: 200 / 40
Offset:              2.016ns (Levels of Logic = 3)
  Source:            rram1:douta<0> (PAD)
  Destination:       s_reg5/Q4/d_reg_0 (FF)
  Data Path: rram1:douta<0> to s_reg5/Q4/d_reg_0
                                Gate     Net
    RRAM:douta<0>          5   0.000   0.526  rram1 (dout_rram1<0>)
     LUT3:I1->O            1   0.275   0.000  mux5_5/Mmux_d_out_7 (mux5_5/Mmux_d_out_7)
     MUXF5:I0->O           1   0.303   0.430  mux5_5/Mmux_d_out_5_f5 (mux5_5/Mmux_d_out_5_f5)
     LUT3:I1->O            1   0.275   0.000  mux_sel4<2>1 (mux5_out5<0>)
     FDCE:D                    0.208          s_reg5/Q4/d_reg_0
    Total                      2.016ns (1.061ns logic, 0.955ns route)
                                       (52.6% logic, 47.4% route)
Timing constraint: Default OFFSET OUT AFTER for Clock 'clk'
  Total number of paths / destination ports: 293 / 117
Offset:              5.407ns (Levels of Logic = 5)
  Source:            rrom/BU2/U0/blk_mem_generator/valid.cstr/has_mux_a.A/sel_pipe_0 (FF)
  Destination:       B<7> (PAD)
  Source Clock:      clk rising 0.7X
  Data Path: rrom/BU2/U0/blk_mem_generator/valid.cstr/has_mux_a.A/sel_pipe_0 to B<7>
                                Gate     Net
     FDE:C->Q             16   0.370   0.766  U0/blk_mem_generator/valid.cstr/has_mux_a.A/sel_pipe_0 (U0/blk_mem_generator/valid.cstr/has_mux_a.A/sel_pipe<0>)
     LUT3:I0->O            1   0.275   0.000  U0/blk_mem_generator/valid.cstr/has_mux_a.A/Mmux_dout_mux_3 (U0/blk_mem_generator/valid.cstr/has_mux_a.A/Mmux_dout_mux_3)
     MUXF5:I1->O           1   0.303   0.429  U0/blk_mem_generator/valid.cstr/has_mux_a.A/Mmux_dout_mux_2_f5 (douta(0))
     end scope: 'BU2'
     end scope: 'rrom'
     LUT3:I1->O            3   0.275   0.397  im_show_inst/RGB_inst/B<0>1 (B_0_OBUF)
     OBUF:I->O                 2.592          B_0_OBUF (B<0>)
    Total                      5.407ns (3.815ns logic, 1.592ns route)
                                       (70.6% logic, 29.4% route)
快乐出发 发表于 2012-5-28 22:25 | 显示全部楼层
