想用gstreamer 改变音频格式播放到alsa声卡总是失败
1837|0
 楼主| 岳佳佳 发表于 2025-2-24 15:19 | 显示全部楼层 |阅读模式
我的目标,想把一个raw data音频文件,将浮点型32位转化为S16_LE格式,但是总是出错,deepseek来来回回就那么试,人已经麻了,求各位大佬帮助
这是我的命令
gst-launch-1.0 filesrc location=/data/7_1.pcm ! capsfilter caps=audio/x-raw,
format=F32LE,rate=48000,channels=8,layout=interleaved,channel-mask=0x0000007f,en
dianness=1 ! audioconvert ! capsfilter caps=audio/x-raw,format=S16LE,rate=48000,
channels=8,layout=interleaved,channel-mask=0x0000007f,endianness=1 ! alsasink de
vice=hw:0,1
下面是日志输出:
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
ERROR: from element /GstPipeline:pipeline0/GstCapsFilter:capsfilter0: Filter caps do not completely specify the output format
Additional debug info:
../plugins/elements/gstcapsfilter.c(453): gst_capsfilter_prepare_buf (): /GstPipeline:pipeline0/GstCapsFilter:capsfilter0:
Output caps are unfixed: EMPTY
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
Freeing pipeline ...
