[AVR单片机] avr-gcc内使用大数组的问题,请高手指教!
4066|6
 楼主| cyh537 发表于 2007-3-1 20:05 | 显示全部楼层 |阅读模式
我打算把16*8英文字库定义成一个大数组,可是在使用这个字库的时候,发现只有前面128个字节数据 可以正常使用,后面的数据读出来的都是0x00 0x01 0xff一些莫名奇妙的的数据.不知道是不是我的avr-gcc编译器没有设置好啊.代码如下,请做过的兄弟指点一下,先谢了.
 const unsigned char acFont[] =
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0f,0x08,
  0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0xf8,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,
  0x08,0x08,0x08,0x08,0x0f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,
  0x08,0x08,0x08,0x08,0x08,0x08,0x08,0xf8,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,
  0x08,0x08,0x08,0x08,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,
  0x3c,0x7e,0x7e,0x7e,0x3c,0x18,0x00,0x00,0x00,0x00,0x00,0xff,0xff,
  0xff,0xff,0xe7,0xc3,0x81,0x81,0x81,0xc3,0xe7,0xff,0xff,0xff,0xff,
  0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0x05,0x05,0x09,
  0x09,0x10,0x10,0x38,0x44,0x44,0x44,0x38,0x00,0x00,0x00,0x00,0x1c,
  0x22,0x22,0x22,0x1c,0x08,0x08,0x7f,0x08,0x08,0x08,0x08,0x00,0x00,
  0x00,0x00,0x00,0x00,0x03,0x1d,0x11,0x13,0x1d,0x11,0x11,0x11,0x13,
  0x17,0x36,0x70,0x60,0x00,0x00,0x00,0x08,0x08,0x5d,0x22,0x22,0x22,
  0x63,0x22,0x22,0x22,0x5d,0x08,0x08,0x00,0x00,0x08,0x08,0x08,0x08,
  0x08,0x08,0x08,0x08,0xff,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x00,
  0x00,0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0x3f,0x1f,0x0f,0x07,0x03,
  0x01,0x00,0x00,0x08,0x1c,0x2a,0x08,0x08,0x08,0x08,0x08,0x08,0x08,
  0x08,0x2a,0x1c,0x08,0x00,0x00,0x00,0x24,0x24,0x24,0x24,0x24,0x24,
  0x24,0x24,0x24,0x00,0x00,0x24,0x24,0x00,0x00,0x00,0x1f,0x25,0x45,
  0x45,0x45,0x25,0x1d,0x05,0x05,0x05,0x05,0x05,0x00,0x00,0x08,0x08,
  0x08,0x08,0x08,0x08,0x08,0x08,0xff,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xff,0x08,0x08,0x08,
  0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0xf8,
  0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x08,0x1c,0x2a,0x08,0x08,
  0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x08,0x08,0x08,
  0x08,0x08,0x08,0x08,0x08,0x0f,0x08,0x08,0x08,0x08,0x08,0x08,0x08,
  0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x02,0x7f,0x02,0x04,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x20,0x7f,0x20,
  0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x10,
  0x10,0x10,0x10,0x10,0x10,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x12,
  0x36,0x24,0x48,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x24,0x24,0x24,0xfe,0x48,0x48,0x48,0xfe,0x48,
  0x48,0x48,0x00,0x00,0x00,0x00,0x10,0x38,0x54,0x54,0x50,0x30,0x18,
  0x14,0x14,0x54,0x54,0x38,0x10,0x10,0x00,0x00,0x00,0x44,0xa4,0xa8,
  0xa8,0xa8,0x54,0x1a,0x2a,0x2a,0x2a,0x44,0x00,0x00,0x00,0x00,0x00,
  0x30,0x48,0x48,0x48,0x50,0x6e,0xa4,0x94,0x88,0x89,0x76,0x00,0x00,
  0x00,0x60,0x60,0x20,0xc0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x02,0x04,0x08,0x08,0x10,0x10,0x10,0x10,0x10,
  0x10,0x08,0x08,0x04,0x02,0x00,0x00,0x40,0x20,0x10,0x10,0x08,0x08,
  0x08,0x08,0x08,0x08,0x10,0x10,0x20,0x40,0x00,0x00,0x00,0x00,0x00,
  0x10,0x10,0xd6,0x38,0x38,0xd6,0x10,0x10,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x10,0x10,0x10,0x10,0xfe,0x10,0x10,0x10,0x10,0x00,
  0x7f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x60,0x00,0x00,0x00,0x00,
  0x01,0x02,0x02,0x04,0x04,0x08,0x08,0x10,0x10,0x20,0x20,0x40,0x40,
  0x00,0x00,0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x42,0x42,0x42,0x42,
  0x24,0x18,0x00,0x00,0x00,0x00,0x00,0x10,0x70,0x10,0x10,0x10,0x10,
  0x10,0x10,0x10,0x10,0x7c,0x00,0x00,0x00,0x00,0x00,0x3c,0x42,0x42,
  0x42,0x04,0x04,0x08,0x10,0x20,0x42,0x7e,0x00,0x00,0x00,0x00,0x00,
  0x3c,0x42,0x42,0x04,0x18,0x04,0x02,0x02,0x42,0x44,0x38,0x00,0x00,
  0x00,0x00,0x00,0x04,0x0c,0x14,0x24,0x24,0x44,0x44,0x7e,0x04,0x04,
  0x1e,0x00,0x00,0x00,0x00,0x00,0x7e,0x40,0x40,0x40,0x58,0x64,0x02,
  0x02,0x42,0x44,0x38,0x00,0x00,0x00,0x00,0x00,0x1c,0x24,0x40,0x40,
  0x58,0x64,0x42,0x42,0x42,0x24,0x18,0x00,0x00,0x00,0x00,0x00,0x7e,
  0x44,0x44,0x08,0x08,0x10,0x10,0x10,0x10,0x10,0x10,0x00,0x00,0x00,
  0x00,0x00,0x3c,0x42,0x42,0x42,0x24,0x18,0x24,0x42,0x42,0x42,0x3c,
  0x00,0x00,0x00,0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x26,0x1a,0x02,
  0x02,0x24,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,
  0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x10,0x10,0x20,0x00,0x00,
  0x00,0x02,0x04,0x08,0x10,0x20,0x40,0x20,0x10,0x08,0x04,0x02,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfe,0x00,0x00,0x00,0xfe,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x20,0x10,0x08,0x04,0x02,
  0x04,0x08,0x10,0x20,0x40,0x00,0x00,0x00,0x00,0x00,0x3c,0x42,0x42,
  0x62,0x02,0x04,0x08,0x08,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x00,
  0x38,0x44,0x5a,0xaa,0xaa,0xaa,0xaa,0xb4,0x42,0x44,0x38,0x00,0x00,
  0x00,0x00,0x00,0x10,0x10,0x18,0x28,0x28,0x24,0x3c,0x44,0x42,0x42,
  0xe7,0x00,0x00,0x00,0x00,0x00,0xf8,0x44,0x44,0x44,0x78,0x44,0x42,
  0x42,0x42,0x44,0xf8,0x00,0x00,0x00,0x00,0x00,0x3e,0x42,0x42,0x80,
  0x80,0x80,0x80,0x80,0x42,0x44,0x38,0x00,0x00,0x00,0x00,0x00,0xf8,
  0x44,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x44,0xf8,0x00,0x00,0x00,
  0x00,0x00,0xfc,0x42,0x48,0x48,0x78,0x48,0x48,0x40,0x42,0x42,0xfc,
  0x00,0x00,0x00,0x00,0x00,0xfc,0x42,0x48,0x48,0x78,0x48,0x48,0x40,
  0x40,0x40,0xe0,0x00,0x00,0x00,0x00,0x00,0x3c,0x44,0x44,0x80,0x80,
  0x80,0x8e,0x84,0x44,0x44,0x38,0x00,0x00,0x00,0x00,0x00,0xe7,0x42,
  0x42,0x42,0x42,0x7e,0x42,0x42,0x42,0x42,0xe7,0x00,0x00,0x00,0x00,
  0x00,0x7c,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x7c,0x00,
  0x00,0x00,0x00,0x00,0x3e,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,
  0x08,0x08,0x88,0xf0,0x00,0x00,0x00,0xee,0x44,0x48,0x50,0x70,0x50,
  0x48,0x48,0x44,0x44,0xee,0x00,0x00,0x00,0x00,0x00,0xe0,0x40,0x40,
  0x40,0x40,0x40,0x40,0x40,0x40,0x42,0xfe,0x00,0x00,0x00,0x00,0x00,
  0xee,0x6c,0x6c,0x6c,0x6c,0x54,0x54,0x54,0x54,0x54,0xd6,0x00,0x00,
  0x00,0x00,0x00,0xc7,0x62,0x62,0x52,0x52,0x4a,0x4a,0x4a,0x46,0x46,
  0xe2,0x00,0x00,0x00,0x00,0x00,0x38,0x44,0x82,0x82,0x82,0x82,0x82,
  0x82,0x82,0x44,0x38,0x00,0x00,0x00,0x00,0x00,0xfc,0x42,0x42,0x42,
  0x42,0x7c,0x40,0x40,0x40,0x40,0xe0,0x00,0x00,0x00,0x00,0x00,0x38,
  0x44,0x82,0x82,0x82,0x82,0x82,0xb2,0xca,0x4c,0x38,0x06,0x00,0x00,
  0x00,0x00,0xfc,0x42,0x42,0x42,0x7c,0x48,0x48,0x44,0x44,0x42,0xe3,
  0x00,0x00,0x00,0x00,0x00,0x3e,0x42,0x42,0x40,0x20,0x18,0x04,0x02,
  0x42,0x42,0x7c,0x00,0x00,0x00,0x00,0x00,0xfe,0x92,0x10,0x10,0x10,
  0x10,0x10,0x10,0x10,0x10,0x38,0x00,0x00,0x00,0x00,0x00,0xe7,0x42,
  0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x3c,0x00,0x00,0x00,0x00,
  0x00,0xe7,0x42,0x42,0x44,0x24,0x24,0x28,0x28,0x18,0x10,0x10,0x00,
  0x00,0x00,0x00,0x00,0xd6,0x92,0x92,0x92,0x92,0xaa,0xaa,0x6c,0x44,
  0x44,0x44,0x00,0x00,0x00,0x00,0x00,0xe7,0x42,0x24,0x24,0x18,0x18,
  0x18,0x24,0x24,0x42,0xe7,0x00,0x00,0x00,0x00,0x00,0xee,0x44,0x44,
  0x28,0x28,0x10,0x10,0x10,0x10,0x10,0x38,0x00,0x00,0x00,0x00,0x00,
  0x7e,0x84,0x04,0x08,0x08,0x10,0x20,0x20,0x42,0x42,0xfc,0x00,0x00,
  0x00,0x1e,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,
  0x10,0x1e,0x00,0x00,0x00,0x40,0x40,0x20,0x20,0x10,0x10,0x10,0x08,
  0x08,0x04,0x04,0x04,0x02,0x02,0x00,0x78,0x08,0x08,0x08,0x08,0x08,
  0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x78,0x00,0x00,0x1c,0x22,0x00,
  0x00,0xff,0x00,0x60,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3c,
  0x42,0x1e,0x22,0x42,0x42,0x3f,0x00,0x00,0x00,0x00,0x00,0xc0,0x40,
  0x40,0x40,0x58,0x64,0x42,0x42,0x42,0x64,0x58,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x1c,0x22,0x40,0x40,0x40,0x22,0x1c,0x00,
  0x00,0x00,0x00,0x00,0x06,0x02,0x02,0x02,0x1e,0x22,0x42,0x42,0x42,
  0x26,0x1b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3c,0x42,
  0x7e,0x40,0x40,0x42,0x3c,0x00,0x00,0x00,0x00,0x00,0x0f,0x11,0x10,
  0x10,0x7e,0x10,0x10,0x10,0x10,0x10,0x7c,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x3e,0x44,0x44,0x38,0x40,0x3c,0x42,0x42,0x3c,
  0x00,0x00,0x00,0xc0,0x40,0x40,0x40,0x5c,0x62,0x42,0x42,0x42,0x42,
  0xe7,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x70,0x10,0x10,
  0x10,0x10,0x10,0x7c,0x00,0x00,0x00,0x00,0x00,0x0c,0x0c,0x00,0x00,
  0x1c,0x04,0x04,0x04,0x04,0x04,0x04,0x44,0x78,0x00,0x00,0x00,0xc0,
  0x40,0x40,0x40,0x4e,0x48,0x50,0x68,0x48,0x44,0xee,0x00,0x00,0x00,
  0x00,0x00,0x70,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x7c,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfe,0x49,0x49,0x49,
  0x49,0x49,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xdc,
  0x62,0x42,0x42,0x42,0x42,0xe7,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x3c,0x42,0x42,0x42,0x42,0x42,0x3c,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0xd8,0x64,0x42,0x42,0x42,0x44,0x78,0x40,
  0xe0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1e,0x22,0x42,0x42,0x42,
  0x22,0x1e,0x02,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xee,0x32,
  0x20,0x20,0x20,0x20,0xf8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x3e,0x42,0x40,0x3c,0x02,0x42,0x7c,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x10,0x10,0x7c,0x10,0x10,0x10,0x10,0x10,0x0c,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc6,0x42,0x42,0x42,0x42,0x46,
  0x3b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe7,0x42,0x24,
  0x24,0x28,0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0xd7,0x92,0x92,0xaa,0xaa,0x44,0x44,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x6e,0x24,0x18,0x18,0x18,0x24,0x76,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0xe7,0x42,0x24,0x24,0x28,0x18,0x10,
  0x10,0xe0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7e,0x44,0x08,0x10,
  0x10,0x22,0x7e,0x00,0x00,0x00,0x03,0x04,0x04,0x04,0x04,0x04,0x08,
  0x04,0x04,0x04,0x04,0x04,0x04,0x03,0x00,0x08,0x08,0x08,0x08,0x08,
  0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x60,
  0x10,0x10,0x10,0x10,0x10,0x08,0x10,0x10,0x10,0x10,0x10,0x10,0x60,
  0x00,0x30,0x4c,0x43,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0x23,0x41,
  0x40,0xfe,0x40,0xfe,0x40,0x40,0x22,0x1c,0x00,0x00,0x00,0x7f,0x40,
  0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x7f,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x60,
  0x20,0x20,0x00,0x00,0x00,0x07,0x04,0x04,0x08,0x0c,0x08,0x08,0x18,
  0x10,0x10,0x10,0x20,0x20,0xc0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x44,0x6e,0x22,0x44,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x63,0x63,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x18,0x18,0x10,0x7e,0x10,0x18,0x18,0x10,0x10,0x10,0x10,0x10,
  0x10,0x00,0x00,0x00,0x18,0x18,0x76,0x7e,0x18,0x10,0x10,0x10,0x10,
  0x18,0x76,0x5a,0x18,0x18,0x00,0x00,0x30,0x50,0x88,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x48,0x48,0x48,
  0x49,0x32,0x04,0x08,0x11,0x22,0x42,0x82,0x02,0x01,0x00,0x00,0x3c,
  0x00,0x3c,0x42,0x40,0x40,0x30,0x0c,0x06,0x02,0x02,0x42,0x7c,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x20,0x60,0x60,0x20,0x10,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3e,0x4a,0x48,0x48,0x4a,0x4e,
  0x48,0x48,0x48,0x49,0x3f,0x00,0x00,0x00,0x7f,0x40,0x40,0x40,0x40,
  0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x7f,0x00,0x00,0x11,0x0a,0x04,
  0x7f,0x00,0x01,0x02,0x04,0x04,0x08,0x10,0x20,0x40,0x7f,0x00,0x00,
  0x00,0x7f,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,
  0x7f,0x00,0x00,0x00,0x7f,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,
  0x40,0x40,0x40,0x7f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x60,0x20,
  0x40,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x01,0x01,0x00,0x01,0x02,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3c,0x3c,
  0x3c,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x60,0xb8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0xe9,0x4b,0x4b,0x5d,0x55,0x5f,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x88,0x70,0x20,0x30,
  0x48,0x40,0x60,0x38,0x0c,0x4c,0x78,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x40,0x20,0x30,0x10,0x20,0x20,0x40,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x02,0x7d,0x49,0x4f,0x48,0x48,0x4d,0x36,
  0x00,0x00,0x00,0x00,0x7f,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,
  0x40,0x40,0x40,0x7f,0x00,0x00,0x00,0x22,0x14,0x08,0x00,0x7e,0x02,
  0x04,0x08,0x08,0x10,0x20,0x40,0x7e,0x00,0x00,0x24,0x24,0x00,0x42,
  0x44,0x24,0x28,0x18,0x18,0x10,0x10,0x10,0x10,0x3c,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x00,0x20,0x20,0x20,
  0x20,0x20,0x20,0x20,0x20,0x00,0x00,0x04,0x04,0x04,0x18,0x2e,0x4e,
  0x50,0x50,0x50,0x22,0x3c,0x40,0x40,0x40,0x00,0x00,0x00,0x1e,0x22,
  0x20,0x20,0x20,0x38,0x20,0x20,0x21,0xfa,0x4c,0x00,0x00,0x00,0x40,
  0x27,0x18,0x10,0x20,0x20,0x20,0x20,0x20,0x20,0x10,0x18,0x27,0x40,
  0x00,0x00,0x00,0x00,0x62,0x24,0x24,0x14,0x18,0xff,0x08,0xff,0x08,
  0x08,0x3c,0x00,0x00,0x00,0x00,0x40,0x40,0x40,0x40,0x40,0x40,0x00,
  0x00,0x40,0x40,0x40,0x40,0x40,0x40,0x07,0x08,0x08,0x04,0x02,0x03,
  0x04,0x08,0x08,0x05,0x02,0x01,0x04,0x08,0x08,0x07,0x00,0x00,0x00,
  0x0c,0x0c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x7e,0xa6,0xc1,0xc1,0xc1,0xa6,0x5a,0x24,0x00,
  0x00,0x00,0x00,0x00,0x00,0xe0,0x90,0xf0,0x90,0xf0,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x11,0x22,
  0x24,0x44,0x4c,0x24,0x22,0x12,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0xff,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x78,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x7e,0xaa,0xa5,0xb9,0xa9,0xa6,0x42,
  0x3c,0x00,0x00,0x00,0x00,0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x48,0x48,
  0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x01,0x01,0x01,0x0f,0x01,0x01,0x01,0x00,0x0f,0x00,0x00,0x00,
  0x00,0x00,0x00,0x70,0x90,0x10,0x20,0x50,0xf0,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x10,0x20,0x10,0x10,0x60,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x20,0x00,0x00,
  0x00,0x00,0x22,0x22,0x22,0x22,0x22,0x2f,0x50,0x40,0x40,0x00,0x00,
  0x00,0x00,0x3e,0xf4,0xf4,0xf4,0xf4,0x74,0x14,0x14,0x14,0x14,0x14,
  0x14,0x14,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x07,0x07,0x03,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x10,0x60,0x00,0x00,0x20,0x20,
  0x20,0x20,0x20,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x70,0x98,0x88,0x50,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x88,0x48,0x24,0x22,0x32,0x24,
  0x44,0x88,0x00,0x00,0x00,0x00,0x00,0x42,0x44,0x44,0x48,0x48,0x50,
  0x12,0x26,0x26,0x27,0x40,0x00,0x00,0x00,0x00,0x00,0x44,0x44,0x44,
  0x48,0x48,0x50,0x17,0x21,0x22,0x44,0x47,0x00,0x00,0x00,0x00,0x00,
  0x62,0x24,0x44,0x28,0x28,0x50,0x12,0x16,0x26,0x27,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x10,0x10,0x00,0x00,0x10,0x20,0x20,0x44,
  0x44,0x3c,0x00,0x00,0x10,0x10,0x00,0x10,0x18,0x28,0x28,0x28,0x24,
  0x3c,0x44,0x44,0x42,0xc7,0x00,0x00,0x08,0x10,0x20,0x10,0x18,0x28,
  0x28,0x28,0x24,0x3c,0x44,0x44,0x42,0xc7,0x00,0x00,0x18,0x28,0x00,
  0x10,0x18,0x28,0x28,0x28,0x24,0x3c,0x44,0x44,0x42,0xc7,0x00,0x00,
  0x30,0x0c,0x00,0x10,0x18,0x28,0x28,0x28,0x24,0x3c,0x44,0x44,0x42,
  0xc7,0x00,0x00,0x24,0x3c,0x00,0x10,0x18,0x28,0x28,0x28,0x24,0x3c,
  0x44,0x44,0x42,0xc7,0x00,0x00,0x18,0x28,0x18,0x10,0x18,0x28,0x28,
  0x28,0x24,0x3c,0x44,0x44,0x42,0xc7,0x00,0x00,0x00,0x00,0x00,0x1e,
  0x18,0x28,0x28,0x2a,0x4e,0x78,0x48,0x48,0x89,0xde,0x00,0x00,0x00,
  0x00,0x00,0x1c,0x23,0x41,0x40,0x40,0x40,0x40,0x40,0x61,0x32,0x0c,
  0x08,0x08,0x30,0x10,0x10,0x6e,0x42,0x40,0x44,0x44,0x7c,0x44,0x40,
  0x40,0x42,0xfe,0x00,0x00,0x0c,0x08,0x10,0x6e,0x42,0x40,0x44,0x44,
  0x7c,0x44,0x40,0x40,0x42,0xfe,0x00,0x00,0x18,0x28,0x44,0x7e,0x42,
  0x40,0x44,0x44,0x7c,0x44,0x40,0x40,0x42,0xfe,0x00,0x00,0x2c,0x2c,
  0x00,0x7e,0x42,0x40,0x44,0x44,0x7c,0x44,0x40,0x40,0x42,0xfe,0x00,
  0x00,0x30,0x10,0x10,0x38,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,
  0x10,0x7c,0x00,0x00,0x0c,0x08,0x10,0x38,0x10,0x10,0x10,0x10,0x10,
  0x10,0x10,0x10,0x10,0x7c,0x00,0x00,0x18,0x28,0x00,0x38,0x10,0x10,
  0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x7c,0x00,0x00,0x24,0x2c,0x00,
  0x38,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x7c,0x00,0x00,
  0x00,0x00,0x00,0x3c,0x22,0x22,0x21,0x21,0x31,0x21,0x23,0x22,0x26,
  0x78,0x00,0x00,0x30,0x0c,0x00,0x42,0x62,0x62,0x52,0x52,0x4a,0x4a,
  0x46,0x46,0x42,0xe2,0x00,0x00,0x30,0x10,0x10,0x2c,0x42,0x42,0x42,
  0x42,0x42,0x42,0x42,0x42,0x24,0x18,0x00,0x00,0x08,0x10,0x10,0x2c,
  0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18,0x00,0x00,0x18,
  0x28,0x44,0x3c,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18,
  0x00,0x00,0x30,0x0c,0x00,0x3c,0x42,0x42,0x42,0x42,0x42,0x42,0x42,
  0x42,0x24,0x18,0x00,0x00,0x24,0x24,0x00,0x3c,0x42,0x42,0x42,0x42,
  0x42,0x42,0x42,0x42,0x24,0x18,0x00,0x00,0x00,0x00,0x00,0x10,0x08,
  0x04,0x02,0x01,0x02,0x04,0x08,0x10,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x3c,0x42,0x46,0x4a,0x4a,0x53,0x52,0x62,0x62,0x44,0x38,0x00,
  0x00,0x30,0x10,0x00,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,
  0x44,0x38,0x00,0x00,0x08,0x08,0x10,0x62,0x42,0x42,0x42,0x42,0x42,
  0x42,0x42,0x42,0x44,0x38,0x00,0x00,0x18,0x28,0x00,0x42,0x42,0x42,
  0x42,0x42,0x42,0x42,0x42,0x42,0x44,0x38,0x00,0x00,0x24,0x24,0x00,
  0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x44,0x38,0x00,0x00,
  0x08,0x08,0x10,0x62,0x44,0x24,0x28,0x18,0x18,0x10,0x10,0x10,0x10,
  0x3c,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x38,0x26,0x21,0x21,0x21,
  0x26,0x38,0x20,0x70,0x00,0x00,0x00,0x00,0x00,0x1c,0x22,0x22,0x22,
  0x2c,0x22,0x22,0x22,0x22,0x3a,0x6c,0x00,0x00,0x00,0x00,0x00,0x00,
  0x10,0x00,0x00,0x38,0x44,0x44,0x44,0x44,0x44,0x3a,0x00,0x00,0x00,
  0x00,0x00,0x00,0x08,0x18,0x00,0x38,0x44,0x44,0x44,0x44,0x44,0x3a,
  0x00,0x00,0x00,0x00,0x30,0x28,0x44,0x00,0x00,0x7c,0x44,0x1c,0x64,
  0x44,0x45,0x3a,0x00,0x00,0x00,0x00,0x20,0x5c,0x00,0x00,0x00,0x7c,
  0x44,0x1c,0x64,0x44,0x45,0x3a,0x00,0x00,0x00,0x00,0x28,0x6c,0x00,
  0x00,0x00,0x7c,0x44,0x1c,0x64,0x44,0x45,0x3a,0x00,0x00,0x00,0x00,
  0x38,0x28,0x10,0x00,0x00,0x7c,0x44,0x1c,0x64,0x44,0x45,0x3a,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x66,0x99,0x91,0x3f,0x50,0x90,0x99,
  0x6e,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x64,0x44,0x40,
  0x40,0x44,0x44,0x38,0x20,0x10,0x60,0x00,0x00,0x00,0x00,0x10,0x10,
  0x00,0x3c,0x42,0x42,0x7c,0x40,0x22,0x1c,0x00,0x00,0x00,0x00,0x00,
  0x04,0x08,0x08,0x00,0x3c,0x42,0x42,0x7c,0x40,0x22,0x1c,0x00,0x00,
  0x00,0x00,0x00,0x18,0x38,0x44,0x00,0x3c,0x42,0x42,0x7c,0x40,0x22,
  0x1c,0x00,0x00,0x00,0x00,0x00,0x2c,0x24,0x00,0x00,0x3c,0x42,0x42,
  0x7c,0x40,0x22,0x1c,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x10,0x00,
  0x10,0x10,0x10,0x10,0x10,0x10,0x38,0x00,0x00,0x00,0x00,0x00,0x08,
  0x10,0x10,0x00,0x10,0x10,0x10,0x10,0x10,0x10,0x38,0x00,0x00,0x00,
  0x00,0x10,0x28,0x48,0x00,0x00,0x10,0x10,0x10,0x10,0x10,0x10,0x3c,
  0x00,0x00,0x00,0x00,0x28,0x6c,0x00,0x00,0x00,0x10,0x10,0x10,0x10,
  0x10,0x10,0x3c,0x00,0x00,0x00,0x00,0x00,0x24,0x18,0x28,0x04,0x3e,
  0x42,0x42,0x42,0x42,0x42,0x3c,0x00,0x00,0x00,0x00,0x30,0x1c,0x00,
  0x00,0x00,0x7c,0x42,0x42,0x42,0x42,0x42,0xe6,0x00,0x00,0x00,0x00,
  0x00,0x00,0x10,0x00,0x00,0x3c,0x42,0x42,0x42,0x42,0x66,0x3c,0x00,
  0x00,0x00,0x00,0x00,0x00,0x0c,0x08,0x00,0x3c,0x42,0x42,0x42,0x42,
  0x66,0x18,0x00,0x00,0x00,0x00,0x18,0x28,0x04,0x00,0x00,0x3c,0x42,
  0x42,0x42,0x42,0x44,0x38,0x00,0x00,0x00,0x00,0x30,0x1c,0x00,0x00,
  0x00,0x3c,0x42,0x42,0x42,0x42,0x44,0x38,0x00,0x00,0x00,0x00,0x24,
  0x2c,0x00,0x00,0x00,0x3c,0x42,0x42,0x42,0x42,0x44,0x38,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x1f,0x00,0x01,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3e,0x46,0x4a,
  0x52,0x62,0x44,0xb8,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0xc4,
  0x44,0x44,0x44,0x44,0x44,0x26,0x3a,0x00,0x00,0x00,0x00,0x00,0x04,
  0x08,0x18,0xc4,0x44,0x44,0x44,0x44,0x44,0x26,0x3a,0x00,0x00,0x00,
  0x00,0x18,0x28,0x44,0x00,0x02,0x42,0x42,0x42,0x42,0x42,0x46,0x38,
  0x00,0x00,0x00,0x00,0x00,0x00,0x24,0x24,0xc4,0x44,0x44,0x44,0x44,
  0x44,0x26,0x3a,0x00,0x00,0x00,0x00,0x0c,0x08,0x10,0x00,0x00,0x24,
  0x24,0x24,0x18,0x18,0x10,0x10,0x10,0x60,0x00,0x00,0xc0,0x40,0x40,
  0x40,0x5e,0x22,0x42,0x42,0x22,0x22,0x54,0x48,0x40,0x60,0x00,0x00,
  0x24,0x24,0x00,0x00,0x00,0x24,0x24,0x24,0x18,0x18,0x10,0x10,0x10,
  0x60,0x60
 楼主| cyh537 发表于 2007-3-1 20:11 | 显示全部楼层
另外 直接访问外部地址也不对啊.
我先把字库定位在32k的位置0x8000
然后用下面代码取数据,读到的数据全是0.迷惑?
while(i < 500)
print("   i=0x%x     *(unsigned char*)(0x8000 + i) = 0x% x ",i,*(unsigned char*)(0x8000 + i));
i++;
AA_55 发表于 2007-3-1 21:10 | 显示全部楼层
你把大数组给定义到RAM中去了
RAM不够大,读取超出RAM大小的部分肯定就是随机数据了。
C语言标准中没有修饰变量存储空间的统一规定,各个编译器实现的方法不同。GCC AVR并不是将数组用const修饰就是将数组给定义到程序存储空间了,它只是指明这个数组是不能被修改的常量,而这个数组的存储还是在RAM中
mohanwei 发表于 2007-3-1 21:44 | 显示全部楼层
楼上说得对,加个“code”关键字,将它定义到程序存储空间
 楼主| cyh537 发表于 2007-3-4 19:51 | 显示全部楼层
仍未解决
多谢 AA_55 和 mohanwei.
不过如果是因为使用ram超出4k,编译器应该报错啊.
另外,我把编译出来的hex文件转换成bin格式,
和4k的英文字库进行比对,发现里面的确有完整的字库,4k!
而且去掉该定义后编译的hex文件转换成bin文件后和刚才整整少了4k.正好是字库的容量.
dai_weis 发表于 2007-3-4 20:45 | 显示全部楼层
参考一下pgmspace.h
把你的数据另行写入FLASH的指定开始位置,连续存储,读取的时候采用pgmspace.h文件中的读取函数,采用地址起始位置+偏移量来完成对数组的访问,看看可行不。
AA_55 发表于 2007-3-4 22:19 | 显示全部楼层
如果你给定的编译条件不正确,编译器是不会报错的
要知道,c语言最特殊的地方,是开放了很多便利给程序员。它假定:程序员知道自己在做什么,所以编译器不太干涉程序员的行为。如果真的发生了问题,要程序员自己解决。c语言运用的一个基本原则就是:要自己控制程序行为,而不是依赖编译错误提示。
另外,楼主还是没有明白c语言的机制。
在你所定义的数组中,数据还是存在于代码中的。当你的程序初始化时候,它被复制到RAM中去。因为,你的定义就是在RAM中建立一个数组嘛(原因我说过),它必须按照你的定义去建立一个这么大的数组,不管真正的RAM大小是多少。但是,初始化RAM数组的元素的数据必须有一个原始的存储空间,它只能够根据程序原意的定义,以立即数的方式存储在程序中。所以,你能看到源程序生成的代码中包含了这些数据,但是却不能操纵这些数据。这些数据必须复制到RAM中,才符合程序定义,才能操纵。
