creator 运行问题
1753|3
 楼主| 冰清玉洁 发表于 2012-6-6 23:11 | 显示全部楼层 |阅读模式
我装了PSOC creator ,运行后老出现问题,弹出如下界面
wenfen 发表于 2012-6-6 23:13 | 显示全部楼层
Please follow the steps below to fix this:
- Windows - >Start  -> Run "regedit" ;
- Find the register can and check the value of  HKEY_CURRENT_USER\Control Panel\Desktop\MenuShowDelay ;
- If it is  zero, change it to greater than zero;
- Rstart the computer for the change to take effect.
参考:https://bbs.21ic.com/viewthread.p ... p;highlight=creator
 楼主| 冰清玉洁 发表于 2012-6-6 23:15 | 显示全部楼层
我回去研究研究
先结贴了
