[其他] RT-Thread函数指针块自动初始化简介
2936|8
 楼主| jcky001 发表于 2024-12-27 14:39 | 显示全部楼层 |阅读模式
环境:rt-thread 4.0.3 rt-thread studio 2.2.1 ART-Pi
定义 函数指针块
主要用于map文件标记
components.c 中
static int rti_start(void)
return 0;
INIT_EXPORT(rti_start, "0");
static int rti_board_start(void)
return 0;
INIT_EXPORT(rti_board_start, "0.end");
static int rti_board_end(void)
return 0;
INIT_EXPORT(rti_board_end, "1.end");
static int rti_end(void)
return 0;
INIT_EXPORT(rti_end, "6.end");
执行
void rt_components_board_init(void) 执行第0等级
void rt_components_init(void) 执行其余等级 rtthread.map
*(SORT(.rti_fn*))
.rti_fn.0 0x9002a5fc 0x4 ./rt-thread/src/components.o
0x9002a5fc __rt_init_rti_start
.rti_fn.0.end 0x9002a600 0x4 ./rt-thread/src/components.o
0x9002a600 __rt_init_rti_board_start
.rti_fn.1 0x9002a604 0x4 ./libraries/drivers/drv_adc.o
0x9002a604 __rt_init_STM32_adc_init
.rti_fn.1 0x9002a608 0x4 ./board/board.o
0x9002a608 __rt_init_clock_information
.rti_fn.1 0x9002a60c 0x4 ./board/drv_mpu.o
0x9002a60c __rt_init_mpu_init
.rti_fn.1 0x9002a610 0x4 ./applications/main.o
0x9002a610 __rt_init_vtor_config
.rti_fn.1.end 0x9002a614 0x4 ./rt-thread/src/components.o
0x9002a614 __rt_init_rti_board_end
.rti_fn.2 0x9002a618 0x4 ./rt-thread/components/utilities/ulog/backend/console_be.o
0x9002a618 __rt_init_ulog_console_backend_init
.rti_fn.2 0x9002a61c 0x4 ./rt-thread/components/utilities/ulog/ulog.o
0x9002a61c __rt_init_ulog_init
.rti_fn.2 0x9002a620 0x4 ./rt-thread/components/dfs/src/dfs.o
0x9002a620 __rt_init_dfs_init
.rti_fn.4 0x9002a624 0x4 ./rt-thread/components/utilities/utest/utest.o
0x9002a624 __rt_init_utest_init
.rti_fn.4 0x9002a628 0x4 ./rt-thread/components/libc/compilers/newlib/libc.o
0x9002a628 __rt_init_libc_system_init
.rti_fn.5 0x9002a62c 0x4 ./applications/uart_sample.o
0x9002a62c __rt_init_uart_dma_sample
.rti_fn.6 0x9002a630 0x4 ./rt-thread/components/finsh/shell.o
0x9002a630 __rt_init_finsh_system_init
.rti_fn.6.end 0x9002a634 0x4 ./rt-thread/src/components.o
0x9002a634 __rt_init_rti_end
0x9002a638 __rt_init_end = .
0x9002a638 . = ALIGN (0x4)
[!provide] PROVIDE (__ctors_start__, .)
怎样插入函数指针
rtdef.h 中 宏定义
/* board init routines will be called in board_init() function */
#define INIT_BOARD_EXPORT(fn) INIT_EXPORT(fn, "1")
/* pre/device/component/env/app init routines will be called in init_thread */
/* components pre-initialization (pure software initilization) */
#define INIT_PREV_EXPORT(fn) INIT_EXPORT(fn, "2")
/* device initialization */
#define INIT_DEVICE_EXPORT(fn) INIT_EXPORT(fn, "3")
/* components initialization (dfs, lwip, ...) */
#define INIT_COMPONENT_EXPORT(fn) INIT_EXPORT(fn, "4")
/* environment initialization (mount disk, ...) */
#define INIT_ENV_EXPORT(fn) INIT_EXPORT(fn, "5")
/* appliation initialization (rtgui application etc ...) */
#define INIT_APP_EXPORT(fn) INIT_EXPORT(fn, "6")
#define SECTION(x) __attribute__((section(x)))
#define RT_UNUSED __attribute__((unused))
#define RT_USED __attribute__((used))
#define ALIGN(n) __attribute__((aligned(n)))
#define RT_WEAK __attribute__((weak))
#define rt_inline static __inline
typedef int (*init_fn_t)(void);
RT_USED const init_fn_t __rt_init_##fn SECTION(".rti_fn." level) = fn
编译保留 RT_USED
函数指针 init_fn_t
函数名—宏连接 __rt_init_##fn
编译位置 SECTION(".rti_fn." level)
无法去污粉 发表于 2025-2-28 16:18 | 显示全部楼层
INIT_EXPORT 宏通常用于将一个初始化函数注册到RT-Thread系统的启动队列中,以便系统启动时按顺序调用这些初始化函数。
tpgf 发表于 2025-3-1 10:32 | 显示全部楼层
RT-Thread提供了多个自动初始化宏,用于不同类型的初始化
磨砂 发表于 2025-3-1 18:39 | 显示全部楼层
在RT-Thread中,函数指针块的自动初始化是通过一系列预定义的宏和机制来实现的
晓伍 发表于 2025-3-1 20:35 | 显示全部楼层
RT-Thread的自动初始化机制允许开发者通过特定的宏定义来声明初始化函数,这些函数将在系统启动过程中被自动调用,无需显式地在代码中逐一调用
八层楼 发表于 2025-3-2 08:02 | 显示全部楼层
在系统启动过程中,RT-Thread会遍历这些初始化函数表,并按顺序调用其中的函数,从而完成自动初始化过程
观海 发表于 2025-3-2 09:48 | 显示全部楼层
确保自动初始化的函数所在的section是连续的并且类型一致,这样才能保证从起始地址到结束地址挨个执行实现自动初始化
guanjiaer 发表于 2025-3-2 11:40 | 显示全部楼层
在使用自动初始化机制时,应注意避免函数间的依赖关系导致的初始化顺序问题
