求修改单片机程序
2090|3
 楼主| 2010061105 发表于 2012-5-29 12:40 | 显示全部楼层 |阅读模式
有一个单片机c程序,可能出问题了,求修改,用液晶,1602显示动态值,AD为0804八位的,显示0-100,具体程序  通过调节输入电压,显示0-100
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
uchar code table[]="WENDU:";
uchar code table1[]="SHEZHI:";
uchar code table2[]={'0','1','2','3','4','5','6','7','8','9','0'};
sbit lcden=P3^4;
sbit lcdrs=P3^5;
sbit dula=P2^6;
sbit wela=P2^7;
sbit beep=P2^3;
sbit wr=P3^6;
sbit rd=P3^7;
uchar num,A1,A2,A3;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_com(uchar com)
lcdrs=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_data(uchar date)
lcdrs=1;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init()
dula=0;
wela=0;
lcden=0;
write_com(0x38);
write_com(0x0e);
write_com(0x06);
write_com(0x01);
void start()
wr=1;
delay(20);
wr=0;
delay(20);
wr=1;
void main()
float adval,B;
while(1)
{init();
start();
delay(1000);
P1=0xff;
rd=1;
delay(10);
rd=0;
adval=P1;
rd=1;
B=adval*20/51;
    num=B;
    A1=num/100;
    A2=num%100/10;
    A3=num%10;
for(num=0;num<6;num++)
write_data(table[num]);
delay(20);
write_com(1);
write_com(0x80+0x40);
for(num=0;num<7;num++)
write_data(table1[num]);
delay(20);
write_com(0x80+0x48);
for(num=0;num<1;num++)
write_data(table2[A1]);
delay(20);
write_com(0x80+0x49);
write_data(table2[A2]);
delay(20);
write_com(0x80+0x50);
write_data(table2[A3]);
delay(20);
delay(1000);
NE5532 发表于 2012-5-29 13:14 | 显示全部楼层
无要求,无硬件电路图,无注释,看到都已经蛋疼了,楼主啊,我们不是神仙啊~!
wukunshan 发表于 2012-5-29 17:45 | 显示全部楼层
温馨提示所有单片机初学者:写C源码要有注释的习惯!利人利己。
saikita 发表于 2012-5-29 19:23 | 显示全部楼层
蛋疼的问题,就一句话和一个程序
