[经验分享] 单片机IO口模拟I2C软件驱动
1646|0
 楼主| tpgf 发表于 2024-11-4 11:18 | 显示全部楼层 |阅读模式
//延时函数
static void I2c_Delay(uint8_t count)
    uint8_t i;
    for(i = 0;i < count;i++);
//读取SDA脚位状态
static uint8_t I2c_SDAStatus(void)
    uint8_t SDA_Status;
    SDA_Status = PB06_GETVALUE();
    return SDA_Status?1:0;
//设置SDA脚为输出
void SDA_OutMode(void)
    GPIO_InitTypeDef GPIO_InitStructure = {0};
    GPIO_InitStructure.Pins = GPIO_PIN_6;
    GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_PP;
    GPIO_InitStructure.IT   = GPIO_IT_NONE;
    GPIO_Init(CW_GPIOB,&GPIO_InitStructure);
//设置SDA脚为输入
void SDA_inputMode(uint8_t InputMode)
    if(InputMode == 0)
        GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_PP;  //无下拉,只能输出低电平作ACK(2004特殊I2C协议,主机即作写数据又作ACK,最后一字节非ACK)
    else
        GPIO_InitStructure.Mode = GPIO_MODE_INPUT_PULLUP;
//I2C开始信号
void I2c_Start(void)
    SDA_OutLow;
    I2c_Delay(30);
    SCL_OutLow;
    I2c_Delay(30);
//I2C停止信号
void I2c_Stop(void)
    SCL_OutLow;
    I2c_Delay(30);
    SDA_OutLow;
    I2c_Delay(30);
    SCL_OutHigh;
    I2c_Delay(30);
    SDA_OutHigh;
//等待(从机)应答
uint8_t I2c_WaitAck(uint8_t AckFlag)
    uint8_t AckNack = 1;
    if(AckFlag)  //2004特殊I2C协议,主机即作写数据又作ACK,最后一字节非ACK
        SDA_inputMode(0);  //输入下拉,模拟假应答;主机写主机应答/非应答,从机2004识别
        SDA_OutLow;
    else
        SDA_OutHigh;
    I2c_Delay(12);
    SCL_OutHigh;
    I2c_Delay(30);
    SCL_OutLow;
    I2c_Delay(10);
    SDA_OutMode();
    I2c_Delay(5);
    return AckNack;
//发送ACK
void I2c_SendAck(void)
    SDA_OutLow;
    I2c_Delay(30);
    SCL_OutHigh;
    I2c_Delay(30);
    SCL_OutLow;
    I2c_Delay(30);
//发送NACK
void I2c_SendNack(void)
    SDA_OutHigh;
    I2c_Delay(30);
    SCL_OutHigh;
    I2c_Delay(30);
    SCL_OutLow;
    I2c_Delay(30);
//写一个字节
void I2c_WriteByte(uint8_t Byte)
    uint8_t i;
    for(i = 0;i < 8;i++)
        I2c_Delay(26);
        I2c_Delay(6);
        if(Byte&0x80)
            SDA_OutHigh;
        else
            SDA_OutLow;
        I2c_Delay(30);
        SCL_OutHigh;
        I2c_Delay(30);
        SCL_OutLow;
        Byte <<= 1;
    SCL_OutLow;
    I2c_Delay(5);
//读一个字节
uint8_t I2c_ReadByte(void)
    uint8_t i,byte;
    SDA_inputMode(0);
    I2c_Delay(5);
        byte <<= 1;
        I2c_Delay(26);
        if(I2c_SDAStatus())
           byte |= 0x01;
        I2c_Delay(26);
        SCL_OutHigh;
        I2c_Delay(26);
        SCL_OutLow;
    SDA_OutMode();
    return byte;
//连续写多个字节
void I2c_WriteNbyte(uint8_t I2C_Addr,uint8_t* data,uint8_t len)
    uint8_t j = 0;
    I2c_Start();
    I2c_WriteByte(I2C_Addr);
    I2c_WaitAck(1);
    for(j = 0;j < len;j++)
        I2c_WriteByte(data[j]);
        if(j < (len-1))
            I2c_WaitAck(1); //2004特殊I2C协议,主机写,还得主机应答
        else
            I2c_WaitAck(0); //最后一个字节NACK
    I2c_Stop();
//读取多个字节
void I2c_ReadNbyte(uint8_t I2C_Addr,uint8_t* buf,uint8_t len)
    uint8_t j;
//    I2C_Addr <<= 1;
    I2c_Start();
    I2c_WriteByte(I2C_Addr|0x01);
    if(!I2c_WaitAck(1))
        I2c_Stop();
        return;
        buf[j] = I2c_ReadByte();
        if(j != (len-1))
            I2c_SendAck();
        else
            I2c_SendNack();
    I2c_Delay(26);
    I2c_Stop();
原文链接:https://blog.csdn.net/weixin_50707044/article/details/141259267
原文链接:https://blog.csdn.net/weixin_50707044/article/details/141259766
