launchpad的温度采集程序
2882|2
 楼主| gaochy1126 发表于 2012-6-4 10:48 | 显示全部楼层 |阅读模式
* 1. 第一个按钮按下后,设备过渡到应用模式
* 2. 应用模式:
* a、连续采样ADC的温度传感器通道,对比较结果初始值
* b、将PWM根据测量ADC偏移:红色发光二极管的正偏移,绿LED为负偏移
* c、发送到PC的UART通过TimerA的温度值
* d、键按一下“ - >使用当前的温度校准
* e、通过UART发送字符'',通知电脑
#include  "msp430x20x2.h"
#define     LED0                  BIT0
#define     LED1                  BIT6
#define     LED_DIR               P1DIR
#define     LED_OUT               P1OUT
#define     BUTTON                BIT3
#define     BUTTON_OUT            P1OUT
#define     BUTTON_DIR            P1DIR
#define     BUTTON_IN             P1IN
#define     BUTTON_IE             P1IE
#define     BUTTON_IES            P1IES
#define     BUTTON_IFG            P1IFG
#define     BUTTON_REN            P1REN
#define     TXD                   BIT1                      // TXD on P1.1
#define     RXD                   BIT2                      // RXD on P1.2
#define     APP_STANDBY_MODE      0   //APP待机模式
#define     APP_APPLICATION_MODE  1   //APP应用模式
#define     TIMER_PWM_MODE        0
#define     TIMER_UART_MODE       1
#define     TIMER_PWM_PERIOD      2000   //周期
#define     TIMER_PWM_OFFSET      20
#define     TEMP_SAME             0
#define     TEMP_HOT              1
#define     TEMP_COLD             2
#define     TEMP_THRESHOLD        5     //阀值
//   Conditions for 9600/4=2400 Baud SW UART, SMCLK = 1MHz
#define     Bitime_5              0x05*4                      // ~ 0.5 bit length + small 调整
#define     Bitime                13*4//0x0D
#define     UART_UPDATE_INTERVAL  1000  //Uart更新区间
unsigned char BitCnt;
unsigned char applicationMode = APP_STANDBY_MODE;
unsigned char timerMode = TIMER_PWM_MODE;
unsigned char tempMode;
unsigned char calibrateUpdate = 0;       //校准更新
unsigned char tempPolarity = TEMP_SAME;  //temp 极性
unsigned int TXByte;
/* 使用8值的移动平均滤波器采样ADC值*/
long tempMeasured[8];  //测量值
unsigned char tempMeasuredPosition=0; //测量位置
long tempAverage;      //平均值
long tempCalibrated, tempDifference;
void InitializeLeds(void);
void InitializeButton(void);
void PreApplicationMode(void);                     // 闪烁LED, 等待按键按下
void ConfigureAdcTempSensor(void);
void ConfigureTimerPwm(void);
void ConfigureTimerUart(void);
void Transmit(void);
void InitializeClocks(void);
void main(void)
  unsigned int uartUpdateTimer = UART_UPDATE_INTERVAL;  //Uart更新空间
  unsigned char i;
  WDTCTL = WDTPW + WDTHOLD;                 // 停止 WDT
  InitializeClocks();
  InitializeButton();
  InitializeLeds();
  PreApplicationMode();                     // 闪烁LED, 等待按键按下
  /* 应用模式开始 */
  applicationMode = APP_APPLICATION_MODE;
  ConfigureAdcTempSensor();                //配置ADC温度传感器
  ConfigureTimerPwm();                     //配置定时器PWM
  __enable_interrupt();                     //使能中断
  /* 主函数应用循环 */
  while(1)
    ADC10CTL0 |= ENC + ADC10SC;             // 采样和转换开始
    __bis_SR_register(CPUOFF + GIE);        // LPM0中断使能
    /* 移动平均滤波器的8个值进行采样的ADC中有所稳定 */
    tempMeasured[tempMeasuredPosition++] = ADC10MEM;
    if (tempMeasuredPosition == 8)
      tempMeasuredPosition = 0;
    tempAverage = 0;
    for (i = 0; i < 8; i++)
      tempAverage += tempMeasured[i];
      tempAverage >>= 3;                      // 除以8获得平均值,此处采用右移3位实现除以8
    if ((--uartUpdateTimer == 0) || calibrateUpdate )
      ConfigureTimerUart();
      if (calibrateUpdate)
        TXByte = 248;                       // 一个具有高值的字符, 超过温度范围
        Transmit();
      TXByte = (unsigned char)( ((tempAverage - 630) * 761) / 1024 );
      Transmit();
    tempDifference = tempAverage - tempCalibrated;
    if (tempDifference < -TEMP_THRESHOLD)
      tempDifference = -tempDifference;
      tempPolarity = TEMP_COLD;
      LED_OUT &= ~ LED1;
    else
    if (tempDifference > TEMP_THRESHOLD)
      tempPolarity = TEMP_HOT;
      LED_OUT &= ~ LED0;
    else
      TACCTL0 &= ~CCIE;
      TACCTL1 &= ~CCIE;
      LED_OUT &= ~(LED0 + LED1);
    if (tempPolarity != TEMP_SAME)
      tempDifference <<= 3;
      tempDifference += TIMER_PWM_OFFSET;
      TACCR1 = ( (tempDifference) < (TIMER_PWM_PERIOD-1) ? (tempDifference) : (TIMER_PWM_PERIOD-1) );
      TACCTL0 |= CCIE;
      TACCTL1 |= CCIE;
  LED_DIR |= LED0 + LED1;
  LED_OUT |= LED0;                          // LED的切换效果
  LED_OUT &= ~LED1;
  BCSCTL1 |= DIVA_1;                        // ACLK/2
  BCSCTL3 |= LFXT1S_2;                      // ACLK = VLO
  TACCR0 = 1200;
  TACTL = TASSEL_1 | MC_1;                  // TACLK = SMCLK, Up mode.
  TACCTL1 = CCIE + OUTMOD_3;                // TACCTL1 Capture Compare
  TACCR1 = 600;
  __bis_SR_register(LPM3_bits + GIE);       // LPM0使能中断
  unsigned char i;
  /* 配置ADC温度传感器通道 */
  ADC10CTL1 = INCH_10 + ADC10DIV_3;         // Temp Sensor ADC10CLK/4
  ADC10CTL0 = SREF_1 + ADC10SHT_3 + REFON + ADC10ON + ADC10IE;
  __delay_cycles(1000);                     // 等待选择ADC参考
  __bis_SR_register(CPUOFF + GIE);          // LPM0使能中断
  tempCalibrated = ADC10MEM;
  for (i=0; i < 8; i++)
    tempMeasured[i] = tempCalibrated;
  tempAverage = tempCalibrated;
  TACCR0 = TIMER_PWM_PERIOD;
  TACTL = TASSEL_2 | MC_1;                  // TACLK = SMCLK, 截至模式.
  TACCTL0 = CCIE;
  TACCTL1 = CCIE + OUTMOD_3;                // TACCTL1捕获比较
  TACCR1 = 1;
  timerMode = TIMER_UART_MODE;               // 配置 TimerA0 UART TX
  CCTL0 = OUT;                               // TXD Idle as Mark
  TACTL = TASSEL_2 + MC_2 + ID_3;            // SMCLK/8, 连续模式
  P1SEL |= TXD + RXD;                        //
  P1DIR |= TXD;                              //
void Transmit()
  BitCnt = 0xA;                             // 装载位计数器, 8data + ST/SP
  while (CCR0 != TAR)                       // 防止异步捕获
    CCR0 = TAR;                             // 当前TA计数器的状态
  CCR0 += Bitime;                           // 一些时间直到第一位
  TXByte |= 0x100;                          // 新增标记停止位TXByte
  TXByte = TXByte << 1;                     // 加空间的起始位
  CCTL0 =  CCIS0 + OUTMOD0 + CCIE;          // TXD = mark = idle
  while ( CCTL0 & CCIE );                   // 等待TX完成
// Timer A0 interrupt service routine
#pragma vector=TIMERA0_VECTOR
__interrupt void Timer_A (void)
  if (timerMode == TIMER_UART_MODE)
    CCR0 += Bitime;                            // 新增偏移量CCR0
    if (CCTL0 & CCIS0)                         // TX on CCI0B?
      if ( BitCnt == 0)
        CCTL0 &= ~ CCIE;                      // All bits TXed, 失能中断
      else
        CCTL0 |=  OUTMOD2;                    // TX Space
        if (TXByte & 0x01)
        CCTL0 &= ~ OUTMOD2;                   // TX Mark
        TXByte = TXByte >> 1;
        BitCnt --;
  else
    if (tempPolarity == TEMP_HOT)
      LED_OUT |= LED1;
    if (tempPolarity == TEMP_COLD)
      LED_OUT |= LED0;
    TACCTL0 &= ~CCIFG;
#pragma vector=TIMERA1_VECTOR
__interrupt void ta1_isr(void)
  TACCTL1 &= ~CCIFG;
  if (applicationMode == APP_APPLICATION_MODE)
  else
    LED_OUT ^= (LED0 + LED1);
  BCSCTL1 = CALBC1_1MHZ;                        // 设定范围
  DCOCTL = CALDCO_1MHZ;
  BCSCTL2 &= ~(DIVS_3);                         // SMCLK = DCO / 8 = 1MHz
void InitializeButton(void)                     // 配置按钮
  BUTTON_DIR &= ~BUTTON;
  BUTTON_OUT |= BUTTON;
  BUTTON_REN |= BUTTON;
  BUTTON_IES |= BUTTON;
  BUTTON_IFG &= ~BUTTON;
  BUTTON_IE |= BUTTON;
*按钮按下口中断
* 1、在待机模式:进入和退出应用模式
* 2、在应用模式:重新调整温度传感器
#pragma vector=PORT1_VECTOR
__interrupt void PORT1_ISR(void)
  BUTTON_IFG = 0;
  BUTTON_IE &= ~BUTTON;            /* 去抖 */
  WDTCTL = WDT_ADLY_250;
  IFG1 &= ~WDTIFG;                 /* 清除中断标志 */
  IE1 |= WDTIE;
    tempCalibrated = tempAverage;
    calibrateUpdate  = 1;
  else
    applicationMode = APP_APPLICATION_MODE; // 从待机状态切换到应用模式
    __bic_SR_register_on_exit(LPM3_bits);
#pragma vector=WDT_VECTOR
__interrupt void WDT_ISR(void)
    IE1 &= ~WDTIE;                   /* 失能中断 */
    WDTCTL = WDTPW + WDTHOLD;        /* 使 WDT 返回至保持状态 */
    BUTTON_IE |= BUTTON;             /* 去抖完成 */
// ADC10中断服务程序
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR (void)
  __bic_SR_register_on_exit(CPUOFF);        // 返回到Active模式
hjyt008 发表于 2012-6-5 09:01 | 显示全部楼层
哇~~~~~~好复杂啊,你是怎么看懂的啊?
~遥望~ 发表于 2013-1-7 10:43 | 显示全部楼层
是不是板子里面自带的那个程序?
