这程序有什么问题
1635|5
 楼主| yszong 发表于 2012-6-6 20:11 | 显示全部楼层 |阅读模式
#include <reg52.h>
void main (void)
  uchar reg_rddata;
  LCD_Reset();
  LCD_Initial();
  LCD_CLR();
  WriteDataToREG(0x00,0xcd);
  SetXY(0x00,0x00);
  Display_Chinese(tab1,160);
  reg_rddata = ReadDataFromREG(0xa0);
  reg_rddata |= 0x04;            //致能触摸中断
  WriteDataToREG(0xa0,reg_rddata);
  IT0=0;
  //EA=1;
  //EX0=1;
  while(1)
  if(reg_rddata & 0x40)
    reg_rddata &= 0xfb;            //禁能触摸中断
    get_touch();       //接收触摸键程序
     if(key_fg)
            key_fg=0x00;
            key_x2=key_x1;key_x1=touchx/100;
            key_y2=key_y1;key_y1=touchy/100;
            Delay_Nms(20);
           if((key_x2!= key_x1)||(key_y2!=key_y1)) continue;
            key= xytab[(key_y1-1)*7+key_x1-1];
             switch(key)    //判触摸地号11----77
             {    case 31:
                  case 32:
                  case 33:
                  case 34:
                  case 35:
                  case 36:
                  case 37:  {WriteDataToREG(0x10,0x2b);    //显示图形1
                               WriteDataToREG(0x00,0xc5);
                               lcd_photo(tab4);
                               Delay_Nms (3000);break;  }
                  case 41:
                  case 42:
                  case 43:
                  case 44:
                  case 45:
                  case 46:    //下面是显示文字
                  case 47:  {  WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                               WriteDataToREG(0x00,0xc5); //0xcd写文字,0xc5写图形
                                lcd_photo(tab5);
                               Delay_Nms (3000);break; }   //
                  case 51:   //下面可以增加
                  case 52:
                  case 53:
                  case 54:
                  case 55:
                  case 56:
                  case 57:  {WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                                lcd_photo(tab6);
                  case 61:
                  case 62:
                  case 63:
                  case 64:
                  case 65:
                  case 66:
                  case 67:  {WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                                lcd_photo(tab7);
                  case 71:
                  case 72:
                  case 73:
                  case 74:
                  case 75:
                  case 76:
                  case 77:  {WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                                lcd_photo(tab8);
                               Delay_Nms (3000);break; }   // 减键
jiahy 发表于 2012-6-6 20:12 | 显示全部楼层
你就不能将switch(key)
改成
switch(key / 10)
       case 3 :{WriteDataToREG(0x10,0x2b);    //显示图形1
                               lcd_photo(tab4);
       case 4 :{  WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                                lcd_photo(tab5);
       case 5 :{WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                                lcd_photo(tab6);
       case 6 :{WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                                lcd_photo(tab7);
       case 7 :{WriteDataToREG(0x10,0x2b); //2b写汉字,3d写英文(粗字),
                                lcd_photo(tab8);
       default :
              break;
吗?
lizye 发表于 2012-6-6 20:13 | 显示全部楼层
这大程序看得我头疼
shimx 发表于 2012-6-6 20:14 | 显示全部楼层
2楼正解
 楼主| yszong 发表于 2012-6-6 20:16 | 显示全部楼层
懂了,谢谢
 楼主| yszong 发表于 2012-6-6 20:17 | 显示全部楼层
结贴了
