- * FreeRTOS V202212.01
- * Copyright (C) 2020 Amazon.com, Inc. or its affiliates. All Rights Reserved.
- * Permission is hereby granted, free of charge, to any person obtaining a copy of
- * this software and associated documentation files (the "Software"), to deal in
- * the Software without restriction, including without limitation the rights to
- * use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
- * the Software, and to permit persons to whom the Software is furnished to do so,
- * subject to the following conditions:
- * The above copyright notice and this permission notice shall be included in all
- * copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
- * FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
- * COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
- * IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
- * CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
- * https://www.FreeRTOS.org
- * https://github.com/FreeRTOS
- #ifndef FREERTOS_CONFIG_H
- #define FREERTOS_CONFIG_H
- * Application specific definitions.
- * These definitions should be adjusted for your particular hardware and
- * application requirements.
- * THESE PARAMETERS ARE DESCRIBED WITHIN THE 'CONFIGURATION' SECTION OF THE
- * FreeRTOS API DOCUMENTATION AVAILABLE ON THE FreeRTOS.org WEB SITE.
- * See http://www.freertos.org/a00110.html.
- /* Ensure definitions are only used by the compiler, and not by the assembler. */
- #if defined(__ICCARM__) || defined(__CC_ARM) || defined(__GNUC__)
- #include <stdint.h>
- extern uint32_t system_core_clock;//SystemCoreClock;
- #endif
- #define configUSE_PREEMPTION 1
- #define configSUPPORT_STATIC_ALLOCATION 0//1
- #define configSUPPORT_DYNAMIC_ALLOCATION 1
- #define configUSE_IDLE_HOOK 0
- #define configUSE_TICK_HOOK 0
- #define configCPU_CLOCK_HZ (system_core_clock)//80000000//( SystemCoreClock )
- #define configTICK_RATE_HZ ( ( TickType_t ) 1000 )
- #define configMAX_PRIORITIES ( 56 )
- #define configMINIMAL_STACK_SIZE ( ( uint16_t ) 512 )
- #define configTOTAL_HEAP_SIZE ( ( size_t ) 5 * 1024 )
- #define configMAX_TASK_NAME_LEN ( 16 )
- #define configUSE_TRACE_FACILITY 1
- #define configUSE_16_BIT_TICKS 0
- #define configUSE_MUTEXES 1
- #define configQUEUE_REGISTRY_SIZE 8
- #define configUSE_RECURSIVE_MUTEXES 1
- #define configUSE_COUNTING_SEMAPHORES 1
- #define configUSE_PORT_OPTIMISED_TASK_SELECTION 0
- #define configUSE_MALLOC_FAILED_HOOK 0//1
- #define configCHECK_FOR_STACK_OVERFLOW 0//2
- /* Defaults to size_t for backward compatibility, but can be changed
- * if lengths will always be less than the number of bytes in a size_t. */
- #define configMESSAGE_BUFFER_LENGTH_TYPE size_t
- /* USER CODE END MESSAGE_BUFFER_LENGTH_TYPE */
- /* Software timer definitions. */
- #define configUSE_TIMERS 1
- #define configTIMER_TASK_PRIORITY ( 2 )
- #define configTIMER_QUEUE_LENGTH 10
- #define configTIMER_TASK_STACK_DEPTH 256
- /* Set the following definitions to 1 to include the API function, or zero
- * to exclude the API function. */
- #define INCLUDE_vTaskPrioritySet 1
- #define INCLUDE_uxTaskPriorityGet 1
- #define INCLUDE_vTaskDelete 1
- #define INCLUDE_vTaskCleanUpResources 0
- #define INCLUDE_vTaskSuspend 1
- #define INCLUDE_vTaskDelayUntil 1
- #define INCLUDE_vTaskDelay 1
- #define INCLUDE_xTaskGetSchedulerState 1
- #define INCLUDE_xTimerPendFunctionCall 0
- #define INCLUDE_xQueueGetMutexHolder 1
- #define INCLUDE_uxTaskGetStackHighWaterMark 1
- #define INCLUDE_eTaskGetState 1
- /* Cortex-M specific definitions. */
- #ifdef __NVIC_PRIO_BITS
- /* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
- #define configPRIO_BITS __NVIC_PRIO_BITS
- #else
- #define configPRIO_BITS 4
- #endif
- /* The lowest interrupt priority that can be used in a call to a "set priority"
- * function. */
- #define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 15
- /* The highest interrupt priority that can be used by any interrupt service
- * routine that makes calls to interrupt safe FreeRTOS API functions. DO NOT
- * CALL INTERRUPT SAFE FREERTOS API FUNCTIONS FROM ANY INTERRUPT THAT HAS A
- * HIGHER PRIORITY THAN THIS! (higher priorities are lower numeric values. */
- #define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
- /* Interrupt priorities used by the kernel port layer itself. These are generic
- * to all Cortex-M ports, and do not rely on any particular library functions. */
- #define configKERNEL_INTERRUPT_PRIORITY ( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << ( 8 - configPRIO_BITS ) )
- /* !!!! configMAX_SYSCALL_INTERRUPT_PRIORITY must not be set to zero !!!!
- See http://www.FreeRTOS.org/RTOS-Cortex-M3-M4.html. */
- #define configMAX_SYSCALL_INTERRUPT_PRIORITY ( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << ( 8 - configPRIO_BITS ) )
- /* Normal assert() semantics without relying on the provision of an assert.h
- * header file. */
- #define configASSERT( x ) if ( ( x ) == 0 ) { taskDISABLE_INTERRUPTS(); for( ;; ); }
- /* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
- * standard names. */
- #define vPortSVCHandler SVC_Handler
- #define xPortPendSVHandler PendSV_Handler
- //#define xPortSysTickHandler SysTick_Handler
- /* Allow system call from within FreeRTOS kernel only. */
- #define configENFORCE_SYSTEM_CALLS_FROM_KERNEL_ONLY 1
- /* STM32H743 has 16 MPU regions and therefore it is necessary to configure
- * configTOTAL_MPU_REGIONS correctly. */
- #define configTOTAL_MPU_REGIONS 16
- /* The default TEX,S,C,B setting marks the SRAM as shareable and as a result,
- * disables cache. Do not mark the SRAM as shareable because caching is being
- * used. TEX=0, S=0, C=1, B=1. */
- #define configTEX_S_C_B_SRAM ( 0x03UL )
- #endif /* FREERTOS_CONFIG_H */
3.2、fun_task.c
- #include "main.h"
- #define START_TASK_PRO 1
- #define START_STK_SIZE 64
- TaskHandle_t StartTask_Handler;
- #define TASK1_PRIO 2
- #define TASK1_STK_SIZE 64
- static TaskHandle_t Task1Task_Handler = NULL;
- #define TASK2_PRIO 3
- #define TASK2_STK_SIZE 64
- static TaskHandle_t Task2Task_Handler = NULL;
- #define TASK3_PRIO 4
- #define TASK3_STK_SIZE 64
- static TaskHandle_t Task3Task_Handler = NULL;
- void start_task(void *pvParameters);
- void task1(void *pvParameters);
- void task2(void *pvParameters);
- void task3(void *pvParameters);
- void task_create(void)
- //start_task
- xTaskCreate((TaskFunction_t )start_task,
- (const char* )"start_task",
- (uint16_t )START_STK_SIZE,
- (void* )NULL,
- (UBaseType_t )START_TASK_PRO,
- (TaskHandle_t* )&StartTask_Handler);
- vTaskStartScheduler();
- taskENTER_CRITICAL();
- //task1
- xTaskCreate((TaskFunction_t )task1,
- (const char* )"task1",
- (uint16_t )TASK1_STK_SIZE,
- (void* )NULL,
- (UBaseType_t )TASK1_PRIO,
- (TaskHandle_t* )&Task1Task_Handler);
- //task2
- xTaskCreate((TaskFunction_t )task2,
- (const char* )"task2",
- (uint16_t )TASK2_STK_SIZE,
- (void* )NULL,
- (UBaseType_t )TASK2_PRIO,
- (TaskHandle_t* )&Task2Task_Handler);
- //task3
- xTaskCreate((TaskFunction_t )task3,
- (const char* )"task3",
- (uint16_t )TASK3_STK_SIZE,
- (void* )NULL,
- (UBaseType_t )TASK3_PRIO,
- (TaskHandle_t* )&Task3Task_Handler);
- taskEXIT_CRITICAL();
- vTaskDelete(StartTask_Handler);
- //task1
- while (1)
- printf("task1 run ...\r\n");
- vTaskDelay(100);
- //task2
- while (1)
- printf("task2 run ...\r\n");
- vTaskDelay(200);
- //task3
- while (1)
- printf("task3 run ...\r\n");
- vTaskDelay(300);
3.3、main.c
- #include "main.h"
- int main(void)
- system_clock_config();
- init_usart(115200);
- delay_init();
- init_led();
- task_create();
- while(1)
四、程序运行
下载程序后,串口输出
