[应用相关]
使用STM32 USB HID接口模拟键盘发送按键数据
636|3
1. 实现功能描述
实现通过STM32通过USB接口模拟键盘发送按键数据,这里模拟的数据限制在16进制数值,即:
0 - 9
A - F
数据范围 0x00 - 0x0F
2. USB HID 接口设置
使用芯片:STM32F103C8T6
USB 设置
USB HID 设置
3. HID代码修改
找到 usbd_hid.c
修改 nInterfaceProtocol 的值为 1=keyboard
修改 __ALIGN_BEGIN static uint8_t USBD_HID_CfgFSDesc[USB_HID_CONFIG_DESC_SIZ] __ALIGN_END 中 nInterfaceProtocol 的值为 1=keyboard
__ALIGN_BEGIN static uint8_t USBD_HID_CfgFSDesc[USB_HID_CONFIG_DESC_SIZ]  __ALIGN_END =
  0x09, /* bLength: Configuration Descriptor size */
  USB_DESC_TYPE_CONFIGURATION, /* bDescriptorType: Configuration */
  USB_HID_CONFIG_DESC_SIZ,
  /* wTotalLength: Bytes returned */
  0x00,
  0x01,         /*bNumInterfaces: 1 interface*/
  0x01,         /*bConfigurationValue: Configuration value*/
  0x00,         /*iConfiguration: Index of string descriptor describing
  the configuration*/
  0xE0,         /*bmAttributes: bus powered and Support Remote Wake-up */
  0x32,         /*MaxPower 100 mA: this current is used for detecting Vbus*/
  /************** Descriptor of Joystick Mouse interface ****************/
  /* 09 */
  0x09,         /*bLength: Interface Descriptor size*/
  USB_DESC_TYPE_INTERFACE,/*bDescriptorType: Interface descriptor type*/
  0x00,         /*bInterfaceNumber: Number of Interface*/
  0x00,         /*bAlternateSetting: Alternate setting*/
  0x01,         /*bNumEndpoints*/
  0x03,         /*bInterfaceClass: HID*/
  0x01,         /*bInterfaceSubClass : 1=BOOT, 0=no boot*/
  0x01,         /*nInterfaceProtocol : 0=none, 1=keyboard, 2=mouse*/
  0,            /*iInterface: Index of string descriptor*/
  /******************** Descriptor of Joystick Mouse HID ********************/
  /* 18 */
  0x09,         /*bLength: HID Descriptor size*/
  HID_DESCRIPTOR_TYPE, /*bDescriptorType: HID*/
  0x11,         /*bcdHID: HID Class Spec release number*/
  0x01,
  0x00,         /*bCountryCode: Hardware target country*/
  0x01,         /*bNumDescriptors: Number of HID class descriptors to follow*/
  0x22,         /*bDescriptorType*/
  HID_MOUSE_REPORT_DESC_SIZE,/*wItemLength: Total length of Report descriptor*/
  0x00,
  /******************** Descriptor of Mouse endpoint ********************/
  /* 27 */
  0x07,          /*bLength: Endpoint Descriptor size*/
  USB_DESC_TYPE_ENDPOINT, /*bDescriptorType:*/
  HID_EPIN_ADDR,     /*bEndpointAddress: Endpoint Address (IN)*/
  0x03,          /*bmAttributes: Interrupt endpoint*/
  HID_EPIN_SIZE, /*wMaxPacketSize: 4 Byte max */
  0x00,
  HID_FS_BINTERVAL,          /*bInterval: Polling Interval */
  /* 34 */
修改__ALIGN_BEGIN static uint8_t USBD_HID_CfgHSDesc[USB_HID_CONFIG_DESC_SIZ] __ALIGN_END 中 nInterfaceProtocol 的值为 1=keyboard
__ALIGN_BEGIN static uint8_t USBD_HID_CfgHSDesc[USB_HID_CONFIG_DESC_SIZ]  __ALIGN_END =
  0x00,
  the configuration*/
  /* 09 */
  /* 18 */
  0x01,
  0x00,
  /* 27 */
  0x00,
  HID_HS_BINTERVAL,          /*bInterval: Polling Interval */
  /* 34 */
修改__ALIGN_BEGIN static uint8_t USBD_HID_OtherSpeedCfgDesc[USB_HID_CONFIG_DESC_SIZ] __ALIGN_END 中 nInterfaceProtocol 的值为 1=keyboard
__ALIGN_BEGIN static uint8_t USBD_HID_OtherSpeedCfgDesc[USB_HID_CONFIG_DESC_SIZ]  __ALIGN_END =
  0x00,
  the configuration*/
  /* 09 */
  /* 18 */
  0x01,
  0x00,
  /* 27 */
  0x00,
  /* 34 */
修改键值描述长度 及 键值描述代码
// HID_MOUSE_REPORT_DESC_SIZE 鼠标的报告长度,鼠标按键少,键盘按键多,根据键盘按键修改该数值为63U
//以下为修改后的报告函数
__ALIGN_BEGIN static uint8_t HID_MOUSE_ReportDesc[HID_MOUSE_REPORT_DESC_SIZE] __ALIGN_END =
    0x05, 0x01,                    // USAGE_PAGE (Generic Desktop)
    0x09, 0x06,                    // USAGE (Keyboard)
    0xa1, 0x01,                    // COLLECTION (Application)
    0x05, 0x07,                    //   USAGE_PAGE (Keyboard)
    0x19, 0xe0,                    //   USAGE_MINIMUM (Keyboard LeftControl)
    0x29, 0xe7,                    //   USAGE_MAXIMUM (Keyboard Right GUI)
    0x15, 0x00,                    //   LOGICAL_MINIMUM (0)
    0x25, 0x01,                    //   LOGICAL_MAXIMUM (1)
    0x75, 0x01,                    //   REPORT_SIZE (1)
    0x95, 0x08,                    //   REPORT_COUNT (8)
    0x81, 0x02,                    //   INPUT (Data,Var,Abs)
    0x95, 0x01,                    //   REPORT_COUNT (1)
    0x75, 0x08,                    //   REPORT_SIZE (8)
    0x81, 0x03,                    //   INPUT (Cnst,Var,Abs)
    0x95, 0x05,                    //   REPORT_COUNT (5)
    0x05, 0x08,                    //   USAGE_PAGE (LEDs)
    0x19, 0x01,                    //   USAGE_MINIMUM (Num Lock)
    0x29, 0x05,                    //   USAGE_MAXIMUM (Kana)
    0x91, 0x02,                    //   OUTPUT (Data,Var,Abs)
    0x75, 0x03,                    //   REPORT_SIZE (3)
    0x91, 0x03,                    //   OUTPUT (Cnst,Var,Abs)
    0x95, 0x06,                    //   REPORT_COUNT (6)
    0x25, 0x65,                    //   LOGICAL_MAXIMUM (101)
    0x19, 0x00,                    //   USAGE_MINIMUM (Reserved (no event indicated))
    0x29, 0x65,                    //   USAGE_MAXIMUM (Keyboard Application)
    0x81, 0x00,                    //   INPUT (Data,Ary,Abs)
    0xc0                           // END_COLLECTION
4. 模拟键盘发送数据
使用函数: USBD_HID_SendReport(&hUsbDeviceFS, sendBuffer, 8);
发送数字
keyout_buff[0] = 0x00;   //是否使用shift  0x00 no  0x02 yes
keyout_buff[2] = 0x27;   //数字0  数字1为0x1E,1-9依次加1
USBD_HID_SendReport(&hUsbDeviceFS, keyout_buff, 8);
HAL_Delay(15);
//clear  发送全0数组结束本次发送
keyout_buff[2] = 0x00;
HAL_Delay(15);
发送字母
keyout_buff[0] = 0x02;  //是否开启大写字母 0x00 不开启 0x02 开启
keyout_buff[2] = 0x04;  //字母a a-z 依次累加1
HAL_Delay(15);
HAL_Delay(15);
原文链接:https://blog.csdn.net/uyoev123abc/article/details/145156522
SophiaOP| | 2025-1-22 20:06 | 只看该作者
103是不是不能做主机啊?
我爱台妹mmd| | 2025-1-31 23:51 | 只看该作者
模拟 USB HID 键盘设备
