Low-Speed Magnetic Angle Encoder IC MagnTek's low-speed magnetic angle encoder IC integrates high-precision AMR sensing elements with a dedicated decoding processing chip, achieving angle detection accuracy within ±1°. With a minimum package size of 3mm x 3mm, it meets the size requirements of most applications. Meanwhile, the non-contact magnetic sensing control offers high reliability, with a maximum operating temperature range of -40 to 125°C. It features traditional ABZ/UVW incremental outputs, as well as analog output and multiple output interfaces such as IC, SPL, and PWM. Recommended Applications: Pan-tilt systems, servos, robotic joint control, stepper motor control, and more.
