[51单片机] 读写25LC040的问题
5039|1
 楼主| 比神乐 发表于 2024-10-21 16:10 | 显示全部楼层 |阅读模式
proteus仿真图
程序
  1. #include <reg51.h> // ??8051?????
  2. #include <intrins.h>
  3. #define uchar unsigned char
  4. #define uint  unsigned int
  5.
  6. sbit SCK=P2^0;
  7. sbit SI=P2^1;
  8. sbit SO=P2^2;
  9. sbit CS=P2^3;
  10. // ???SPI??????
  11. void SPI_Init(void); // SPI???
  12. void SPI_SendByte(unsigned char byte); // SPI??????
  13. unsigned char SPI_ReceiveByte(void); // SPI??????
  14. void SPI_CS_Low(void); // ??????
  15. void SPI_CS_High(void); // ??????
  16. unsigned char readData,readData1,readData2;
  17. // 25LC040???
  18. #define READ_INSTRUCTION  0x03 // ???(??25LC040,????????????)
  19. #define WRITE_INSTRUCTION 0x02 // ???(??,??????????)
  20. #define WREN_INSTRUCTION  0x06 // ?????
  21.
  22. // ????
  23. void EEPROM_WriteByte(unsigned char address, unsigned char date) {
  24.     SPI_CS_Low(); // ??????
  25.     SPI_SendByte(WREN_INSTRUCTION); // ???????
  26.     SPI_CS_High(); // ??????,???????(??????)
  27.
  28.     SPI_CS_Low(); // ????????
  29.     SPI_SendByte(WRITE_INSTRUCTION); // ?????
  30.     //SPI_SendByte((address >> 8) & 0xFF); // ???????(??25LC040,?????)
  31.     SPI_SendByte(address); // ???????
  32.     SPI_SendByte(date); // ????
  33.     SPI_CS_High(); // ??????,?????
  34.
  35.     // ???????????,?????EEPROM????
  36. }
  37.
  38. unsigned char EEPROM_ReadByte(unsigned char address) {
  39.     unsigned char date;
  40.
  41.     SPI_CS_Low(); // ??????
  42.     SPI_SendByte(READ_INSTRUCTION); // ?????
  43.     //SPI_SendByte((address >> 8) & 0xFF); // ???????(??25LC040,?????)
  44.     SPI_SendByte(address ); // ???????
  45.     date = SPI_ReceiveByte(); // ????
  46.     SPI_CS_High(); // ??????,?????
  47.
  48.     return date;
  49. }
  50. void EEPROM_ReadByte1(unsigned char address) {
  51.     unsigned char date;
  52.
  53.     SPI_CS_Low(); // ??????
  54.     SPI_SendByte(READ_INSTRUCTION); // ?????
  55.     //SPI_SendByte((address >> 8) & 0xFF); // ???????(??25LC040,?????)
  56.     SPI_SendByte(address ); // ???????
  57.     readData = SPI_ReceiveByte(); // ????
  58.                 readData1 = SPI_ReceiveByte();
  59.          readData2 = SPI_ReceiveByte();
  60.     SPI_CS_High(); // ??????,?????
  61.
  62.    // return date;
  63. }
  64.
  65. void main(void) {
  66.                 uint i;
  67.
  68.     SPI_Init(); // ???SPI??
  69.
  70.     // ??:?????EEPROM
  71.     EEPROM_WriteByte(0x00, 0xAB); // ???0x0000??0xAB
  72.                 for(i=0;i<10000;i++);
  73.     EEPROM_WriteByte(0x01, 0x55); // ???0x0000??0xAB
  74.                 for(i=0;i<10000;i++);
  75.                 EEPROM_WriteByte(0x02, 0x66); // ???0x0000??0xAB
  76.                 for(i=0;i<10000;i++);
  77.     // ??:?EEPROM????
  78.     EEPROM_ReadByte1(0); // ???0x0000????
  79.     P1=  readData;
  80.         _nop_();
  81.                         _nop_();
  82.                 //readData1 = EEPROM_ReadByte(0x01); // ???0x0000????
  83.     P3=  readData1;
  84.         _nop_();
  85.                         _nop_();
  86.                 //readData2 = EEPROM_ReadByte(0x02); // ???0x0000????
  87.     P0=  readData2;
  88.     // ?????????????????
  89.
  90.     while (1) {
  91.         // ???
  92.     }
  93. }
  94.
  95. // ????????SPI???????
  96. void SPI_Init(void) {
  97.     // ???SPI??,????????
  98. }
  99.
  100. void SPI_SendByte(unsigned char byte) {
  101.     // ??SPI??????
  102.                 uchar i;
  103.                 for(i=0;i<8;i++)
  104.                 {
  105.                         SCK=0;
  106.                         _nop_();
  107.                         _nop_();
  108.                         if((byte&0x80)==0x80)
  109.                                 SI=1;
  110.                         else
  111.                                 SI=0;
  112.                         _nop_();
  113.                         _nop_();
  114.                         byte<<=1;
  115.                         SCK=1;
  116.                         _nop_();
  117.                         _nop_();
  118.                 }
  119. }
  120.
  121. unsigned char SPI_ReceiveByte(void) {
  122.     // ??SPI??????
  123.                 uchar i,dat=0;
  124.         for(i;i<8;i++)
  125.         {
  126.                 dat<<=1;
  127.                 SCK=1;                        //第一位
  128.                 _nop_();
  129.                         _nop_();
  130.         SCK=0;
  131.                 _nop_();
  132.                         _nop_();
  133.                 SO=1;
  134.                 if(SO)
  135.                         dat|=1;
  136.
  137.                 _nop_();
  138.                         _nop_();
  139.
  140.         }
  141.
  142.
  143.     return dat; // ??????????????
  144. }
  145.
  146. void SPI_CS_Low(void) {
  147.     // ???????
  148.     CS = 0; // ?????????P1.0??
  149. }
  150.
  151. void SPI_CS_High(void) {
  152.     // ???????
  153.     CS = 1; // ?????????P1.0??
  154. }
只有第一次读的是对的。
请问高手,哪里错了?谢谢
XZL 发表于 2024-11-11 15:13 | 显示全部楼层
    // ??SPI??????
uhar i,dat=0;
          SO=1;
        for(i;i<8;i++)
                dat<<=1;
                SCK=1;                        //第一位
               _nop_();
               _nop_();
              if(SO)
                   dat|=1;
                 _nop_();
        SCK=0;
                 _nop_();
                 _nop_();
试试这段代码。
