谁能给个430 AD转换的代码啊
1851|3
 楼主| beiwaroad 发表于 2012-5-31 18:58 | 显示全部楼层 |阅读模式
哪位大神能给个430 AD转换的程序啊?
系统是由TimerA控制的,每个脉冲到来的时候就进行一次AD转换,然后把转换的数据存起来。AD转换是单通道的。
xichengmadia 发表于 2012-5-31 19:09 | 显示全部楼层
TI官网上有例程的,你去下载过来呗~
peter_zheng 发表于 2012-6-2 21:30 | 显示全部楼层
//  MSP430F21x2 Demo - ADC10, Sample A0, 1.5V Ref, Set P1.0 if A0 > 0.2V
//  Description: A single sample is made on A0 with reference to internal
//  1.5V Vref. Software sets ADC10SC to start sample and conversion - ADC10SC
//  automatically cleared at EOC. ADC10 internal oscillator times sample (16x)
//  and conversion. In Mainloop MSP430 waits in LPM0 to save power until ADC10
//  conversion complete, ADC10_ISR will force exit from LPM0 in Mainloop on
//  reti. If A0 > 0.2V, P1.0 set, else reset.
//                MSP430F21x2
//         /|\|              XIN|-
//          --|RST          XOUT|-
//        >---|P2.0/A0      P1.0|-->LED
//  A. Dannenberg
//  Texas Instruments Inc.
//  December 2007
//  Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.41A
#include "msp430x21x2.h"
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  ADC10CTL0 = SREF_1 + ADC10SHT_2 + REFON + ADC10ON + ADC10IE;
  TACCR0 = 30;                              // Delay to allow Ref to settle
  TACCTL0 |= CCIE;                          // Compare-mode interrupt.
  TACTL = TASSEL_2 + MC_1;                  // TACLK = SMCLK, Up mode.
  __bis_SR_register(CPUOFF + GIE);          // LPM0, TA0_ISR will force exit
  TACCTL0 &= ~CCIE;                         // Disable timer Interrupt
  ADC10AE0 |= 0x01;                         // P2.0 ADC option select
  P1DIR |= 0x01;                            // Set P1.0 to output direction
  for (;;)
    ADC10CTL0 |= ENC + ADC10SC;             // Sampling and conversion start
    __bis_SR_register(CPUOFF + GIE);        // LPM0, ADC10_ISR will force exit
    if (ADC10MEM < 0x88)                    // ADC10MEM = A0 > 0.2V?
      P1OUT &= ~0x01;                       // Clear P1.0 LED off
    else
      P1OUT |= 0x01;                        // Set P1.0 LED on
// ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
  __bic_SR_register_on_exit(CPUOFF);        // Clear CPUOFF bit from 0(SR)
#pragma vector=TIMERA0_VECTOR
__interrupt void TA0_ISR(void)
  TACTL = 0;
  LPM0_EXIT;                                // Exit LPM0 on return
