[DemoCode下载]
定时器捕获应用
1209|2
xinxianshi|  楼主 | 2025-1-25 13:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 3 $
* $Date: 15/02/06 10:22a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Show how to use the timer1 capture function to capture timer1 counter value.
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M058S.h"
#define PLL_CLOCK           50000000
/* Global Interface Variables Declarations        */
volatile uint32_t g_au32TMRINTCount[4] = {0};
* @brief       Timer0 IRQ
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The Timer0 default IRQ, declared in startup_M058S.s.
void TMR0_IRQHandler(void)
    /* Clear Timer0 time-out interrupt flag */
    TIMER_ClearIntFlag(TIMER0);
    g_au32TMRINTCount[0]++;
* @brief       Timer1 IRQ
* @param       None
* @return      None
* @details     The Timer1 default IRQ, declared in startup_M058S.s.
void TMR1_IRQHandler(void)
    if(TIMER_GetCaptureIntFlag(TIMER1) == 1)
        /* Clear Timer1 capture interrupt flag */
        TIMER_ClearCaptureIntFlag(TIMER1);
        g_au32TMRINTCount[1]++;
* @brief       Timer2 IRQ
* @param       None
* @return      None
* @details     The Timer2 default IRQ, declared in startup_M058S.s.
void TMR2_IRQHandler(void)
    /* Clear Timer2 time-out interrupt flag */
    TIMER_GetIntFlag(TIMER2);
    g_au32TMRINTCount[2]++;
* @brief       Timer3 IRQ
* @param       None
* @return      None
* @details     The Timer3 default IRQ, declared in startup_M058S.s.
void TMR3_IRQHandler(void)
    /* Clear Timer3 time-out interrupt flag */
    TIMER_GetIntFlag(TIMER3);
    g_au32TMRINTCount[3]++;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to HIRC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(TMR0_MODULE);
    CLK_EnableModuleClock(TMR1_MODULE);
    CLK_EnableModuleClock(TMR3_MODULE);
    /* Peripheral clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
    CLK_SetModuleClock(TMR0_MODULE, CLK_CLKSEL1_TMR0_S_HXT, 0);
    CLK_SetModuleClock(TMR1_MODULE, CLK_CLKSEL1_TMR1_S_HCLK, 0);
    CLK_SetModuleClock(TMR3_MODULE, CLK_CLKSEL1_TMR3_S_HXT, 0);
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD, TXD, T0, T1 and T1EX */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk | SYS_MFP_P34_Msk | SYS_MFP_P35_Msk | SYS_MFP_P33_Msk);
                SYS->P3_MFP |= (SYS_MFP_P30_RXD | SYS_MFP_P31_TXD | SYS_MFP_P34_T0 | SYS_MFP_P35_T1 | SYS_MFP_P33_T1EX);
    /* Set P1 multi-function pins for T3 */
    SYS->P1_MFP &= ~SYS_MFP_P11_Msk;
    SYS->P1_MFP |= SYS_MFP_P11_T3;
void UART0_Init(void)
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  MAIN function        */
int main(void)
    volatile uint32_t u32InitCount;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
    printf("+---------------------------------------------------+\n");
    printf("|    Timer External Capture Function Sample Code    |\n");
    printf("+---------------------------------------------------+\n\n");
    printf("# Timer Settings:\n");
    printf("  Timer0: Clock source is 12 MHz; Toggle-output mode and frequency is 500 Hz.\n");
    printf("  Timer3: Clock source is 12 MHz; Toggle-output mode and frequency is 1 Hz.\n");
    printf("  Timer1: Clock source is HCLK(50 MHz); Continuous counting mode; TCMP is 0xFFFFFF;\n");
    printf("          Counter pin enable; Capture pin and capture interrupt enable;\n");
    printf("# Generate 500 Hz frequency from T0 and connect T0 pin to Timer1 counter pin.\n");
    printf("# Generate 1 Hz frequency from T3 and connect T3 pin to T1EX capture pin.\n");
    printf("# Get 500 event counts from Timer1 counter pin when each T1EX pin interrupt occurred.\n\n");
    /* Initial Timer0 and Timer3 default setting */
    TIMER_Open(TIMER0, TIMER_TOGGLE_MODE, 1000);
    TIMER_Open(TIMER3, TIMER_TOGGLE_MODE, 2);
    /* Initial Timer1 default setting */
    TIMER_Open(TIMER1, TIMER_CONTINUOUS_MODE, 1);
    /* Configure Timer1 setting for external counter input and capture function */
    TIMER_SET_PRESCALE_VALUE(TIMER1, 0);
    TIMER_SET_CMP_VALUE(TIMER1, 0xFFFFFF);
    TIMER_EnableEventCounter(TIMER1, TIMER_COUNTER_FALLING_EDGE);
    TIMER_EnableCapture(TIMER1, TIMER_CAPTURE_FREE_COUNTING_MODE, TIMER_CAPTURE_FALLING_EDGE);
    TIMER_EnableCaptureInt(TIMER1);
    /* Enable Timer1 NVIC */
    NVIC_EnableIRQ(TMR1_IRQn);
    /* Clear Timer1 interrupt counts to 0 */
    u32InitCount = g_au32TMRINTCount[1] = 0;
    /* Start Timer0, Timer1 and Timer3 counting */
    TIMER_Start(TIMER0);
    TIMER_Start(TIMER1);
    TIMER_Start(TIMER3);
    /* Check T1EX interrupt counts */
    while(g_au32TMRINTCount[1] <= 10)
        if(g_au32TMRINTCount[1] != u32InitCount)
            printf("[%2d] - %4d\n", g_au32TMRINTCount[1], TIMER_GetCaptureData(TIMER1));
            u32InitCount = g_au32TMRINTCount[1];
    /* Stop Timer0, Timer1 and Timer3 counting */
    TIMER_Close(TIMER0);
    TIMER_Close(TIMER1);
    TIMER_Close(TIMER3);
    printf("*** PASS ***\n");
    while(1);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
你用过定时器捕获这个功能吗?
xinxianshi|  楼主 | 2025-1-25 13:12 | 只看该作者
 通过TCAP (定时器捕捉数据寄存器)可读取 24 位捕捉计数器的值
 支持外部管脚捕捉(T0EX~T3EX),可用于脉宽测量
 支持外部引脚捕捉(T0EX~T3EX),可用于复位24位向上定时器
