[开发工具] Khazama AVR Programmer
1157|1
 楼主| zhuomuniao110 发表于 2025-1-22 13:44 | 显示全部楼层 |阅读模式
You can set your settings according to your project. this steps will execute after you push "Auto Program" button on the main window or press CTRL+P shortcut.
from version 1.7.0 you can override chip signature check (for example for ATMega48 and ATMega48PA chip signatures are different but with overriding sign check you can program this chips truly). you can change programing clock speed too.
Fuses and Lock window help you to set settings for AVR chips.All settings are documented and can select easily from combos or set directly from check boxes.
zhuotuzi 发表于 2025-1-24 17:13 | 显示全部楼层
应该是支持老版本的型号吧。
