{ .base = PMD, .pinPmIdx = 0U, //LED1 CFGTMR0_CH2 .pullCfg = PM_INTERNAL_PULL_NOT_ENABLED, .drvSel = PM_LOW_DRIVE_STRENGTH, .passiveFilt = false, .mux = PM_MUX_ALT2,//PM_MUX_AS_GPIO, .pinLk = false, .intCfg = PM_DMA_INT_DISABLED, .clrIntFlg = false, .gpioBase = NULL, .digitFilt = false, }, { .base = PMD, .pinPmIdx = 15U, //LED2 CFGTMR0_CH0 .pullCfg = PM_INTERNAL_PULL_NOT_ENABLED, .drvSel = PM_LOW_DRIVE_STRENGTH, .passiveFilt = false, .mux = PM_MUX_ALT2, .pinLk = false, .intCfg = PM_DMA_INT_DISABLED, .clrIntFlg = false, .gpioBase = NULL, .digitFilt = false, }, { .base = PMD, .pinPmIdx = 16U, //LED3 CFGTMR0_CH1 .pullCfg = PM_INTERNAL_PULL_NOT_ENABLED, .drvSel = PM_LOW_DRIVE_STRENGTH, .passiveFilt = false, .mux = PM_MUX_ALT2, .pinLk = false, .intCfg = PM_DMA_INT_DISABLED, .clrIntFlg = false, .gpioBase = NULL, .digitFilt = false, },三、TMR初始化 复制 CFGTMR_Init(CFGTMR0_INSTANCE, &g_cfgtmr0InitConfig, &cfgtmr0State); /* Initialize CFGTMR PWM */ CFGTMR_InitPWM(CFGTMR0_INSTANCE, &g_cfgtmr0PWMInitConfig);参数g_cfgtmr0InitConfig: 复制/* CFGTMR user initialize config */ CFGTMR_USER_CONFIG_T g_cfgtmr0InitConfig = { { .softSync = true, /* Software trigger state */ .hwSync0 = false, /* Hardware trigger 1 state */ .hwSync1 = false, /* Hardware trigger 2 state */ .hwSync2 = false, /* Hardware trigger 3 state */ .maxLoadingPoint = false, /* Max loading point state */ .minLoadingPoint = false, /* Min loading point state */ .inverterSync = CFGTMR_PWM_SYNC, /* Update mode for ICTRL register */ .outRegSync = CFGTMR_PWM_SYNC, /* Update mode for SWOCTRL register */ .maskRegSync = CFGTMR_PWM_SYNC, /* Update mode for OMASK register */ .initCounterSync = CFGTMR_PWM_SYNC, /* Update mode for INITV register */ .autoClrTrigger = true, /* Automatic clear of the trigger */ .syncPoint = CFGTMR_UPDATE_NOW, /* Synchronization point */ }, .cfgtmrMode = CFGTMR_MODE_EDGE_ALIGNED_PWM, /* Mode of operation for CFGTMR */ .BDMMode = CFGTMR_BDM_MODE_11, /* CFGTMR debug mode */ .cfgtmrPsc = CFGTMR_CLOCK_DIV_1, /* CFGTMR clock prescaler */ .cfgtmrClkSrc = CFGTMR_CLOCK_SRC_SYSTEMCLK, /* CFGTMR clock source */ .isEnableInitTrg = false, /* Initialization trigger */ .isEnableInterrupt = false, /* Interrupt state */ }; softSync:软件触发状态,设置为true表示启用软件触发。 hwSync0、hwSync1、hwSync2:硬件触发状态,分别对应硬件触发1、2、3,这里都设置为false表示禁用。 maxLoadingPoint、minLoadingPoint:最大和最小加载点状态,这里都设置为false表示禁用。 inverterSync、outRegSync、maskRegSync、initCounterSync:这些参数定义了不同寄存器的更新模式,这里都设置为CFGTMR_PWM_SYNC,表示使用PWM同步模式更新。 autoClrTrigger:自动清除触发状态,设置为true表示启用自动清除触发。 syncPoint:同步点,设置为CFGTMR_UPDATE_NOW表示立即更新。 cfgtmrMode:CFGTMR的工作模式,设置为CFGTMR_MODE_EDGE_ALIGNED_PWM表示边缘对齐PWM模式。 BDMMode:CFGTMR的调试模式,设置为CFGTMR_BDM_MODE_11。 cfgtmrPsc:CFGTMR的时钟预分频器,设置为CFGTMR_CLOCK_DIV_1表示不分频。 cfgtmrClkSrc:CFGTMR的时钟源,设置为CFGTMR_CLOCK_SRC_SYSTEMCLK表示使用系统时钟。 isEnableInitTrg:初始化触发状态,设置为false表示禁用初始化触发。 isEnableInterrupt:中断状态,设置为false表示禁用中断。 参数g_cfgtmr0PWMInitConfig: 复制/* CFGTMR PWM initialize config */ CFGTMR_PWM_PARAM_T g_cfgtmr0PWMInitConfig = { .numOfIndependentPwmChns = 3U, /* Independent PWM channels number */ .numOfCombinedPwmChns = 0U, /* cCombined PWM channels number */ .mode = CFGTMR_MODE_EDGE_ALIGNED_PWM, /* CFGTMR operation mode, Configured as PWM mode */ .uFreqHZ = 10000U, /* PWM frequency in HZ */ .deadTimeVal = 0U, /* Dead time value */ .deadTimePsc = CFGTMR_DEADTIME_DIV_1, /* Dead time prescale */ .pwmIndependentChnCfg = g_cfgtmr0PWMIndependentChannelsConfig, /* Configuration for independent PWM channels */ .pwmCombinedChnCfg = NULL, /* Configuration for combined PWM channels */ .pwmFaultCfg = &g_cfgtmr0PWMFaultConfig /* Configuration for PWM fault */ };numOfIndependentPwmChns:独立PWM通道的数量。 numOfCombinedPwmChns:组合PWM通道的数量(在这个例子中为0n,表示没有使用组合通道)。 mode:CFGTMR的操作模式,这里配置为CFGTMR_MODE_EDGE_ALIGNED_PWM,即边缘对齐PWM模式。 uFreqHZ:PWM信号的频率,以赫兹为单位。 deadTimeVal:死区时间的值。注意,如果enableDeadTime为false,则这个值将被忽略。 deadTimePsc:死区时间预分频器。它决定了死区时间的分辨率。 pwmIndependentChnCfg:指向独立PWM通道配置数组的指针。在这个例子中,它指向了一个包含单个元素的数组。 pwmCombinedChnCfg:指向组合PWM通道配置数组的指针。在这个例子中,它被设置为NULL,因为没有使用组合通道。 pwmFaultCfg:指向PWM故障配置的指针。它允许配置在检测到故障时PWM应该如何响应。 参数g_cfgtmr0PWMIndependentChannelsConfig: 复制/* CFGTMR the PWM of the independent channels config */ CFGTMR_INDEPENDENT_CHAN_PARAM_T g_cfgtmr0PWMIndependentChannelsConfig[3] = { { .hwChannelId = 0, /* Hardware channel ID */ .dutyCycle = 0x2000U, /* Duty cycle percent 0-0x8000 */ .polarity = CFGTMR_POLARITY_HIGH, /* Polarity of the PWM signal generated on MCU pin. */ .safeState = CFGTMR_LOW_STATE, /* Safe state of the PWM channel when faults are detected */ .enableSecondChnOutput = false, /* Enabled/disabled the channel (n+1) output */ .secondChnPolarity = CFGTMR_MAIN_INVERTED, /* Select channel (n+1) output relative to channel (n) */ .enableDeadTime = false, /* Enable/disable dead time */ .isExternalTrigger = false, /* Enable/disable external Trigger */ }, { .hwChannelId = 1, /* Hardware channel ID */ .dutyCycle = 0x2000U, /* Duty cycle percent 0-0x8000 */ .polarity = CFGTMR_POLARITY_HIGH, /* Polarity of the PWM signal generated on MCU pin. */ .safeState = CFGTMR_LOW_STATE, /* Safe state of the PWM channel when faults are detected */ .enableSecondChnOutput = false, /* Enabled/disabled the channel (n+1) output */ .secondChnPolarity = CFGTMR_MAIN_INVERTED, /* Select channel (n+1) output relative to channel (n) */ .enableDeadTime = false, /* Enable/disable dead time */ .isExternalTrigger = false, /* Enable/disable external Trigger */ }, { .hwChannelId = 2, /* Hardware channel ID */ .dutyCycle = 0x2000U, /* Duty cycle percent 0-0x8000 */ .polarity = CFGTMR_POLARITY_HIGH, /* Polarity of the PWM signal generated on MCU pin. */ .safeState = CFGTMR_LOW_STATE, /* Safe state of the PWM channel when faults are detected */ .enableSecondChnOutput = false, /* Enabled/disabled the channel (n+1) output */ .secondChnPolarity = CFGTMR_MAIN_INVERTED, /* Select channel (n+1) output relative to channel (n) */ .enableDeadTime = false, /* Enable/disable dead time */ .isExternalTrigger = false, /* Enable/disable external Trigger */ } }; hwChannelId:硬件通道ID,指定了哪个硬件通道将被配置为PWM输出。 dutyCycle:占空比,以十六进制表示,范围从0到0x8000,对应0%到100%的占空比。 polarity:PWM信号的极性,CFGTMR_POLARITY_HIGH 表示高电平有效,CFGTMR_POLARITY_LOW 表示低电平有效。 safeState:当检测到故障时,PWM通道的安全状态,CFGTMR_LOW_STATE 表示低电平,CFGTMR_HIGH_STATE 表示高电平。 enableSecondChnOutput:是否启用第二个通道(n+1)的输出。在某些硬件中,一个PWM通道可能伴随着一个附加的、相关的通道。 secondChnPolarity:第二个通道(n+1)相对于第一个通道(n)的极性。CFGTMR_MAIN_INVERTED 表示第二个通道的极性与第一个通道相反。 enableDeadTime:是否启用死区时间。死区时间用于防止两个互补的PWM信号同时处于高电平或低电平,从而避免短路。 isExternalTrigger:是否启用外部触发。外部触发允许PWM信号的生成由外部事件控制。 四、调节PWM周期及占空比 复制CFGTMR_UpdatePwmPeriod(CFGTMR0_INSTANCE, CFGTMR_PWM_UPDATE_IN_DUTY_CYCLE, frequencyHZ, true);复制 CFGTMR_UpdatePwmChannel( CFGTMR0_INSTANCE, g_cfgtmr0PWMIndependentChannelsConfig[0].hwChannelId, CFGTMR_PWM_UPDATE_IN_DUTY_CYCLE, dutyCycle, 0U, true); 五、while(1) 复制while (1) { /* Change PWM output frequency */ if (BTN_GetState(BUTTON_KEY1) == 0U) { frequencyHZ += 10000U; if (frequencyHZ > 100000) { frequencyHZ = 10000U; } CFGTMR_UpdatePwmPeriod(CFGTMR0_INSTANCE, CFGTMR_PWM_UPDATE_IN_DUTY_CYCLE, frequencyHZ, true); CFGTMR_UpdatePwmChannel( CFGTMR0_INSTANCE, g_cfgtmr0PWMIndependentChannelsConfig[0].hwChannelId, CFGTMR_PWM_UPDATE_IN_DUTY_CYCLE, dutyCycle, 0U, true); CFGTMR_UpdatePwmChannel( CFGTMR0_INSTANCE, g_cfgtmr0PWMIndependentChannelsConfig[1].hwChannelId, CFGTMR_PWM_UPDATE_IN_DUTY_CYCLE, dutyCycle, 0U, true); CFGTMR_UpdatePwmChannel( CFGTMR0_INSTANCE, g_cfgtmr0PWMIndependentChannelsConfig[2].hwChannelId, CFGTMR_PWM_UPDATE_IN_DUTY_CYCLE, dutyCycle, 0U, true); printf("CFGTMR PWM output frequency %dKHz.\r\n", frequencyHZ / 1000); while (BTN_GetState(BUTTON_KEY1) == 0U); } /* Change PWM output duty cycle */ if (BTN_GetState(BUTTON_KEY2) == 0U) { dutyCycle += 0x1000U; if (dutyCycle > CFGTMR_MAX_DUTY_CYCLE) { dutyCycle = 0x2000U; } CFGTMR_UpdatePwmChannel( CFGTMR0_INSTANCE, g_cfgtmr0PWMIndependentChannelsConfig[0].hwChannelId, CFGTMR_PWM_UPDATE_IN_DUTY_CYCLE, dutyCycle, 0U, true); CFGTMR_UpdatePwmChannel( CFGTMR0_INSTANCE, g_cfgtmr0PWMIndependentChannelsConfig[1].hwChannelId, CFGTMR_PWM_UPDATE_IN_DUTY_CYCLE, dutyCycle, 0U, true); CFGTMR_UpdatePwmChannel( CFGTMR0_INSTANCE, g_cfgtmr0PWMIndependentChannelsConfig[2].hwChannelId, CFGTMR_PWM_UPDATE_IN_DUTY_CYCLE, dutyCycle, 0U, true); printf("CFGTMR PWM output duty cycle %0.2f%%.\r\n", ((float)dutyCycle / CFGTMR_MAX_DUTY_CYCLE) * 100); while (BTN_GetState(BUTTON_KEY2) == 0U); } }按下B1调节PWM周期按下B2调节PWM空比 六、运行效果
收藏0 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
84
147
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
