[技术讨论] GD32F103VET6的usart2 uart3 uart4 工作不正常
694|0
 楼主| jiangwanbo 发表于 2024-11-23 12:41 | 显示全部楼层 |阅读模式
使用GD32F103VET6替代STM32F103VET6时,发现GD32F103VET6的usart2 uart3 uart4 工作不正常。
void Uart3_Init(void)
        /* enable GPIO clock */
        rcu_periph_clock_enable(RCU_GPIOC);
  /* enable USART clock */
  rcu_periph_clock_enable(RCU_UART3);
  /* connect port to USARTx_Tx */
  gpio_init(GPIOC, GPIO_MODE_OUT_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_10);
  /* connect port to USARTx_Rx */
  gpio_init(GPIOC, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_11);
        usart_deinit(UART3);
        usart_baudrate_set(UART3, 115200U);
        usart_word_length_set(UART3, USART_WL_8BIT);
        usart_stop_bit_set(UART3, USART_STB_1BIT);
        usart_parity_config(UART3, USART_PM_NONE);
        usart_hardware_flow_rts_config(UART3, USART_RTS_DISABLE);
        usart_hardware_flow_cts_config(UART3, USART_CTS_DISABLE);
        usart_receive_config(UART3, USART_RECEIVE_ENABLE);
        usart_transmit_config(UART3, USART_TRANSMIT_ENABLE);
        usart_enable(UART3);
                        //usart_data_transmit(UART3, 0X5A);
                        //usart_flag_clear(UART3, USART_FLAG_TBE);
                        //usart_flag_clear(UART3, USART_FLAG_TC);
                        usart_data_transmit(UART3, (uint8_t)0X5A);
                         //(*(volatile uint32_t *)0x40004c04) = 0x01;
                        while(RESET == usart_flag_get(UART3, USART_FLAG_TBE));
                        //usart_flag_clear(USART1, USART_FLAG_TBE);
                        //usart_flag_clear(USART0, USART_FLAG_TC);
                        usart_data_transmit(USART0, 0X5A);
                        while(RESET == usart_flag_get(USART0, USART_FLAG_TBE));
在这里usart0 可以正常输出,uart3就不可以。uart3使用usart_data_transmit(UART3, (uint8_t)0X5A)发送数据时,TBE不清空,data无变化。 我测试了USART2和uart5,同样现象。
