[STM32H5] 在STM32cubeide里面可以方便快捷的开发一个USB
1669|20
 楼主| 小兔兔啊 发表于 2024-11-13 23:39 | 显示全部楼层 |阅读模式
哈根达斯uz 发表于 2024-11-14 21:33 来自手机 | 显示全部楼层
tpgf 发表于 2024-12-3 12:44 | 显示全部楼层
/* Includes ------------------------------------------------------------------*/
#include "usbdfu.h"
/* Private variables ---------------------------------------------------------*/
USBD_HandleTypeDef hUsbDeviceFS;
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USB_DEVICE_Init(void);
int main(void)
    /* MCU Configuration--------------------------------------------------------*/
    SystemClock_Config();
    MX_GPIO_Init();
    MX_USB_DEVICE_Init();
    /* Start USB Device */
    if (HAL_USB_Start(&hUsbDeviceFS) != HAL_OK)
        Error_Handler();
    /* Infinite loop */
    while (1)
        // User code here
  * @brief System Clock Configuration
  * @retval None
    // System Clock configuration code here
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
    // GPIO initialization code here
  * @brief USB device initialization function
  * @param None
  * @retval None
    hUsbDeviceFS.Instance = USB_OTG_FS;
    hUsbDeviceFS.Init.Dev_endpoints = 6;
    hUsbDeviceFS.Init.Speed = BOTH;
    hUsbDeviceFS.Init.Mode = DEFAULT;
    hUsbDeviceFS.Init.Phy_itface = HAL_PHY_ITFACE_EMBEDDED;
    hUsbDeviceFS.Init.Data_start0 = 0x80;
    hUsbDeviceFS.Init.Data_start1 = 0x80;
    hUsbDeviceFS.Init.Data_start2 = 0x80;
    hUsbDeviceFS.Init.Data_start3 = 0x80;
    hUsbDeviceFS.Init.FIFO_size = FIFO_SIZE_16BYTES;
    hUsbDeviceFS.Init.FIFO_queue_size = FIFO_QUEUE_1;
    hUsbDeviceFS.Init.Quantum = 1;
    hUsbDeviceFS.Init.Use_dedicated_ep1 = ENABLE;
    hUsbDeviceFS.Init.Low_power_enable = ENABLE;
    if (HAL_USB_Init(&hUsbDeviceFS) != HAL_OK)
        Error_Handler();
观海 发表于 2024-12-5 17:28 | 显示全部楼层
[size=0.875]PinOut 选项卡中,找到 [size=0.875]Connectivity 部分,勾选 [size=0.875]USB_OTG 以启用USB功能
guanjiaer 发表于 2024-12-5 19:11 | 显示全部楼层
如果需要处理USB事件,可以在 [size=0.875]Core/Src/gd32f10x_it.c 文件中添加相应的中断服务程序
heimaojingzhang 发表于 2024-12-5 21:01 | 显示全部楼层
根据需要修改 [size=0.875]usbdfu.c 中的函数来实现特定的USB功能(如枚举、数据传输等)
keaibukelian 发表于 2024-12-5 22:49 | 显示全部楼层
确保正确配置了USB相关的引脚(如VBUS、DM、DP等)
paotangsan 发表于 2024-12-6 10:31 | 显示全部楼层
如果编译成功,使用STM32CubeProgrammer或其他烧录工具将程序烧录到开发板上
和下土 发表于 2024-12-30 23:52 | 显示全部楼层
在 STM32CubeIDE 中开发 USB 设备功能是非常方便的,STM32CubeIDE 集成了 STM32CubeMX 配置工具,可以通过图形化配置外设,并生成代码框架,从而加速 USB 功能的开发。
慢动作 发表于 2024-12-31 00:11 | 显示全部楼层
在STM32CubeIDE中开发USB功能相对简单
申小林一号 发表于 2024-12-31 16:09 | 显示全部楼层
感谢分享,学习一下
公羊子丹 发表于 2025-1-24 09:37 | 显示全部楼层
是的,STM32CubeIDE确实很方便,USB的开发可以通过它快速生成相关的代码框架。
周半梅 发表于 2025-1-24 09:39 | 显示全部楼层
在CubeIDE里配置USB外设也挺直观的,你可以在配置向导中选择USB主机或设备模式。
帛灿灿 发表于 2025-1-24 09:40 | 显示全部楼层
CubeIDE有自动生成USB设备中断和回调函数的功能,你直接在代码中就能看到相关模板。
童雨竹 发表于 2025-1-24 09:41 | 显示全部楼层
如果你想做USB通信,CubeMX里可以帮你快速设置USB的功能,比如CDC类或HID类。
万图 发表于 2025-1-24 09:43 | 显示全部楼层
如果你是在做USB主机,记得选好对应的驱动,CubeIDE可以自动帮助你配置好。
Wordsworth 发表于 2025-1-24 09:44 | 显示全部楼层
你可以通过STM32CubeMX配置USB外设,之后直接在CubeIDE里打开项目,进行更细致的开发。
Bblythe 发表于 2025-1-24 09:45 | 显示全部楼层
USB的开发不难,但需要留意传输速度和协议的细节,CubeIDE可以帮你减少很多重复的工作。
Pulitzer 发表于 2025-1-24 09:47 | 显示全部楼层
确保你的STM32H5的USB硬件连接没问题,CubeIDE会帮助你处理一些驱动和协议层的细节。
Uriah 发表于 2025-1-24 09:48 | 显示全部楼层
STM32CubeIDE里也有一些USB示例程序,直接用上这些可以大大缩短开发周期。
