LINUX内核2.6.28驱动编写的问题
2316|0
 楼主| fe_arm 发表于 2009-7-15 14:19 | 显示全部楼层 |阅读模式
我写的驱动模块, 用 device_create来建立设备文件,但ls /dev找不到相对应的myalloc设备,请大家帮忙看一下
int __init memory_init(void)
    int res;
    int devno = MKDEV(MEM_MAJOR, 0);
    mem_spvm = (char *)vmalloc(MEM_MALLOC_SIZE);
    if (mem_spvm == NULL)
        printk(KERN_INFO"vmalloc failed! ");
    else
        printk(KERN_INFO"vmalloc successfully! addr=0x%x ", (unsigned int)mem_spvm);
    mem_cdev = cdev_alloc();
    if (mem_cdev == NULL)
        printk(KERN_INFO"cdev_alloc failed! ");
        return 0;
    cdev_init(mem_cdev, &mem_fops);
    mem_cdev->owner = THIS_MODULE;
    mem_cdev->ops = &mem_fops;
    res = cdev_add(mem_cdev, devno, 1);
    if (res)
        cdev_del(mem_cdev);
        mem_cdev = NULL;
        printk(KERN_INFO"cdev_add error ");
    else
        printk(KERN_INFO"cdev_add ok ");
/* creating your own class */
    my_class = class_create(THIS_MODULE, "myalloc");
    if(IS_ERR(my_class)) {
        printk("Err: failed in creating class. ");
       return -1;
/* register your own device in sysfs, and this will cause udevd to create corresponding device node */
    device_create(my_class, NULL, MKDEV(MEM_MAJOR,0), NULL, "myalloc", 0);
    return 0;
